Old 05-19-2004, 08:50 PM   #12076
theRED5's Avatar
R/C Tech Charter Subscriber
You have to get the gears for the rear diff, and build the fornt diff.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 05-19-2004, 08:53 PM   #12077
Default Re: 16/19 conversion belts
Originally posted by Grinder
The Traxxas nitro 4tech 121 tooth main belt is perfect to use for the conversion, don't ask how I found that out. They don't last as long as the ebay belts, but they do last about the same as the Kawahara belts, just not as free. Just got my Prospec today.
The Kawahara conversion belt didnt last very long though. Any tips on prolong it life span?.
challenger is offline   Reply With Quote
Old 05-19-2004, 08:54 PM   #12078
Nitropimp's Avatar
does mugen make a diferential for the front of the car? on of the tracks i run on is very tight and calls out for a differential.
I'm sure that Mugen makes a front diff. I would go Kawahara diff. Can the Negative diff be put in the back???? I'm not sure but I bet the Fish does. Yeah the Prospec is worth it. Hop ups that you really want are the 4mm chasis and CVD's along are worth over $100. So if you can find and afford one go for it....
Nitropimp is offline   Reply With Quote
Old 05-19-2004, 09:02 PM   #12079
Send a message via AIM to Profoxcg
so I get a the stuff to build a rear diff and a just a box for the font? not one way or anything?
I though the negative diff was for the rear...
Is it hard to change diffs in case I want to try different oils for example?
another question, are the blue prospec spring any better than what comes with the mtx3?
Profoxcg is offline   Reply With Quote
Old 05-19-2004, 09:08 PM   #12080
gentleman81's Avatar
u get one rear diff, one way for the front, and a diff housing if you want to buy and build a front diff, the neg diff is for the rear, the springs i dont know, go to mugenseiki.com and mugenracing.com all the info is there
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 05-19-2004, 09:13 PM   #12081
thanks
Old 05-19-2004, 09:16 PM   #12082
go to the prospec on either site and it will have a list of included option parts, the cvds run $40 a set, the chassis is $80, thats makes up the diff right there, not to mention the $80 titanium pillow balls!
Old 05-20-2004, 04:28 AM   #12083
can you give me the url where it is explained what the roll center blocks do. i know it's here somewhere but i don't now where exactly there are too many pages.
Speed De is offline   Reply With Quote
Old 05-20-2004, 07:00 AM   #12084
rattlr2's Avatar
when using 16/19 conversion you have to cut down front tires 3-4mm smaller than rear is this correct/ if so what do you set droop at? with stock tires your suppose to set at 1 . cutting tires 3-4mm down would definitly change this setting correct. how do you calculatediffernt tire size into this setting
rattlr2 is offline   Reply With Quote
Old 05-20-2004, 07:20 AM   #12085
Taylor-Racing's Avatar
You will have to re-set your front ride height to accomodate the smaller fronts and then re-set the droop.
Taylor-Racing is offline   Reply With Quote
Old 05-20-2004, 07:23 AM   #12086
InitialD's Avatar
If you use 4 mm smaller diameter tires and reset your ride height to the original, use -1 for the front droop.
Old 05-20-2004, 07:44 AM   #12087
Vinyard's Avatar
Vinyard is offline   Reply With Quote
Old 05-20-2004, 12:42 PM   #12088
Varuth's Avatar
Not sure you guys seen this already. What do you think?
http://www.rcmag.com/viewtopic.php?m...c=1616&start=0
Varuth is offline   Reply With Quote
Old 05-20-2004, 01:25 PM   #12089
over gear's Avatar
Trader Rating: 15 (100%+)
whoa! time for a new car!
over gear is offline   Reply With Quote
Old 05-20-2004, 01:45 PM   #12090
Varuth's Avatar
Hehehehehee... Think so too
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
