Old 03-05-2004, 07:15 AM   #10396
raffaelli's Avatar
Default Re: Ackerman
Originally posted by Slotmachine
I think the c part gives you increased ackerman and A gives you less.
Just the opposite. Ackerman is the difference in the turning radius of the outside tore compared to the inside tire. Bigger difference = more ackerman.
24ITA
raffaelli is offline   Reply With Quote
Old 03-05-2004, 02:30 PM   #10397
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Here is what I have notice on the steering block
A: sharp initial turning, but start pushing at the middle of the turn
C: intiial turning is not as sharp but a the middle of the turn the car more balance meaning front end doesnt push as bad as block A,
B: is just inbetween the 2.
I am using C now i like it more because I dont have to back off on throttle when I enter sweeper at the end of the straight and yet the car not pushing at all.
Ah10 is offline   Reply With Quote
Old 03-06-2004, 04:59 PM   #10398
I need help. The E-clips holding the 1st gear (47T) keeps coming off everytime I increase throttle. Its the 3rd time already. I always use new clips from mugen. what am I suppose to do? are there any alternative clips? Also my front diff is still leaking and I already use 2 gaskets.
penggoy is offline   Reply With Quote
Old 03-06-2004, 07:00 PM   #10399
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
My diff did the same thing, so i just put a one-way in it, i won't go back. As far as the e-clips i found the my 2-speed shaft was a litttle smaller in diameter than i was suppose to be. I purchased the hollow one and the mugen clips work great
mtx3racer is offline   Reply With Quote
Old 03-06-2004, 07:10 PM   #10400
B
Put a bit of silicone to insure best seal
B is online now   Reply With Quote
Old 03-06-2004, 08:13 PM   #10401
raffaelli's Avatar
Anyone use TRC tires? I am going to try them in the morning and wondered what I am in for.
Thanks!
24ITA
Old 03-06-2004, 08:57 PM   #10402
Manticore's Avatar
a little tips on e-clips tho it might not help in your situation.
the e-clip has one side with smooth edge and the other side has sharp edge. use the smooth edge side towards inside this will reduce the chance of the clip flying off.
Manticore is offline   Reply With Quote
Old 03-06-2004, 09:22 PM   #10403
stefan's Avatar
Send a message via AIM to stefan
Thanks!
They are the same tires as Mugen Fast, Ellegi, Power, etc.
All made by GRP.
stefan is offline   Reply With Quote
Old 03-06-2004, 09:33 PM   #10404
raffaelli's Avatar
I didn't know that. I thought they were something other than GRP. But after reading your post I saw the GRP on the box.
Thanks!
24ITA
Old 03-07-2004, 07:11 PM   #10405
RClover's Avatar
perhaps the e-clip didnt click onto the shaft grove.
each time when i fix that clip, a 'click' sound can be heard making sure it sits tight on the grove. and i also adopt Manti's trick i.e. to make sure the sharp edge of clip facing outward while the rounder edge facing the inner..
many fittings been done and no problem so far.
RClover is offline   Reply With Quote
Old 03-07-2004, 10:05 PM   #10406
Manticore's Avatar
reseat the pulleys also helps by removing stress on the e-clip.
Old 03-07-2004, 11:13 PM   #10407
Ed Delgado's Avatar
Default MTX3 Victorious in @ Hour Enduro @ Royal Palm Raceway in Miami, Fl
I love this car! Two hours without a problem.
Thanks to my co-driver Hector Garcia and pitman Juan Sat and sponsor Warrick Custom Hobbies.
Photo by Jarrod Pilone
Ed Delgado is offline   Reply With Quote
Old 03-08-2004, 03:16 AM   #10408
RClover's Avatar
yea..it is of vital importance to ensure that the shaft protrudes sufficiently out from the spur where the grove can be seen to fit the clip.
recheck that the 16T main shaft pulley was installed properly that leaving no gap between the shaft pin and 16T pulley. Push the shaft towards inner while cross-checking the rear bulkhead (which holds the main shaft) is aligned properly. Then, try fitting the spurs and see if it solves your problem.
Old 03-08-2004, 03:18 AM   #10409
RClover's Avatar
Default Re: MTX3 Victorious in @ Hour Enduro @ Royal Palm Raceway in Miami, Fl
hey...nice ride!
Old 03-08-2004, 09:45 AM   #10410
raffaelli's Avatar
What are the general rules of thumb for when to use front gear diff and when to use the front one way?
24ITA
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
