Old 04-05-2004, 10:56 AM   #10771
Send a message via ICQ to Cartman
look a few pages back!!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 04-05-2004, 11:01 AM   #10772
Manticore's Avatar
R/C Tech Charter Subscriber
here
Manticore is offline   Reply With Quote
Old 04-05-2004, 12:46 PM   #10773
thanks man
jiggamacdaddy is offline   Reply With Quote
Old 04-05-2004, 03:53 PM   #10774
mckrooz's Avatar
Send a message via AIM to mckrooz
Default Need a little help with this problem
Ok, heres the situation. When under hard acceleration, the front end of the car kinda lifts up and I get wheel hop. This only does it when gunning it after a turn. Particularly after a really slow 180 going into a short straight. My clutch does engage a little hard and I don't know if that's whats making the front end lift a little. I've played with droop and it does it no matter what. Here's my setup:
MTX-3
16/19 conversion
Front droop- 2mm
Rear droop- 5mm
Ride height front - 4.5mm
Rear height - 5.5mm
Rear blocks B/B
Front tires trued - 61mm
Rear tires -64mm
Front sway- flat
Rear sway - Silver bar
mckrooz is offline   Reply With Quote
Old 04-05-2004, 04:05 PM   #10775
alucard13's Avatar
what pipe are you all using?
and i don't mean bong pipe
alucard13 is offline   Reply With Quote
Old 04-05-2004, 04:09 PM   #10776
mckrooz's Avatar
Currently I'm using the Novarossi ART 50220. It's the black low end pipe. I switch between that and the RD Logics pipe.
Old 04-05-2004, 04:18 PM   #10777
Data's Avatar
Default Re: Need a little help with this problem
at which track ? and what gearing were you using ? you got to show me next time if you run at cp.
Data is offline   Reply With Quote
Old 04-05-2004, 04:27 PM   #10778
rjl
rjl's Avatar
Default Re: Re: Re: Traction Rolling
Originally posted by Bandeira
I was running 45 shore all around...
Running very hard tyres may require very large amounts of steering, the large angle of the front wheels can upset the balance of the car. Even on very high traction I would rarely go over 42s. I also use Japanese rubber, I find they wear less and this allows smaller diameter tyres.
rjl is offline   Reply With Quote
Old 04-05-2004, 04:29 PM   #10779
mckrooz's Avatar
I'm using 48/42, 17/22 pinion. I'm running at CP. Have we met before?
Old 04-05-2004, 04:33 PM   #10780
Data's Avatar
Have we met before?
.......... you have my neg. diff for the mtx-3
Old 04-05-2004, 04:35 PM   #10781
mckrooz's Avatar
Ahhh, I will have your present on Sat. Yesterday was the first time I went in about a month. I need more practice!
Old 04-05-2004, 04:35 PM   #10782
Data's Avatar
I'm running at CP.
and does the car hop mostly at the same location ? and which turn is that ?
Old 04-05-2004, 04:36 PM   #10783
alucard13's Avatar
Any specific part or model number?
Old 04-05-2004, 04:36 PM   #10784
Data's Avatar
present for me ? did i piss you off
Old 04-05-2004, 04:37 PM   #10785
mckrooz's Avatar
Yes, it hops at the same spot. The last turn right in front of the drivers stand. Also going into the straight. I don't know if the bumps there, but I can actually see the car lift from that distance.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
