Old 05-18-2004, 11:35 AM   #11986
alucard13's Avatar
While I was racing last sat whenever I turned right on a particular turn I would either roll or the right wheels would lift. How would I correct that?
alucard13 is offline   Reply With Quote
Old 05-18-2004, 11:52 AM   #11987
Send a message via ICQ to Cartman
Slow down
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 05-18-2004, 12:13 PM   #11988
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: lay down throttle servo kit!
Originally posted by boy2rc
NIce
Ah10 is offline   Reply With Quote
Old 05-18-2004, 12:14 PM   #11989
Ah10's Avatar
Check your track width, besides 200mm make sure left is the same as right from the center of the chassis. Also check your shock bladders make sure they are in good shape especially your left side.
Old 05-18-2004, 12:25 PM   #11990
alucard13's Avatar
I will check it out. Thanx.
Old 05-18-2004, 12:26 PM   #11991
alucard13's Avatar
Originally posted by Cartman
Slow down
If i was any slower I wouldn't be able to make it around the track before the time ran out
Old 05-18-2004, 02:07 PM   #11992
Varuth's Avatar
Default Tire Truer
Any idea if this Tire True is good?
Varuth is offline   Reply With Quote
Old 05-18-2004, 02:45 PM   #11993
Ah10's Avatar
Default Re: Tire Truer
The GQ one seems pretty nice
A brand new fully automatic tire truer from GQ Products. This is by far the most advanced tire truer available on the market right now and if you compare the price to similar truers out there the price is a bargain!
Technical notes:
Regulated speed for fully automatic tire truing
Adjustable edge sanding
Tire width cutting adjustment
Adjustable diameter (40-80mm)
Truing angle 0 to 2 degrees
Wheels adapters for all 1/10 and 1/8 cars
Titanium nitrite coated cutting tool
Transparent protective cover
Collecting container for ground rubber
Tool/Wrench/Adapter holder
Automatic edge sanding:
This new Edge Sanding Feature enables you to safely true your foam tire edges.
You do not need to find an additional file to true your tire edges.
This makes the whole truing operation much safer.
Adjustable Tire Width to fit all classes tyre width
Adjustable Tire Diameter to fit all classes tyre diameter
Adjustable tire width:
The new Adjustable Tyre Width Feature enables you to easily adjust the width of the cutting area.
You do not have to wait for the time to travel to the end and return.
The new cutting adjustment is controlled by an easy-to-use operating handle.
This makes the whole truing operation much quicker and more flexible.
Old 05-18-2004, 02:56 PM   #11994
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
SQUARE SMR-6 64 Ti Hollow Mid Shaft
SQUARE SMR-17R 64 Ti Hollow 2-Speed Shaft
Originally posted by rattlr2
eddiethefish a couple pages back you posted pictures of shafts and weights. do you have part# for square lightwieght parts?i know they come out of hk but want to make sure ordering right parts just got mtx 3 and wanted to lighten up a little
eddiethefish is offline   Reply With Quote
Old 05-18-2004, 02:59 PM   #11995
Default Re: Re: Tire Truer
This one feature I seem to like most: "Edge Sanding Feature"
NOW, this is what I call "AUTOMATIC".
Technical notes:
Old 05-18-2004, 03:32 PM   #11996
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default G.QTire truer
I think you can get the G.QTire truer at [email protected]
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 05-18-2004, 04:07 PM   #11997
Varuth's Avatar
What about the Integy Automatic one?
Old 05-18-2004, 04:24 PM   #11998
rattlr2's Avatar
thanks eddiethefish for yhe part #
rattlr2 is offline   Reply With Quote
Old 05-18-2004, 05:20 PM   #11999
Send a message via AIM to Profoxcg
1) check you track with
2) Raise your rear roll center...
3) slow down a little, not much
You just have too much tracktion in the rear (cause of the tracktion roll), I would also try a stiffer set of srpings to reduce the roll. I hope this helps
Profoxcg is offline   Reply With Quote
Old 05-18-2004, 05:35 PM   #12000
Derby Bros Racing's Avatar
traction in the rear will not cause traction roll..
tranction in the front does.
traction in the rear causes understeer.
Derby Bros Racing is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
