Old 05-22-2004, 10:05 AM   #12196
Ducati998's Avatar
Thank to all you guy that replied to my question!
Ducati998 is offline   Reply With Quote
Old 05-22-2004, 12:33 PM   #12197
rcmike's Avatar
Trader Rating: 40 (100%+)
Default 16 x 19 side belt ratio
Can someone post the link to this topic,cant seem to find in search funtion. Want to read about pros and cons with it" THANKS
rcmike is offline   Reply With Quote
Old 05-22-2004, 01:59 PM   #12198
Grinder's Avatar
I have been using the conversion for some time now. I use the conversion usually during a main, sometimes during qualifying. I really do not see much handling difference. I have noticed that if I use the conversion with the rear tires the same size as the front it wears out the front 16 tooth pulley faster than normal and is harder on the front belt, but I like it. Keeps my car handling very consistently throughout a long main.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 05-22-2004, 03:09 PM   #12199
B
Default Re: 3-Racing Universals
Originally posted by gonzoY5
Everyone bashes the 3-Racing Universals but I've only broken one in 6 months of racing, and that was when I clipped a barrier on a top speed sweeper. I also tore off my Upper and Lower arms so it wasn't a soft hit. I think those people that call them so cheap need to stop crashing so much.
And even if they're not the same quality as the Mugen Uni's you can get them here http://www.jplracing.com/shop/ for $11 a pair. Even if they don't last as long you can still get 3 pairs for the cost of one of the "better" quality ones.
Some others have different experience with them. Most peopl's 3Racing universals break upon a small tap, or sometimes, when even nothing seemed to have happened, and the universals just blew up.
Guess u got a good one.
B is offline   Reply With Quote
Old 05-22-2004, 03:11 PM   #12200
B
Originally posted by BrainTeased
Im using a Q-world no probs at all uses one motor setup.
yah. i use the same one for many years now. It has never failed me, and it is still running strong.
Best R/C investment yet
Old 05-22-2004, 03:47 PM   #12201
Send a message via AIM to Profoxcg
do you guys know if I can use my serpent started boc for when I build my mugen?
Profoxcg is offline   Reply With Quote
Old 05-22-2004, 05:10 PM   #12202
Q
Q's Avatar
Originally posted by Ducati998
Hi! I was wondering what starter box do you guys use? Thinking of getting a new one. ThanK!
I use associated starter box and it works well with mtx-3. you have to turn the motor inside which is no problem.
Q is offline   Reply With Quote
Old 05-22-2004, 05:41 PM   #12203
Sow&Steady's Avatar
You can but you'll need to manually line up your chassis each time.
Maybe you can do a hack mod job on the rear guide.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-22-2004, 07:44 PM   #12204
TOEBSTER2's Avatar
I just got my MTX-3 finished today, but my only problem is what the heck are you supposed to use for a reciever pack. The directions aren't very clear on that. I fiddled with different packs all morning. The only thing that will fit could be phone size cells or like five AAA batteries. Anyone know for sure.
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 05-22-2004, 08:02 PM   #12205
gonzoY5's Avatar
Bingo...that's exactly what it is. 5 cell AAA pack in a 3x2 hump configuration.
gonzoY5 is offline   Reply With Quote
Old 05-22-2004, 08:05 PM   #12206
BrainTeased's Avatar
Yea i was told to use 5 AAA batteries! but i was thinking if they were 1.5V each that would = to 7.5 volts! but for size yea AAA's or you can get the hump packs which are a smaller type of cell and work great, and works out to 6 Volts.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 05-22-2004, 08:08 PM   #12207
Roger's Avatar
I just got my new chassis today and I will take some pix of it for you guys. The chassis is made by PRP. 7075 4mm chassis with 4mm carbon fiber shock towers. The chassis is CNC cut. It's pretty clean.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 05-22-2004, 08:15 PM   #12208
Ducati998's Avatar
I finally got my mtx-3 started today after manage to turn my wheel on the Associated box, now I won't have to get a new one. Anyway the problem is that after starting up my engine for a while it run for about couples of minutes then it dies. Then when I tried to start it up again it die right away. I tried to adjust the high speed, but it don't seem to work. Do you guy no what maybe the problem? I'm thinking it maybe the glow plug gone bad, but what do you guy think? Thank!
Old 05-22-2004, 08:25 PM   #12209
Does it idle loud or really sluggish? try to play with your low speed screw as thats what your car is running at when you start it. also when you say it runs for a coupler of mins do you mean driving for a couple of mins or idling for a coupler of mins?
Old 05-22-2004, 08:33 PM   #12210
Ducati998's Avatar
It idel pretty loud. Today when starting it I did not run the car. I just added fuel and fired it up to make sure it run. The first time I started it up it idel for a while just sitting there then it dies all sudden then after that I have a bit rouble fireing it up again. I'm runnign a turbo plug, I tried to take the plug out and connect it with the glow plug ignitor, the plug wire didn't turn too bright but I'm not sure if turbo plug suppose to do that, I never used a turbo plug before. I'll try to play the low speed and see, thank!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
