Old 05-24-2004, 04:39 PM   #12316
Suspended
hudy's Avatar
thats no mtx-3 look at the where the wheels go it looks like the 1/8 scale quick tire change design
hudy is offline   Reply With Quote
Old 05-24-2004, 04:42 PM   #12317
Nitropimp's Avatar
Hudy you crack me up.
It is a 1/8 a SMP slide. We are talking aobut the upper deck. How it's blue Carbon Fibre. And wouldn't it be cool to have a MTX-3 like it. That's all.
Nitropimp is offline   Reply With Quote
Old 05-24-2004, 04:57 PM   #12318
rjl
rjl's Avatar
Default Re: Negative diff
Originally posted by Grinder
Anyone know where I can get a negative diff, I ordered one and the place did'nt bother to tell me they are out of them.
PM me, I have stock.
rjl is offline   Reply With Quote
Old 05-24-2004, 05:09 PM   #12319
B
Originally posted by Nitropimp
ok I measured the stock upper deck and it's approx 2.40.
Should I get the 2mm and maybe save some weight or should I get the 3mm and have it the upper plate beefier????? Three color choices silver, gold and blue....
maybe you could reduce the weight by cutting more holes in the upper deck like the KAI upper deck. The downside is that it will be weaker in strength. However, with the right cut outs, I think it could work, and at the same time, look sexier.
B is offline   Reply With Quote
Old 05-24-2004, 05:10 PM   #12320
Bandeira's Avatar
Send a message via ICQ to Bandeira
Originally posted by Bandeira
Hi guys!!
Just arrived from my weekend racing 600km away from home...
An more-or-less important race for me... I was using my third engine...
My car was running fine with 40/40 tyres, but then when entering the high speed sweeper i might have gotten my trigger to the neutral(I found that after the race) as I was using drag brakes, (which I am not very used to) my rear end slipped a little bit then the car flipped over... Results: Broken wing + broken rear bearing;
At this time(as I didn't have enought time to work on the setup) I fitted some 45 tyres at the front, but at this time I needed to get plenty of Dual Rate for some turns, but wasn't flipping...
I suppose I should try to get my rear end more bite when entering the turn so i can run on 40/40 tyres...
Or maybe, make my rear end slip more and use 45/40 tyres...
Any ideas/comments/suggestions/anything?
PS: for the results, as It rained before de B Main(I jumped straight to the A Main - Roar style), I ended up with a 6th place overall... not bad for an improvised 45tyre half a minute before the qual.
No comments on my post?
Bandeira is offline   Reply With Quote
Old 05-24-2004, 06:15 PM   #12321
theRED5's Avatar
R/C Tech Charter Subscriber
What springs are you using?
I sometimes run the Gray rear springs with the lt Blue front springs, That lets the rear steer a little.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 05-24-2004, 06:15 PM   #12322
theRED5's Avatar
But since i've gotten the new Blue springs, I use them all around.
Mugen MRx4
Old 05-24-2004, 06:26 PM   #12323
Grinder's Avatar
rjl ygpm
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 05-24-2004, 06:37 PM   #12324
rattlr2's Avatar
i'll try again rear toe 3deg. is that total or 3deg per side have hudy setup jig and would like to know
rattlr2 is offline   Reply With Quote
Old 05-24-2004, 06:50 PM   #12325
Grinder's Avatar
When someone says they run 3 degrees of rear toe that means 3 degrees on each side left and right. Same with camber, castor, ect..
Old 05-24-2004, 06:52 PM   #12326
ilaybrk's Avatar
stock mtx3 chassi 110.5 my prospec is 109.5
ilaybrk is offline   Reply With Quote
Old 05-24-2004, 07:09 PM   #12327
Varuth's Avatar
What does that mean? 110.5mm in lenght?
Varuth is offline   Reply With Quote
Old 05-24-2004, 07:10 PM   #12328
Bandeira's Avatar
oh yeah... I'm with the dark blue all around...
I usually dial my car with the rear roll center... but this time it seems that got on the edge... I'm planning to stick up with the 45/40 tyres and just get the rear roll center a little lower so i get more steering...
I would love if this car had front roll center adjustment...
cheers...
Old 05-24-2004, 07:25 PM   #12329
ilaybrk's Avatar
grams
Old 05-24-2004, 07:44 PM   #12330
Send a message via AIM to kreidel
cheers...
Is that the A block for lower?
kreidel is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
