Old 01-16-2004, 01:16 AM   #9676
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by dino.tw
still can't login MSN.....
By the way,there is my new 2004 painting...
it looks like it is a mutated bird !
Manticore is offline   Reply With Quote
Old 01-16-2004, 12:54 PM   #9677
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Hey Guys!
I can smell the nitro of summer coming, only 3 more months...
I've been working on the mtx-3 a little bit lately, prepping it for summer, but it's come time to replace that CVD that I FUBAR'ed a while back. Question is:
Mugen or RDLogics CVD? RDLogics is $10 cheaper, and I havent heard anything about them, so let the beans spill!
btw: remember this: http://www.rctech.net/forum/attachme...?postid=439261 hehehehe..
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 01-16-2004, 05:13 PM   #9678
Corse-R's Avatar
Mugen definitely! Broke in the past the 3 Racing ones and visually the RD Logic ones seemed the same (or almost the same). Put the Mugen ones and magically all mine problems snapping CVD's were gone.
Now, under many many many litres of fuel under their belts, bought a shaft replacement for them but after a careful inspection and teardown, the spares keep on their bag and the originals were reassembled, probably after Winternats or more after will change. Mugen ones are cheap on the long term.
BTW: How about a warm-up on the Winternats? there are still locations and we plan to do a rctech fest (hehehe.... wouldn't mind to do some races on a hotel corridor? )
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-16-2004, 05:24 PM   #9679
RCTech Member #2
TSR6's Avatar
haha, alright, Mugen it is.. I knew to stay away from 3Racing's CVD's, but hadn't heard anything about RD's.
I wish I was going to the Winternats, and I probably would if it weren't for school. I may do some traveling this summer though if I can get my nitro sedan as rockin as my electric sedan. I was looking at the Airtronic's race, because our campus is on spring break during that period, but I would need to be back the day after the race. I'm not sure if that is feasable.
Troy
RCTech Member #2
Old 01-16-2004, 06:05 PM   #9680
Manticore's Avatar
Hey Guys!
i dont have this problem even with a couple of hard crashes. I wonder if you have set the servo saver tension too loose and when there is a crash, the steering knuckle will be in full steering position and until the CVD joint breaks.
Old 01-16-2004, 06:16 PM   #9681
Manticore's Avatar
the good side of the 3racing CVD is very cheap and the outdrive pin is very hard to wear. and the bad side of 3racing CVD is that the joint pin is thinner then the mugen one and it will break after extneisve use.
Old 01-16-2004, 06:32 PM   #9682
RCTech Member #2
TSR6's Avatar
Nah, I caught the sweeper, ripped the whole wheel off, CVD parts and all.
Troy
RCTech Member #2
Old 01-16-2004, 06:35 PM   #9683
Manticore's Avatar
why you caught the sweeper?
I do think the CVD broke before the wheel detached.
Old 01-16-2004, 06:39 PM   #9684
RCTech Member #2
TSR6's Avatar
I kept getting more and more confident for how deep and hard I could drive into the corner without washing out, out steering other cars with the one-way ( they all run spools, or diffs ) ... and WHAM, took it too deep one lap.
teeeheee... I said deep and hard..... teeeheeee
Troy
RCTech Member #2
Old 01-16-2004, 06:44 PM   #9685
Manticore's Avatar
you will definitely go faster with a front oneway axle. we do run the oneway at our medium and tight track.
Old 01-16-2004, 06:49 PM   #9686
RCTech Member #2
TSR6's Avatar
They all say that you can't dive in as deep, but I was doing just that -- Holding it open longer, then braking into the corner. Go figure..
Troy
RCTech Member #2
Old 01-16-2004, 07:08 PM   #9687
Manticore's Avatar
or they are not running MTX3 !
Old 01-17-2004, 05:11 AM   #9688
Originally posted by Cartman
why not buy a kawahara one?
kawahara is like $50 on ace hardware hobbies. but I think k factory is cheaper, isnt it?
Is it worth the money? Or should I stay with the stock rear stabilizer?
penggoy is offline   Reply With Quote
Old 01-17-2004, 06:46 AM   #9689
For you guys running the 0.8 module gears, what kind of spread can you use without bogging the engine when it shifts? I just bought some to try this year and not sure what the limits are. I can't get out yet to test (WAAAAAAAAY to cold!!!!).
tekrsq is offline   Reply With Quote
Old 01-17-2004, 07:05 AM   #9690
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
well, i bought a set w/ an 8th tooth spread on the spurs. Its was way to much. So i went up to a 54t. on 2nd and 60t. on 1st. It worked ok, but personally i don't like the 0.8 gears because they always strip. I crank down on all of the screws, but they still manage to get out of alignment. I have never had the problem w/ reg. gearing. I would forget about the 0.8 gears(how long is the straight at the track you run at?) unless the straight away is like more than 200ft.
mtx3racer is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
