Old 01-29-2004, 10:49 AM   #9916
Manticore's Avatar
R/C Tech Charter Subscriber
the adaptor
Manticore is offline   Reply With Quote
Old 01-29-2004, 07:01 PM   #9917
sir
the adaptor is for rear only ? or can be use in the front as well?
what is the kawahara part number?
thanks
fuse01 is offline   Reply With Quote
Old 01-29-2004, 07:05 PM   #9918
Manticore's Avatar
Originally posted by fuse01
sir
thanks
this adaptor can be fitted to both front and rear diff. I dont have that part number
I do have both front/rear solid axle using this adaptor with me but i have never used them.
Old 01-29-2004, 07:30 PM   #9919
you have PM
Old 01-29-2004, 07:42 PM   #9920
Manticore's Avatar
you have PM
you have pm 2 !
Old 01-29-2004, 09:52 PM   #9921
mckrooz's Avatar
Send a message via AIM to mckrooz
Originally posted by Manticore
the 16/19T pulley conversion is referring to the side pulley with the long belt. stock pulley there is front:24T and rear 19T
what you need to do the conversion is get an extra 16T pulley, put the rear 19T to the front and affix the extra 16T to the rear. and at last you need a shorter side belt. kawahara carries the shorter long belt for this conversion and there is someone on this forum selling the shorter long belt.
i tried the alloy pulley and i dont like them as they wear too fast. stick with the plastic pulleys.
with the 16/19 conversion, you may use smaller tire in the front which is the purpose of the 16/19 pulley conversion.
why you need to shaved your steering linkage and deburred the diff case?
So with this conversion, do you HAVE to true the front tires down to get the full benefit?
mckrooz is offline   Reply With Quote
Old 01-29-2004, 09:54 PM   #9922
Manticore's Avatar
yes, 4mm smaller in the front
Old 01-29-2004, 10:11 PM   #9923
sbmon's Avatar
and dont forget that when running a smaller tire on the front you will have to adjust your droop accordingly
sbmon is offline   Reply With Quote
Old 01-29-2004, 11:49 PM   #9924
theRED5's Avatar
As I understand this, because of the way the MTx3 wears the rears so much more than the fronts, the handling will go away, at least it did on my car. So "they" came up with this fix, so to speak. When running the 16/19 change, you run the fronts 4mm smaller than the rears, and at the end of a 30-45 min main the car still handles as well as it does at the start of the race. Because the tires are almost even after 30 min, at my track.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 01-30-2004, 09:06 AM   #9925
sbmon's Avatar
That is my understanding too red5
but I have not yet tried this belt and pulley configuration
my question though to those that have experience with this
gearing/belt configurationi s this If you begin the 30 minute main
with front tires 4 mm smaller, then you say the tires wear evenly that means that when you finish the main the front tires will still be 4mm smaller than the rear tires right(because this would have to be the case for consistent handling. Is my thinking correct here?
Old 01-30-2004, 09:41 AM   #9926
stefan's Avatar
Send a message via AIM to stefan
I usually start with a 3.5 mm split and after 30 minutes still have a 3 mm split.
The car handles much more consistent during the entire main.
We have a guy at the track who runs the belt conversion w/o any split, he says he likes the overdrive.
He's fast, but I think this is putting tons of strain on the drive train.
stefan is offline   Reply With Quote
Old 01-30-2004, 12:26 PM   #9927
2Fast4U2's Avatar
I have never heard of this problem. I have run My mtx3 in numerous 30 min mains. I have never noticed a significant difference in the way the car handle in the first 5 min to the last 5 min. I look at my lap times. they don't vary much. if i was running a 11:9's at first 5 min. I still can run 11:9's in last 5 min.
who makes this conversion piece?
2Fast4U2 is offline   Reply With Quote
Old 01-30-2004, 12:28 PM   #9928
B
no one makes them
you make it yourself
all you buy is the different belt to work with the pullies, thats all
B is offline   Reply With Quote
Old 01-30-2004, 12:39 PM   #9929
2Fast4U2's Avatar
That is all I needed to know. Mine drives fine.
Old 01-30-2004, 04:13 PM   #9930
theRED5's Avatar
I run softer rear tires with harder springs and found that the rears would be smaller than the fronts at the end. That's why I changed to it.
You may be compensating for the difference thru the race without noticing the handling difference. If not leave it off, you don't need the change.
I like running the conversion.
Mugen MRx4
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
