Old 04-24-2004, 09:08 PM   #11086
Send a message via AIM to kreidel
Default Re: novak synthesized reciever
Originally posted by darkangel
hello, I'm thinking about getting a Mtx-3 but I'm not sure my novak reciever will fit in the mugen. Anyone with any experience with this?
You wouldnt buy a car because your receiver might not fit?????
kreidel is offline   Reply With Quote
Old 04-24-2004, 09:10 PM   #11087
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Post SHIFT POINT
It is easier to find shift point if running car in a wide open space than on a tight or restrictive race track...imo
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 04-24-2004, 09:23 PM   #11088
alucard13's Avatar
Originally posted by B
I would try 2.5 turns out, and see what happens.
Do you have the 0.8module? If you do, then it is harder to notice the shift since it is so smooth.
I am not sure about the 0.8 module. i have whatever the kit came with. I am still trying to get used to this car and its parts. i had the ntc3 and was familiar with that. It'll take me a liitle bit to learn alll the new stuff on this car, but so far i'm loving it. thanx for the info.
alucard13 is offline   Reply With Quote
Old 04-24-2004, 09:24 PM   #11089
alucard13's Avatar
Originally posted by racecar850
If car accelerates quickly & engine runs out of rpm quickly....you are stuck in first gear...loosen adjusting screws (equal amounts), then run car again...............
If car is sluggish from standstill and just continues to accelerate....you are probably in second gear...tighten screws (equal amounts)
You should notice gear shift point...it is subtle but noticable
Thanx for the help. I was at a local track today and another guy had an mtx-3 and i could tell when his shifted. I will try the 2.5 turn and see what happens.
Thanx all
Old 04-24-2004, 09:50 PM   #11090
hi guys, I have a question...
what is the difference between how fast and how hard the gear shifts? and how do i adjust the car to shift harder or faster?
thanks
Icung is offline   Reply With Quote
Old 04-24-2004, 10:08 PM   #11091
alucard13's Avatar
thanks
never heard of the car shifting harder. Faster i guess may mean to loosen the screws so that it shifts quicker/sooner.
Old 04-25-2004, 11:17 AM   #11092
Thank you Nitropimp and Racecar850 for your replies
Kreidel: no I wouldn't base my decision solely on a piece of electronic equipment. But thank you for asking
I will most likely will go with the Mugen as I know it better and know where I can get parts easily for it. I'm running the GS Vision Pro right now, but the part supply for my area just dried up.
Thank you for the replies
darkangel is offline   Reply With Quote
Old 04-25-2004, 04:26 PM   #11093
Nitropimp's Avatar
DarkAngel- (Man I loved Jessica Alba in Dark Angel) anyways you can't go wrong with a MTX-3 Awesome car. Also you have THE BEST forum with people that well help with your car. Go stock setup first.
Nitropimp is offline   Reply With Quote
Old 04-25-2004, 04:42 PM   #11094
I can always get several set-ups from the top guys at the track if i don't like the stock.
the darkangel name is from the japanese manga of the same name not the tv show. I think I've only seen the show once.
Old 04-25-2004, 05:33 PM   #11095
rjl
rjl's Avatar
Originally posted by alucard13
For your two speed how many turns do you have? It never said on the instruction. But i know on the TC3 (my last car) it was like 3 1/2 turn from compressed, so thats what i did for this one, but i cannot hear it shift and i'm not sure if its too tight or too loose. any ideas?
On large tracks mine is bottomed, one small tracks out about 1-1.5 turns. Make sure you have a small gap between the shoes, adjusted with the grub screws or else the cam will over rotate and jam in second.
The two speed shift point is determined by your first gear pinion and the power available so is quite variable.
rjl is offline   Reply With Quote
Old 04-25-2004, 07:18 PM   #11096
racecar850's Avatar
These may help out
Mugen MTX-4 :tire:
Old 04-25-2004, 07:27 PM   #11097
racecar850's Avatar
Thumbs up HANDLE MODIFICATION
Mugen MTX-4 :tire:
Old 04-25-2004, 08:59 PM   #11098
GAMBO94's Avatar
Who makes that Handle
GAMBO94 is offline   Reply With Quote
Old 04-25-2004, 09:31 PM   #11099
racecar850's Avatar
Exclamation HOME MADE
A fellow MTX-3 racer made a couple of these, primarily just to try out. The main purpose is for head protection.
Made from 1/8" dia steel, with two alum standoffs attached to chassis.......very simple, anybody should be able to make them. Head protection works...tried it out last Sunday
Here`s another view........
Mugen MTX-4 :tire:
Old 04-25-2004, 09:51 PM   #11100
Nitropimp's Avatar
racecar850- is that a throttle return spring on the left side of the handle??
thanks
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
