Old 02-04-2004, 09:01 PM   #9976
highwayman's Avatar
Originally posted by Corse-R
On 0.8 gearing there are available:
- 1st gear 20 - 23T
- 2nd gear 25 - 29T
- 1st spurs 60 - 58T
- 2nd spurs 54 - 52T
Almost stock gearing on 0.8 module is 20/26 with 59/54T If not remember bad.
is there an advantage in using the .8 module? is it like using 64pitch gears in EP cars, more efficiency? or is it to adjust the final drive ratios more closely?
highwayman is offline   Reply With Quote
Old 02-04-2004, 09:13 PM   #9977
speedydave's Avatar
Send a message via AIM to speedydave Send a message via Yahoo to speedydave
Has anyone here run rubber tires on their MTX3? I know the MTX3 comes with foamies, and it's probably designed with using foamies in mind, but (other than the normal differences between foam and rubber) would there be any negative side effects to running rubbers on the MTX3? Thanks.
speedydave is offline   Reply With Quote
Old 02-04-2004, 10:12 PM   #9978
B
Originally posted by Manticore
have you put on the gasket?
with just silicone, the gasket can be omitted!
well, tat least that works for me!
B is offline   Reply With Quote
Old 02-04-2004, 10:25 PM   #9979
Trader Rating: 37 (100%+)
speedydave, there is no problem running rubber tires on the mtx3. you should remove the front one way and install a front diff. a good starting point is 20 to 30k diff oil in front and 5 to 7k in rear. also, go with softer springs front and rear. i followed associated's rubber setup for the ntc3. copper front and gold rear.
Buggy Master is offline   Reply With Quote
Old 02-05-2004, 02:30 AM   #9980
Vinyard's Avatar
Originally posted by TOMJR
hi guys where can i get the 16/19t side pulley conversion + the belt....which brand do the conversion...btw i am staying in singapore...does 3racing have the stuff ?
the conversion is only swapping of some pulleys..
the only thing you need to get is an extra 16t or 19t side pulley
(cant remember which) and a side belt.. the stock dun fit.
fuse01 where's the belt you got from corse-r?
Vinyard is offline   Reply With Quote
Old 02-05-2004, 04:42 AM   #9981
EVOLUTION's Avatar
Originally posted by Vinyard
the only thing you need to get is an extra 16t or 19t side pulley (cant remember which) and a side belt.. the stock dun fit.
EVOLUTION is offline   Reply With Quote
Old 02-05-2004, 05:50 AM   #9982
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by EVOLUTION
what?
Manticore is offline   Reply With Quote
Old 02-05-2004, 06:14 AM   #9983
VenomWorldOrder's Avatar
i found that the power band seems to be smoother, and my top end was higher.
VenomWorldOrder is offline   Reply With Quote
Old 02-05-2004, 07:38 AM   #9984
Francis M.'s Avatar
it is exactly like running a 64pitch in ep.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-05-2004, 08:41 AM   #9985
those belts never came.. must have lost in the mail...
anyway i have forgotton about it also..
never mind la..
it was like 6 months ago and i have shifted house as well.
fuse01 is offline   Reply With Quote
Old 02-05-2004, 11:33 AM   #9986
Default Setup
I have a question.
When reading from a setup sheet that you need 3 degrees of toe in does this mean you need 3 degrees on each side? Or a total of 3 degrees (1.5 on each side)?
czotalis is offline   Reply With Quote
Old 02-05-2004, 01:16 PM   #9987
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
mtx3racer is offline   Reply With Quote
Old 02-05-2004, 07:30 PM   #9988
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
For as many people that were playing the penguin game on here earlier, I thought SOMEONE would like my picture... guess not. - haha
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-05-2004, 07:57 PM   #9989
Registered User
junito yukiyu's Avatar
Send a message via MSN to junito yukiyu
droop , what setting do you guys use??
junito yukiyu is offline   Reply With Quote
Old 02-05-2004, 08:11 PM   #9990
Roger's Avatar
2 up front , 6 in the back
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
