Old 05-26-2004, 06:34 AM   #12391
VenomWorldOrder's Avatar
Originally posted by bleach1
Im building an mtx3 prospec and am having a little problem with the clutch. I am following the steps but even without any shims behind the thrust bearing there is no play and the hub is locking against the clutch shoe. I am using a Jp rossi engine and the kit supplied collet. any ideas?
if you have no shims behind the thrust bearing, (ie closest to the hex screw head) and it is still tightening up to the point that the bell doesn't spin it means that the flywheel collet is not going far enough into the flywheel. use another flywheel collet that is worn down a little and see if the flywheel is pushed in towards the engine more. IS THERE A LARGE GAP BETWEEN THE MOTOR AND FLYWHEEL??
come to mbank sunday, and i can lend you one of my collets, hopefully they fit better.
VenomWorldOrder is offline   Reply With Quote
Old 05-26-2004, 12:10 PM   #12392
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default MTX-3 Chassis
Good Day All,
Just an FYI for everyone.
best,
fish
P.S. Thanks to Nitropimp for the contribution
eddiethefish is offline   Reply With Quote
Old 05-26-2004, 12:17 PM   #12393
Ducati998's Avatar
Default Re: rear window cut out
Originally posted by Ed Delgado
Hey Ducati, its pretty easy. First draw it out on the body itself with a marker. Then, with a Dremel tool, open holes in the corner of each openeng, the trim away the rest with scissors. If you notice, the three bodies have different solutions to the rear window. The latest, my 2nd Mazda 6 seems to be the best- very little rear flex in rear of body.
Thanx Ed, I going to follow your direction and do it on one of my body!
Ducati998 is offline   Reply With Quote
Old 05-26-2004, 12:18 PM   #12394
Ducati998's Avatar
Default Re: MTX-3 Chassis
Originally posted by eddiethefish
Good Day All,
best,
fish
HI! I was wondering who make the middle chassis? Thanx!
Old 05-26-2004, 02:03 PM   #12395
For a MTX-3 prospec what parts do i need to run a lola body shell....?
Also, If someone could post a pic or pattern set up of the MTX-3 prospec battery layout.
Will 26mm tires fit ther rear of the prospec.
vadn1 is offline   Reply With Quote
Old 05-26-2004, 02:34 PM   #12396
Varuth's Avatar
Talking about light weight.
Varuth is offline   Reply With Quote
Old 05-26-2004, 02:50 PM   #12397
B
Default Re: Re: MTX-3 Chassis
Probably FiveStars? Looks like it, or the ETF one.
They are both 3mm though.
B is offline   Reply With Quote
Old 05-26-2004, 02:53 PM   #12398
Suspended
hudy's Avatar
is the last chasis the one that come with the mtx-3 prospec
hudy is offline   Reply With Quote
Old 05-26-2004, 02:56 PM   #12399
Someone needs to come up with a Carbon Fiber chassis.
Old 05-26-2004, 02:58 PM   #12400
B
carbon fiber chassis is not for nitro cars
1) they crack instead of bend.
2) they dissipate heat poor, so the engine may overheat. I am skeptic to see that those small cut out vents can do wonders in cooling
Carbon fiber chassis is for EP
Old 05-26-2004, 03:24 PM   #12401
Suspended
hudy's Avatar
Think about this real cars have carbon fibre hood that stand up to alot of heat and nothing happens to them I believe its the import scene that does this to their cars
Old 05-26-2004, 03:33 PM   #12402
Ive heard and seen pics of 1/8 scale buggy driver in Europe us CF for chassis'
Old 05-26-2004, 03:51 PM   #12403
mckrooz's Avatar
Send a message via AIM to mckrooz
The problem that lies is not that it can't take the heat, it's that the material doesn't dissipate the heat as well as metal. It won't 'absorb' the heat like a metal chassis will, therefore causing the engine to overheat.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 05-26-2004, 03:58 PM   #12404
mckrooz's Avatar
And CF hoods on import cars are used to lighten the weight of the car. Mostly just eye candy though.
Kyosho RRR Evo2
Old 05-26-2004, 04:08 PM   #12405
FW-05RR's Avatar
thats true
FW-05RR is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
