Old 05-31-2004, 11:01 PM   #12541
Ed Delgado's Avatar
Default Traxxas Part #4863
The part # is #4863
Ed Delgado is offline   Reply With Quote
Old 06-01-2004, 06:19 AM   #12542
Taylor-Racing's Avatar
Originally posted by Ah10
You might want to decrease rear toe in to gain more steering and use A block. If you get too much steering then you can decrease dual rate on your radio!
Thanks Ah10,
I've already decreased rear toe and narrowed the front a bit but we're currently running the B block. I'll give the "A" a go. I would love to get too much steering.
This'll be a change - with the Kyosho, we were always chasing rear end traction.
Taylor-Racing is offline   Reply With Quote
Old 06-01-2004, 08:32 AM   #12543
theRED5's Avatar
R/C Tech Charter Subscriber
You might try putting gray springs in the rear with the stock light blue front springs. I get the rear to rotate like that.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 06-01-2004, 08:46 AM   #12544
Default Re: Traxxas Nitro 4-Tec belt works
Originally posted by Ed Delgado
I work at a LHS and tried every belt we had in stock from other cars-Serpent's 705 & Impulse, HPI's R40, Hot Bodies' Cheapo Car- to no avail. Then a couple of weeks ago, I looked up at the wall of parts and saw Traxxas' side belt for the Nitro 4-tec. "What the heck, let me try it out" I thought-perfect fit! The only thing is that it is a little stiff- it's a little thicker than Mugen's stock side belt. The next weekend while at the track, I compared it to the one that is sold on E-Bay (another racer had one) and the quality of the teeth on the belt did not look as good as on the Traxxas belt.
I don't have the part # handy, but I'll post it as soon as I get back to work later this week. Your LHS should be able to look it up and order one for you.
Like I said, it's a bit stiffer than Mugen's stock belt, but until Mugen Racing get Kawahara's low friction conversion belt back in stock it will have to do.
Ed that is fantastic.
Is there a way to make belts softer, any type of chemical. Also some of the electric racers cut teeth off of the pulleys, with that work here....?
vadn1 is offline   Reply With Quote
Old 06-01-2004, 09:15 AM   #12545
Thanks guys for the info... I was told Kawahara's pulley conversion comes the the side belt... That Traxxas side belt might be worth looking into for those who already have the 16/19 conversion... I called Nitro house as well.. Didn't have it there either... I've never been an ebay person... But I guess I'll have to give it a try...
RC_Alan
rc_alan is offline   Reply With Quote
Old 06-01-2004, 10:27 AM   #12546
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
is there anyone here running a rdlogics turbo II pipe ? what exhaust gasket do you guys using ? i am kind of having some leakage problem, the header is a bit too big for my stock novarossi gasket ..
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 06-01-2004, 12:07 PM   #12547
gonzoY5's Avatar
Use the RD logics one. I had that same problem when I got my Turbo II, and coincidentaly I had an RD one and it worked perfect.
gonzoY5 is offline   Reply With Quote
Old 06-01-2004, 12:49 PM   #12548
alucard13's Avatar
Default Prospec
I have noticed alot of you guys have been busy building the Prospec. I am about to get one myself (should be here this week I hope), and was wondering what complications you have had or any advice in setting this up? I have an MTX-3, but I did not build it myself and since I am enjoying this car alot I want to build it from scratch so I know how to fix it. Thanx
alucard13 is offline   Reply With Quote
Old 06-01-2004, 12:58 PM   #12549
Tag
Tag's Avatar
okay, thanks for the info, i will give it a try
Old 06-01-2004, 02:23 PM   #12550
rjl
rjl's Avatar
You could try a .15 size gasket.
rjl is offline   Reply With Quote
Old 06-01-2004, 03:24 PM   #12551
]-[0pa]0ng's Avatar
Default Kawahara Low friction belt
Couple questions here:
1. Will this belt work well with a 19t & 16t setup or am I on the wrong belt to begin with?
2. Does anyone have the part number for it?
3. What are your thoughts on the latest Team Int. tire truer.
Lastly I'm brand new to on road. This is my first car it's a Mugen MTX3 Prospec. So far I have ordered quite a bit form 3 Racing and K factory. I tried to pick up as much CF as I could then bought every pulley and gear I could find. Was building this car and ran into all this plastic stuff ( gears & pulleys ) as well as the diff. case. and thought oh well all that has to go. I'm running nothing but Fast tires for it. I'm buying 2 painted bodies from Shop UFO that I came across from this site. Looks real cool.
Thanks,
Pretty cool site!
]-[0p
]-[0pa]0ng is offline   Reply With Quote
Old 06-01-2004, 03:33 PM   #12552
Tag
Tag's Avatar
i ve tried that but it does not fit snuggly.
Old 06-01-2004, 03:34 PM   #12553
Tag
Tag's Avatar
where do you guys get parts for novarossi engines ? i am looking to buy new bearings for my engine.. thanks
Old 06-01-2004, 03:45 PM   #12554
]-[0pa]0ng's Avatar
One palce to buy real sweet bearing or I would think the best anywhere is: Boca Bearings You have a high end engine treat it with a high temp ultimate ceramic bearing. I just bought the Mugen X12 and have just sent it out to be modified by a Serpent team driver out of Austin TX. I here it's supose to be ballistic.
All I have at the moment is the Mugen belts trying to fgure which way to go or what belts are the best to buy for this car.
]-[0p
Old 06-01-2004, 04:42 PM   #12555
theRED5's Avatar
Default RC_ALAN>>
E mail this guy for the Kawa 16/19 belts, I've ordered from him a couple of times, and he has fast friendly service.
Micheal Gutierrez
Mugen MRx4
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
