Old 05-10-2004, 10:07 PM   #11596
gentleman81's Avatar
Default new mtx3
what are the differences in the types of servo saver and the rear end block, they come in a, b, and c types?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 05-10-2004, 10:09 PM   #11597
Jonathan's Avatar
Try 21 27, 59 53.
Seeya!
Jonathan
Team Mugen
Jonathan is offline   Reply With Quote
Old 05-10-2004, 10:09 PM   #11598
Nitropimp's Avatar
DocSafety- No problem. That's what this forum is all about!
Stefan- Man ...thanks for all your advice. Hope you stop by and visit us now and then. I'll give you my avater's number if you don't leave.
Nitropimp is offline   Reply With Quote
Old 05-10-2004, 10:12 PM   #11599
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Re: new mtx3
A Block rear, less traction, B Block medium traction C Block more traction.
The steering rack in the front A Wheels turn more equaly, B wheels have slight amount of ackerman, C has the most ackerman the outside wheel turns less than the inside wheel they say that the C block will give you more turn in, but less on power steering, the oposit goes for the A block.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 05-10-2004, 11:00 PM   #11600
Jonathan's Avatar
Originally posted by Bandeira
During my weekend testing I did have problems with the fine pitch gears...
As for being since 1996 in this hobby, I assume that my gear meshing is preety good...
But last weekend I had lost aprox. 4 second gear(.8 module) spurs in one single day...
What I noticed was that the gear box seemed to shift harder than usually... Any comments?
About the rear Diff... I can't imagine myself using 50k oil or something near that... The harder I used was 15k and I had to be veeeeeeery smooth on the throttle... What's the matter with me ?
Double check your gear mesh by removing your first gear spur and physically inspect the second gear mesh. If that's not it... then there are a lot of other variables. Too much split in your gearing??? Drive train could be binding... and so on. BTW... the method you reveal in setting up your two speed works well in an 1/8th scale but it has a tendency to shift early in sedan unless you crank down on the adjustment screws. It actually makes it more inconsistant. I would revert back the stock setting.
15K is rather lite... if there is any side bite at all, the inside wheel will diff out and cause the car to step out on power... that's why you are having to massage the throttle. So relax...there is
nothing wrong with you. Try the 50k. works well even on medium traction.
One more thing I left out in my post to you yesterday regarding tweak. Check the car for flatness when installing the right radio tray brace. Some time the tightness in the fit will twist the chasiss causing a major tweak inspite of proper droop settings. I trim some material off both ends of this brace to prevent this. Good luck once again.
Seeya!
Jonathan
Team Mugen
Old 05-11-2004, 11:22 AM   #11601
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Shock/Damper Adjuster
Good morning all,
fish is very happy today. No, my wife's not expecting a baby. I'm just happy that it's Tuesday already...
Well, got nothing to do, as always, and thought to share the fun to all of you.
The picture shown below is to compare the difference between the Shock/Damper Adjuster from the Mugen stock and the hop up from SQUARE.
Let's hear all your comment re this.
cheers,
eddiethefish is offline   Reply With Quote
Old 05-11-2004, 12:01 PM   #11602
Varuth's Avatar
Default Re: Shock/Damper Adjuster
Originally posted by eddiethefish
Good morning all,
cheers,
Talking about fine tuen adjustment Wow.....
Varuth is offline   Reply With Quote
Old 05-11-2004, 12:49 PM   #11603
Data's Avatar
go find a job, now !
Data is offline   Reply With Quote
Old 05-11-2004, 12:49 PM   #11604
rjl
rjl's Avatar
Measure the knurled part, the flange is inside the spring and not relevant.
rjl is offline   Reply With Quote
Old 05-11-2004, 12:57 PM   #11605
Varuth's Avatar
Default Re: Re: Shock/Damper Adjuster
Remember, Data. This is his job
Old 05-11-2004, 01:03 PM   #11606
B
Good morning all,
My comment?
I like that Mitutoyo Caliper
B is offline   Reply With Quote
Old 05-11-2004, 01:08 PM   #11607
B,
You surely got good taste...
cheers,
My comment?
Old 05-11-2004, 01:13 PM   #11608
Nitropimp's Avatar
B- you crack me up You spotted the Mitutoyo.
I'm telling you there's some class acts on this forum. You too Eddie.
Old 05-11-2004, 01:20 PM   #11609
raffaelli's Avatar
why would someone consider this a hop up?
raffaelli is offline   Reply With Quote
Old 05-11-2004, 01:23 PM   #11610
There gotta be reasons why they spent time making this out at first. If it ain't do anything, why would spend time on R/D and to have it as final product, marketing, etc.
I also wonder if it ain't gonna be better than those stock one, why bother making one.
getting very intersting, indeed...
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
