Old 12-12-2002, 05:34 AM   #1141
acs
acs's Avatar
is it viable for the steering servo also? or not a good idea.
acs is offline   Reply With Quote
Old 12-12-2002, 05:36 AM   #1142
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by modellor
Zip tying the throttle servo is an old 1:8th scale trick. The ties hold the servo in place without any movement and it allows quicker removal by simply cutting them off.
In fact, this is for anti-vibration. It is not necessary for steering servo as it is far away from the engine.
Manticore is offline   Reply With Quote
Old 12-12-2002, 05:37 AM   #1143
modellor's Avatar
Its not really viable for the steering servo. The servo would be able to tip sideways under the extra loads from the wheels pushing back in the corners.
modellor is offline   Reply With Quote
Old 12-12-2002, 05:38 AM   #1144
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally posted by acs
What are those yellow brake pads? And have you zip-tied your throttle servo in place? why?
Oh, and it looks just like my car.
Looks like Manitcore has already got the Optional Teflon Pads
Mannie, the last 3 years I've known you, this is the most standard car you have had (no hop-ups).
Michael_T is offline   Reply With Quote
Old 12-12-2002, 05:41 AM   #1145
Michael_T's Avatar
Quick question Moon and others:
Does the car come with the digital transponder mount?
Moon - do you have a digital transponder, I couldn't see it in the pics? Where is it mounted?
Old 12-12-2002, 05:43 AM   #1146
acs
acs's Avatar
It comes with the switch mount and the transponder mount. You can't mount both at the same time. (as far as i know)
Old 12-12-2002, 05:49 AM   #1147
acs
acs's Avatar
I see ti screw set, ti turnbuckles, the optional brake pads.
Thats pretty good considering it had not been run at the time of the photo's.
Old 12-12-2002, 05:53 AM   #1148
Michael_T's Avatar
I thought it was too good to be true
Old 12-12-2002, 06:00 AM   #1149
I saw a pic of someone's car that had both the switch and transponder mount in place. The switch was actually upside down, but it worked. Luckily, just about all of our immediate tracks run AMBrC transponders, so I can use my switch.
I have to agree with NR, I think that's the "stockest" car I've seen Mannie own.
Mine is built, but because of the snow I can't even get it broken in. I hate to think I've got to wait until spring to run this thing!!! The only hop-ups I plan to put on are front universals, aluminum chassis brace, and aluminum hex hubs. I'll probably put the teflon pads on as well. I want to see how the stock pads do, but I've put teflon on my MTX-2 and MRX-3. So I figure my MTX-3 will need it also.
Has anyone measured the wheel hexes? Aren't they the same size as the MTX-2 hexes? They look the same to me. It doesn't make sense to me that Mugen would release a set of hexes specifically for the MTX-3 if the MTX-2 hexes would fit.
tekrsq is offline   Reply With Quote
Old 12-12-2002, 06:02 AM   #1150
Manticore's Avatar
the optional teflon pad is the same one used for MTX2.
The car you can see from the pic has alloy hex, TI screws and Ti mid shaft
I had alloy mid bearing block and rear alloy upper deck support installed last night !
Old 12-12-2002, 06:02 AM   #1151
acs
acs's Avatar
Not to mention the aftermarket wheel nuts.
Old 12-12-2002, 06:03 AM   #1152
Manticore's Avatar
I dont race any more so I dont need the mount but the kit does come with the mount for both traditional transponder and digital transponder
Old 12-12-2002, 06:05 AM   #1153
Manticore's Avatar
yep, you remind me, i have the front CVD too.
The MTX2 hex wont fit on MTX3.
Old 12-12-2002, 06:09 AM   #1154
acs
acs's Avatar
Just looking at my car, it seems you are right, by flipping the switch over and placing it above the transponder mount you can use both.
Clever thinking Mugen
Have to buy a switch now.
Old 12-12-2002, 06:10 AM   #1155
Really? What's different, the axle size? I'll have to do some measuring when I get home this afternoon.
I thought about the ti shafts, but 2 people have already told me their ti shafts were "twisting", they went back to the stock shafts. I know of one company that's working on hollow steel shafts; hopefully they'll be a little better. If they are, I'll probably get them.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
