Old 04-30-2004, 12:30 PM   #11266
Varuth's Avatar
Wish anybody who attends Carson Mall race this weekend good luck!!
Varuth is offline   Reply With Quote
Old 04-30-2004, 01:01 PM   #11267
Varuth's Avatar
Anybody knows what throttle punch and throttle curve are?
Old 04-30-2004, 04:01 PM   #11268
gentleman81's Avatar
Default mtx3 or pro spec
i decided to go with the regular mtx 3 kit instead of the pro spec kit, even though the kit is a litmited edition i'm gonna use the extra cash on a kick A$$ engine,
are the nova's being shipped by mugen yet, has anyone seen any prices?
are there any must have or nice to have upgrades for the mtx3?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-30-2004, 04:43 PM   #11269
Default kawahara??
is there a better site for kawahara, by better i mean in english?
thanks
Old 04-30-2004, 04:57 PM   #11270
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: kawahara??
KAWAHARA
thanks
eddiethefish is offline   Reply With Quote
Old 04-30-2004, 04:58 PM   #11271
Default Re: mtx3 or pro spec
Aluminum Hex Nut Wheel Adapter
Old 04-30-2004, 05:23 PM   #11272
Gentleman81: Good choice either way. I already have an kick a$$ engine that I still need to break in
Varuth: Just an guess from an engineer
Throttle punch - instantaneous reaction from the engine on addition of throttle input.
Throttle curve - the overall reaction of the engine throughout the throttle range.
Could be different, noone has used these terms around me before.
darkangel is offline   Reply With Quote
Old 04-30-2004, 07:04 PM   #11273
rjl
rjl's Avatar
If you intend racing, front uni's are good to have, lightened cluth weights are a must. Get yourself the new tank lid, in fact get a couple, it's the only way to get replacement "O" rings without buying a new tank and they deteriorate.
Get yourself 5mm i.d and 3mm i.d. shim sets, more costly but the Kyosho one comes in three thicknesses, you need most of the 5mm shims for correct clutch assembly but also added dust shields for the brake cam and steering post bearings. The rear arms have more end float than they need so fix it during the assembly.
During assembly here are a few things to pay attention to.
( You guys should all add to this with your own experiences)
Do not overtighten the grub screws holding the front lower hinge pin, it will bind if you do.
When installing the brake pins into the chassis make sure the serrations in the pins do not face the brake pad.
Roughen the ends of the pins that support the brake pads and use some cyano to make sure they will not come out of the bulkhead.
rjl is offline   Reply With Quote
Old 04-30-2004, 07:13 PM   #11274
Varuth's Avatar
Aren't they the same thing as Throttle Speed Rate?
Old 04-30-2004, 08:29 PM   #11275
Send a message via AIM to Johnnytc3
does anybody here run the side belt conversion? Does it really work?
Johnnytc3 is offline   Reply With Quote
Old 04-30-2004, 09:32 PM   #11276
Bivens's Avatar
Lightbulb Throttle Punch and Curve
  • Throttle Punch is simply a name for causing the throttle to "jump" through the extreme-low end of the range with the addition of any positive throttle input.....effectively, the use of the throttle punch function causes an immediate jump in servo position from idle to some set value (typically maybe 5% to 10%) to attempt to speed up throttle response of the engine by eliminating the use of very-low throttle positions where the air-flow through the carb throat is too low to effectively function......(this function would be more useful on engines that do not come off of idle well or exhibit poor throttle response)
  • Throttle Curve simply refers to the relationship between the trigger-movement and the servo-travel. A linear relationship means that the "curve" is a direct relationship between the two.....(ex. 50% trigger = 50% throttle servo response). The curve can be altered in many ways by different radio manufacturers....common methods allow exponential curves which will "sensitize" the response on one-end of the servo's travel while de-sensitizing it on the other end. New methods by some manufacturers allow the curve to be treated in multiple linear parts....(ex. -100%=full brake, 0%=idle, 50%=30%, 70%=50%, 100%=full throttle). Different than exponential because the user can change a point on the relationship without affecting the others.
Just another answer from an engineer.....civil
Bivens is offline   Reply With Quote
Old 04-30-2004, 09:46 PM   #11277
mckrooz's Avatar
Send a message via AIM to mckrooz
I run the conversion and noticed that I do save tires with it. The rears don't wear as fast as with the stock pulleys. Like everyone said on here, you gotta true the fronts down.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 04-30-2004, 11:39 PM   #11278
mckrooz, hmm but then what is the point if you have to true down the front? From what im getting here is:
stock belts- wear rear tire faster
conversioin - wear fronts faster
Old 05-01-2004, 12:28 AM   #11279
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
no, nothing to do with tire wear, with the conversion your front wheel is smaller and it is compensate with diffferent front to back ratio by different size pulley. since the front tire has less foam, thinner then you will have much better steering overall. MTX3 stock form already have excellent steering and after the 16/19 conversion then you can gain even more also meaning you can take the car into conor faster. Now if you can take conors faster then that means lower lap time.
Ah10 is offline   Reply With Quote
Old 05-01-2004, 12:32 AM   #11280
rjl
rjl's Avatar
The front is overdriven. You must run smaller fronts to achieve 1:1 ratio.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
