Old 02-25-2004, 05:43 PM   #10291
Send a message via AIM to kreidel
Stiffer springs, harder shore foams
kreidel is offline   Reply With Quote
Old 02-25-2004, 05:53 PM   #10292
stefan's Avatar
Send a message via AIM to stefan
Front swaybar vertical,
rear bar as stiff as possible,
superglue on the tire sidewalls,
smaller tires
car as low as possible
stefan is offline   Reply With Quote
Old 02-25-2004, 06:13 PM   #10293
vones's Avatar
Originally posted by fuse01
we have a new local track and everycar there traction rolls...
any idea how to cure it?
roll during cornering on power and off power..
setup is stock.
or you can go round slower.....you too fast already....... try using 45-42 sh for frnt n rear....Tom was using 45sh...but the traction varies frm day n night....n it is worse on weekends. I was using 42sh frnt n rear for my evo leslie was using 37sh for the past 2 days. also can play. use frnt 1-way it is much better.
vones is offline   Reply With Quote
Old 02-25-2004, 06:22 PM   #10294
Manticore's Avatar
R/C Tech Charter Subscriber
setup is stock.
use a front gear diff and you may use harder brake to quickly slow down your car before a corner.
Manticore is offline   Reply With Quote
Old 02-25-2004, 06:30 PM   #10295
sbmon's Avatar
manticore
where can I find that kai option stuff for sale on the net
I like the upper deck
sbmon is offline   Reply With Quote
Old 02-25-2004, 06:33 PM   #10296
Manticore's Avatar
Originally posted by sbmon
manticore
i dont think you can but i might be wrong. actually shops in Hk doesnt import their stuff. it could be the price issue.
Old 02-25-2004, 06:54 PM   #10297
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Traction roll
First make sure the car is 200mm rear and 198/199mm front
Max. height 6mm
go to a stiffer oil all around
use the new progressive blue springs all around
as said before, smaller tires ( diamiter)
The team Mugen guys say that they never run harder than 37 shore all around , and useing the front diff under any condition will be slower than the one way.If your car is set up propperly you will be able to use the brakes Hard!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-25-2004, 07:00 PM   #10298
sbmon's Avatar
never run harder than 37 shores?
I think conditions at the track should be the deciding
factor for tire choice. Just look at the set up for the winner
of the winter nats.
Old 02-25-2004, 07:03 PM   #10299
Manticore's Avatar
of the winter nats.
is he a team mugen driver?
there are a lot of things that team driver does while you dont.
same token, the champ use this or that and this doesnt mean you will win if you use this and that.
Old 02-25-2004, 07:09 PM   #10300
Manticore's Avatar
there is one fastest way to overcome traction roll,
"SMALL TIRE" with this, you dont need front diff, you dont need brake and you are fast.
Old 02-25-2004, 08:35 PM   #10301
chippy's Avatar
setup is stock.
Stiffer springs, sway bar, harder compound tyres
And use the rear A roll centre blocks
chippy is offline   Reply With Quote
Old 02-25-2004, 10:43 PM   #10302
V-1-R's Avatar
how do i determine if i get traction roll?
kindly explain, thank you.
V-1-R is offline   Reply With Quote
Old 02-25-2004, 10:45 PM   #10303
B
when your car flips over and crashes into a wall due to the high traction
B is offline   Reply With Quote
Old 02-25-2004, 10:52 PM   #10304
what does the A block does ?in the rear... in simple terms please.
i'm on 42 shore all round and still flip, using the new darker blue springs and the harder new rear sway bars as well.
ride height abt 3mm front and back... front roll bar at 60degree
still flip ergggggg .... maybe a softer spring to counter the effect?
or maybe raise the shocks to vertical to have less side bite?
fuse01 is offline   Reply With Quote
Old 02-25-2004, 10:55 PM   #10305
V-1-R's Avatar
i see!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
