Old 12-10-2002, 08:28 PM   #1036
hurhur's Avatar
Originally posted by rranger
MTX3 is designed to use off set wheels. so all four dogbones are shorter then what you need when using 0 offset wheel. It makes noise, clicks, and pop out etc. To solve the problem,.keep the track width under 197 or insert O rings between dogbone and drive hub or add 1-2mm 6x8 spacer to the one way drive hub, use the spacer of non tubo glow plug do the job, or use MTX-2 's dogbones.
No grease!
One word..INCREDIBLE!
hurhur is offline   Reply With Quote
Old 12-10-2002, 08:29 PM   #1037
Manbik's Avatar
(chant) Ronnie Grease! Ronnie Grease! Oi! Oi! Oi!
Manbik is offline   Reply With Quote
Old 12-10-2002, 08:40 PM   #1038
Manticore's Avatar
R/C Tech Charter Subscriber
Now I know that's a goblin's common sense.
Manticore is offline   Reply With Quote
Old 12-10-2002, 11:50 PM   #1039
Jonathan's Avatar
I could be wrong...but I think the rranger is talking about spacing out the one way out-drive. Could work... except that there is a plastic spacer/seal already in most cars. So, I'm not sure if it'll be a good idea to have a copper gasket rubbing on a plastic spacer.
Anyhow... a question for my sifoo... I'm not interested in the car, but I do want to know your opinion on the new MTX3 rims/tires ??? Are they avail in HK yet. Any finally.... are they comparable in price w/ the old Fast tires? Thanks Moon!!!
Seeya!
Jonathan
Jonathan is offline   Reply With Quote
Old 12-11-2002, 12:16 AM   #1040
Manticore's Avatar
Seeya!
Jonathan
the spacer in that point will reduce the one-way roller coverage on the outdrive shaft unless the outdrive has much longer shaft inside the oneway.
the stock MTX3 tire is also made by GRP and they are 1mm offset. the tire has not yet available here.
Old 12-11-2002, 12:31 AM   #1041
Jonathan's Avatar
Thanks Manticore.
How are the rims? They appear to be a lot stronger than some of the other GRP's. I don't mind the 1mm offset...just more pillow ball "coverage" in the arms. (for my RR) Thanks again.
Seeya!
Jonathan
Old 12-11-2002, 12:37 AM   #1042
Joehwee's Avatar
anybody know what's the shore of those tyres that come with the kit
Joehwee is offline   Reply With Quote
Old 12-11-2002, 12:51 AM   #1043
acs
acs's Avatar
Kit comes with 37 shore front and rear.
acs is offline   Reply With Quote
Old 12-11-2002, 02:29 AM   #1044
Yes, that's exactly what I am talking about, but I don't understand what you mean plastic spacer, the added spacer direct contact the one way bearing with a metal housing, I don't see any plastic parts.
rranger is offline   Reply With Quote
Old 12-11-2002, 02:37 AM   #1045
The oneway out drive shaft is 13 mm long, and the one way bearing is 12 mm, except the housing, you add 2 mm spacer still keep the bearing cover the shaft completely. 'Know your car first' Yes, that's what Hpi telling us.
Old 12-11-2002, 02:41 AM   #1046
sparksy's Avatar
Trader Rating: 14 (94%+)
The V-one R varients have a plastic spacer there.... I still dont think its a good idea.... bronze is soft.... metal is hard... bronze shavings and bearings are bad
sparksy is offline   Reply With Quote
Old 12-11-2002, 03:13 AM   #1047
Manticore's Avatar
in this case, you dont need 7075 chassis at all. a FRP chassis will do the job but not necessary correct.
you do miss HPI forum.
Old 12-11-2002, 03:18 AM   #1048
sparksy's Avatar
I'm thinking of cutting up a piece of lexan to use as an upper deck.... It will be heaps lighter.... it flexes a bit, but I figure if I use 2 it should be ok.... you want me to make you up one Manti?
Old 12-11-2002, 03:23 AM   #1049
modellor's Avatar
2mm Lexan for a Radio Plate. Not bad idea but will it be sturdy enough. I mean the flex will upset both your throttle linkages and the steering linkages and play havoc with the balance of the car.
modellor is offline   Reply With Quote
Old 12-11-2002, 03:29 AM   #1050
sparksy's Avatar
I have the flex under control... I'll glue a few lightened toungue depressors under it
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
