Old 05-06-2004, 06:10 AM   #11401
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Re: Two-speed issues
well said, kreidel.
Originally posted by kreidel
I seriously doubt there is a need for an aftermarket 2speed. The Mugen's 2 speed is great as long as you know how to set it properly.
eddiethefish is offline   Reply With Quote
Old 05-06-2004, 06:12 AM   #11402
Default Re: 2 speed issues
and you expect things to work like new after a year?
Originally posted by VenomWorldOrder
...the car is 1 year old...
Old 05-06-2004, 06:15 AM   #11403
DO NOT spoil the use on thread lock. Had no idea where you got the idea from, perhaps from HPI?
do you recon i have to put thread lock on the small grub screws or will this ruin the shifting mechanism?
Old 05-06-2004, 06:15 AM   #11404
Default at last... MRX-4
Old 05-06-2004, 06:21 AM   #11405
yes, ah10. I have now seen the CAD. Let me know when you need some help.
best,
Old 05-06-2004, 06:34 AM   #11406
alucard13's Avatar
Originally posted by fastfred
Yes, I've set it properly, and repeatedly.
Seems to lose its settings, or only work sporadically.
Cleaned it thoroughly, cleaned the metal cup it fits into, only to get shifts for about a minute, after that, nothing.
Anyone experience anything similar?
Junito: do you have a link? Google didn't get any hits.
m
I have experienced the same thing. Alot of it has to do with what rjl said in regards to the .5mm gap. I noticed that if i tightened or loosened the screws it would not make much difference. But when i got the gap right, then it shifted better and i could use the screws to change the settings. But it took me about 2 tanks to figure it out so i may need to change shoes since the thread may be stripped. I also noticed that if the gap was to large, even by just a little bit it would not fit into the housing. I have noticed that this two speed is very delicate. I am used to the TC3 two speed.
alucard13 is offline   Reply With Quote
Old 05-06-2004, 06:36 AM   #11407
alucard13's Avatar
Speaking of two speeds. My two speed shoes stick out a little bit farther than than housing. they are not completely in the housing. When I installed them they were evenly lined up inside the housing. But after a couple tanks around a local track the shoes are sticking out a little bit. Any ideas?
Old 05-06-2004, 07:30 AM   #11408
rjl
rjl's Avatar
Maybe too much float on the shaft. Use the side belt pulley to reduce the float, you need a little but not too much.
rjl is offline   Reply With Quote
Old 05-06-2004, 08:50 AM   #11409
VenomWorldOrder's Avatar
Originally posted by chookgb
the wear on the metal cam will cause the 2 speed to lock in 2nd as well as shifting problems i had the same problem,i would say it is time for new 2 speed parts and install as per manual no need for loctite
no worries thanks greg. i guess i owe mr mugen dealer, jason in sydney a metal cam also!! sorry jas. put me down for a shoe kit and 2 (two) cams.
VenomWorldOrder is offline   Reply With Quote
Old 05-06-2004, 08:54 AM   #11410
Default Re: at last... MRX-4
Originally posted by eddiethefish
i'd like to say we are sort of looking at the new mtx4 when we see the mrx4........but IT LOOKS LIKE THE MTX3! HEHE
Old 05-06-2004, 01:14 PM   #11411
Varuth's Avatar
Default Re: Re: at last... MRX-4
Wow...MRX4 now!!!! GOOD LUCK FISH. You have a sale to do now
Varuth is offline   Reply With Quote
Old 05-06-2004, 01:17 PM   #11412
[QUOTE]I have experienced the same thing. Alot of it has to do with what rjl said in regards to the .5mm gap. I noticed that if i tightened or loosened the screws it would not make much difference. But when i got the gap right, then it shifted better and i could use the screws to change the settings. But it took me about 2 tanks to figure it out so i may need to change shoes since the thread may be stripped. I also noticed that if the gap was to large, even by just a little bit it would not fit into the housing. I have noticed that this two speed is very delicate. I am used to the TC3 two speed. [QUOTE]
That's funny, many TC3 use Mugan clutch while some Mtx use their 2 speed.
Make sure you have evenly adjust both shoes out from the center to have diameter you want.
rranger is offline   Reply With Quote
Old 05-06-2004, 02:12 PM   #11413
FAST1's Avatar
Thumbs up Re: at last... MRX-4
Look like a MRX3 Pro Spec!!
FAST1 is offline   Reply With Quote
Old 05-06-2004, 02:24 PM   #11414
Couldn't wait to see the MTX-4!
Old 05-06-2004, 02:53 PM   #11415
Don't know if you guys see the pattern.
MTX-2, MTX-2 ProSpec
MTX-3, MTX-3 ProSpec
MRX-3, MRX-3 Works
MRX-4
Thus, those who wish to buy the ProSpec, hold on your bucks to your dearly life, as MTX-4 should come out not too long.
Just my big jumbo mumbo quarters!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
