Old 02-25-2004, 10:58 PM   #10306
vones's Avatar
Originally posted by fuse01
what does the A block does ?in the rear... in simple terms please.
i'm on 42 shore all round and still flip, using the new darker blue springs and the harder new rear sway bars as well.
ride height abt 3mm front and back... front roll bar at 60degree
still flip ergggggg .... maybe a softer spring to counter the effect?
or maybe raise the shocks to vertical to have less side bite?
set ur frnt roll bar 90 deg.....wats ur droop frnt n rear..?
vones is offline   Reply With Quote
Old 02-25-2004, 11:01 PM   #10307
RClover's Avatar
Default Re: tires
Originally posted by Slotmachine
I really like these, Im sure they are GRP rubber
these GQ tyres are made in Taiwan, foam quality is a real issue..
RClover is offline   Reply With Quote
Old 02-25-2004, 11:03 PM   #10308
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: tires
stop bad mouth GQ !! some body will slap on you punk !
Manticore is offline   Reply With Quote
Old 02-25-2004, 11:04 PM   #10309
stock setup
if not wrong 2 front 6 rear
fuse01 is offline   Reply With Quote
Old 02-25-2004, 11:05 PM   #10310
RClover's Avatar
how about putting more camber angle all round will help the roll?
Old 02-25-2004, 11:05 PM   #10311
Manticore's Avatar
stock setup
reduce rear droop does help. also stand up rear shock also helps a bit
Old 02-25-2004, 11:07 PM   #10312
RClover's Avatar
Default Re: Re: Re: tires
opps...sorree sir!
Old 02-25-2004, 11:56 PM   #10313
veecee's Avatar
Trader Rating: 34 (100%+)
Default building...
Guys, I don't have a setup board but I'm keen to start bulding. Any ballpark numbers on the pivot ball assemblies? Thx.
veecee is offline   Reply With Quote
Old 02-26-2004, 02:02 AM   #10314
Slotmachine's Avatar
Send a message via MSN to Slotmachine
sERPENT u.k Now uses these tires, they are notTaiwan foam they are Jasenese Foam same as H.P.I. from what I hear
The a roll center position will give you less rear side bite!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-26-2004, 03:59 AM   #10315
Taylor-Racing's Avatar
I suspect you're right - Japanese foam, but would like to know for sure.
We use Active tyres and these have exactly the same rims, only yellow.
Taylor-Racing is offline   Reply With Quote
Old 02-26-2004, 06:52 AM   #10316
rjl
rjl's Avatar
If your rolling on corner entry reduce rear droop and slow down a bit, if rolling on exit reduce front droop and take it easier on the throttle.
rjl is offline   Reply With Quote
Old 02-26-2004, 08:10 PM   #10317
mckrooz's Avatar
Send a message via AIM to mckrooz
Default Re: building...
Do you have calipers? I can give you the gap between the arm and hub. I'd have to measure when I get home.
mckrooz is offline   Reply With Quote
Old 02-27-2004, 05:45 AM   #10318
Default Fort Myers
Is there any link for the Fort Myers Track were the Winter nats took place? I would like see pics of that track.
czotalis is offline   Reply With Quote
Old 02-27-2004, 06:12 AM   #10319
JCB
JCB's Avatar
www.winternats.com
JCB is offline   Reply With Quote
Old 02-27-2004, 08:49 AM   #10320
cyba888's Avatar
Try stiffer springs and make sure your front suspension toes out also. When its toe in it will tend to flip more. I had the same problem as well. You might want to check your front tire diameter is not too small compared to the rears. I think stiffer springs will have less bite. Try that first, then play around with the suspension angles. Good Luck
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
