Old 05-04-2004, 02:48 PM   #11371
ilaybrk's Avatar
I thought laying the shocks down was for A high bite tight track.If not what is.
ilaybrk is offline   Reply With Quote
Old 05-04-2004, 03:44 PM   #11372
Bivens's Avatar
Laying down the front and rear shocks results in a smooth-stable car....regardless of the traction conditions......
More-vertical shocks give a quicker initial response on entry and exit of the corner......(possibly less mid-corner lateral traction). Personally, I like to stand the shocks up on smaller technical tracks.......I can understand that laying them down will give the car a smooth feel on FAST open tracks......
Was this your intent RRanger?
Bivens is offline   Reply With Quote
Old 05-04-2004, 06:21 PM   #11373
Bandeira's Avatar
Send a message via ICQ to Bandeira
Default Gurney
Hi there....
Any of you guys already tried using a Gurney in Touring Bodies?
Any one knows if it is Ifmar Legal do bend a little gurney on the edge of the wing...
cheers...
Bandeira is offline   Reply With Quote
Old 05-04-2004, 06:41 PM   #11374
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Re: Gurney
Originally posted by Bandeira
Hi there....
cheers...
Yes it should be legal in all forms of racing. I have done this on low bite tracks when I needed a little xtra bite. The best thing is if no one looks real close they will never know why you car has more bite than thiers!
Paul.............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 05-04-2004, 08:35 PM   #11375
gentleman81's Avatar
Default got my mtx3 today
construction is underway tomorrow night. cvds will be ordered. any last opinion members?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 05-04-2004, 09:01 PM   #11376
GAMBO94's Avatar
Default Re: Re: Gurney
Paul.............
Hi Guys,,
What is that??? ,i would like to know,i race in a low bite track..Thanks Luis.
GAMBO94 is offline   Reply With Quote
Old 05-04-2004, 09:15 PM   #11377
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Default Re: got my mtx3 today
Take your time
Follow the instructions
Have fun...part of enjoyment is the assembly
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 05-04-2004, 09:24 PM   #11378
Sow&Steady's Avatar
Default MTX3 Prospec
I've posted some info I managed to gather from around the rumour mill about the new MTX3 Prospec at 3Hobby.Com. Read the full article by clicking Read more ...
Now, the question is has anyone bought one of these kits yet? My current MTX3 is almost fully kitted to the same spec except that I ended up paying more for all the stuff!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-04-2004, 09:34 PM   #11379
GAMBO94's Avatar
Default Re: Re: Re: Gurney
Old 05-05-2004, 04:40 AM   #11380
rattlr2's Avatar
what wheels do i need for mtx3 specific wheels or will tc3 wheels work
rattlr2 is offline   Reply With Quote
Old 05-05-2004, 05:24 AM   #11381
mcsquish's Avatar
Default 16/19 conversion
Thanks for the replies, I have already found a good set-up. I was wondering about the 16/19 conversion on the side belt for the wide open tracks. Thank you again though.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 05-05-2004, 07:55 AM   #11382
rjl
rjl's Avatar
The geometry is designed around offset rims.
rjl is offline   Reply With Quote
Old 05-05-2004, 09:32 AM   #11383
Default Re: Re: Re: Re: Gurney
Originally posted by GAMBO94
GAMB049 A gurney flap is a bend in the top of the wing all the way across it, it is usualy a 90deg. bend leaning forward to catch more air and apply more downforce. It was named after Dan Gurney an Indy car racer that came up with the idea, on real cars they have removeable ones made to diferent sizes.
Paul..............................
Old 05-05-2004, 11:44 AM   #11384
Bandeira's Avatar
Paul.............
I'm gonna try it next weekend...
The Ifmar rules say about gruney strips, but not bending a gurney on your wing... I remember it saying that bend-your-own wings were prohibited... Which leaves some doubts about what is considered a Bend-yor-own wing.. If it's a full bend-your-own or if you cant bend any part of it..
The problem in this track I'm racing is that you need plenty of front end grip during cornering but another big problem is to get stability under braking... I've been using the least brake I can set so I can keep my car stable...
Because of that I was thinking on solutions and remembered the gurney...
Any other suggestions to make the car more stable under braking?
cheers...
Old 05-05-2004, 12:58 PM   #11385
Default Stabillity
Bandeira: You could try the teflon brake pads, they are awsome. Also try a spring from a writing pen on your brake rod , instead of fuel tubing, this will give a fade effect to the brakes. Make sure your car is ballanced from left to right, any difference between the two and the car will not brake straight. Also play around with you rear droop setings, you can make the car more or less satable with this seting, also make sure you try to brake in a straight line when possible, untill you get things figured out in your set up.Toe in in the rear will make the car more stable under braking as well as under excelleration. Good luck! Paul......................................
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
