Old 06-02-2004, 09:58 PM   #12616
j240z's Avatar
Default Transponder mount AND switch mount
I just did this today. I was looking for a way to use both the transponder mount and the switch mount on my MTX-3. I mounted the trans mount in the normal position. Then I placed the switch mount upside down above the trans mount. I used 2 longer screws to mfasten them in the oem holes. It seems to work really nice. I didn't like not having a switch and I didn't want to drill any unneccesary holes. If someone has already posted this I appologize for the repeat. Hopefully someone else will find this as useful as I have. Here are a couple of pics of the final result.
j240z is offline   Reply With Quote
Old 06-02-2004, 09:58 PM   #12617
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Default TIRE SHORE
Originally posted by Tag
does anyone knows what is the tire compund that comes with a the stock mtx-3 ? i have a set lying around and would like to try it next time around..thanks !
I believe the stock tires are 40 shore for the front & 37 shore for the rear.
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 06-02-2004, 10:00 PM   #12618
j240z's Avatar
Default Re: Transponder mount AND switch mount
One more pic. It might affect CG a bit but it seems worth it...?
Old 06-02-2004, 10:05 PM   #12619
gentleman81's Avatar
thanks thats a nice trick
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 06-02-2004, 10:28 PM   #12620
rjl
rjl's Avatar
The stock tyres are 37 front and rear.
rjl is offline   Reply With Quote
Old 06-02-2004, 11:14 PM   #12621
Send a message via AIM to Johnnytc3
Default Engine problem
hey guys, i tried to mount my sirio engine in my mtx-3 with the novarossi carb and it binds against the brake disks, my picco mounts in just fine with the same carb.... sirios and mugens dont mix??
Johnnytc3 is offline   Reply With Quote
Old 06-03-2004, 02:00 AM   #12622
rjl
rjl's Avatar
Hey AMG good to see you running Active rubber, what do you think?
Old 06-03-2004, 06:44 AM   #12623
Bivens's Avatar
INCORRECT......They mix well.. I am running sirio's (sometimes with a nova carb from an MT12). You do have the brake-rub problem if you are not careful during installation. You must slightly rotate the carb to gain clearance. In-fact...the previous owner of my "used" carb didn't understand this and there is a groove worn in the mid-range needle side of the carb, just below the screw......gives some additional clearance....
Bivens is offline   Reply With Quote
Old 06-03-2004, 08:31 AM   #12624
Taylor-Racing's Avatar
Originally posted by theRED5
Ed> For the front belt I use the MRX3 "DO240" "S 6mm MRX" belt in the front on the MTx3 or Kawa K-770 belt for the rear of the MRX, on the front of the MTX3, they fill the pulley and will last a long time. I've had the same one on my car since just before the WinterNats, with no signs of wear.
theRED5
Are the MRX belts softer than the standard MTX ones?
Taylor-Racing is offline   Reply With Quote
Old 06-03-2004, 09:03 AM   #12625
Bandeira's Avatar
Send a message via ICQ to Bandeira
Originally posted by AMGRacer
The difficulty that a fuel gun presents is that you require one hand to completely use the gun, so you only have one hand left to hold the car and open the tank. With the zip tie from the tank lid this becomes pretty hard. Also the tank lid must be pretty much completly vertical to get the nozzle onto the tank lid "square", again this is difficult with the type of opening device you mention.
I found the best way is as follows. Run a large zip tie from the tank lid to the rear shock tower. Secure the zip tie to the rear shock tower. Keep it fairly tight. You will notice that the zip tie runs past the cutout in the rear window. Reach through the rear window with one hand and grab the zip tie and lift the car. When you do this the tank flips open pretty much vertical and you can hold the car in the air with just the one hand. You then fuel it and drop it back onto the track and the tank snaps closed.
Yeah... I've sen lots of people using this method, but not in MTX3 because there is nowhere in the rear shock tower for you to secure your zip-tie...
Bandeira is offline   Reply With Quote
Old 06-03-2004, 02:08 PM   #12626
What type of battery configuration is on the stock mtx-3 and the prospec, anyone have pics of each....?
vadn1 is offline   Reply With Quote
Old 06-03-2004, 04:23 PM   #12627
Send a message via AIM to kreidel
The stock MTX3 and the Prospec use the exact same battery packs because they are identical cars just one has more hopup addons.
kreidel is offline   Reply With Quote
Old 06-03-2004, 04:31 PM   #12628
]-[0pa]0ng's Avatar
Trying to figure which way to go on an engine here. Just looking to have fun does not have to be Roar sactioned. I have heard the Mugen XS.12 is a solid runner and hold a tune well or there is the Novarossi NSR.12S5. Which one if any has more potential?
Mugen I can pick up for $299
Novarossi for $245
Thanks!
]-[0pa]0ng is offline   Reply With Quote
Old 06-03-2004, 04:35 PM   #12629
]-[0pa]0ng's Avatar
RD Logics has a 800 mah receiver pack for your MTX3. I just bought one.
RD Logics
Cost $ 23.00
Old 06-03-2004, 07:21 PM   #12630
theRED5's Avatar
I don't know whether they're softer, the case with the front one is that it's much wider than the stock front belt.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
