Old 12-04-2002, 03:35 AM   #901
acs
acs's Avatar
Originally posted by hooked_on
Yes Keith Mackrel, He is Mr Yokomo since buying your old electric. I tried to convert him to associated, but to no avail.
I guess he knows a good deal when he see's one.
There will still be one Yok gp car there.
acs is offline   Reply With Quote
Old 12-04-2002, 03:37 AM   #902
acs
acs's Avatar
rjl,
did you put the Rossi in your "3" car?
It looked like it would be a tight fit.
Old 12-04-2002, 03:42 AM   #903
rjl
rjl's Avatar
Originally posted by SHARP
Is the clutch the same as supplied mith mtx2 prospec? The mtx2 manual says nothing about shims on the inside of the clutch bell. The motor cannot provide drive until the bell is pushed out against the thrust bearing can it?
Is there any reasons you would want more or less slop in clutch bell?
All info appreciated!
The assembly and shimming of this clutch is the same as every "power clutch" I have encountered. It pays to shim internally so that the inside 5x10 clutch bearing stays within the bell and can't slide up and down the motor shaft.
Varying the endplay on an adjustable clutch can assist in power delivery but it is personal and depends on your driving style.
rjl is offline   Reply With Quote
Old 12-04-2002, 03:46 AM   #904
rjl
rjl's Avatar
Originally posted by acs
rjl,
I'm running the new PIXI, my engine is a bit shorter than yours, got it to ninth at the Nats and only 2 weeks old at the time.
Old 12-04-2002, 09:24 AM   #905
ilaybrk's Avatar
when i tried to put a pixi in my friends tc3 the header melted the fuel exit port on the tank is that what you mean shorter or do you mean the new 5 port pixi
ilaybrk is offline   Reply With Quote
Old 12-04-2002, 10:04 AM   #906
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
Can someone post a picture of the Pixi engine never seen one before thanx.
ROBBIE C is offline   Reply With Quote
Old 12-04-2002, 10:18 AM   #907
modellor's Avatar
modellor is offline   Reply With Quote
Old 12-04-2002, 10:35 AM   #908
ROBBIE C's Avatar
Wow very nice looks like a serio motor.
Old 12-04-2002, 10:39 AM   #909
ROBBIE C's Avatar
Is this the motor of choice where you live?
Old 12-04-2002, 11:00 AM   #910
ilaybrk's Avatar
hey robby nobody runs a pixi at crystal park
Old 12-04-2002, 11:26 AM   #911
YBSLOW's Avatar
Default TFT Race!
Waz up Robbie! See ya next week at TFT. Now get back to work.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 12-04-2002, 11:33 AM   #912
Thanks for the help with the clutch everyone!! my car is set for its first run finally. unfortunately im back at boarding school so it will be another 15 days till i do get to drive it
by the way, im not the only one who has ever had these problems with rims not coming off the axle! Robbie tells me that he has done it, and it is due to the axle actually threading into the wheel, then when the wheel is on, u cannot screw it off!!! well, with some heat, and tugging, and a little frustration, the wheels are off, and drilled sust a little wider so the go on, and come off!!!
Nytrochaos is offline   Reply With Quote
Old 12-04-2002, 12:03 PM   #913
Send a message via ICQ to Cartman
the clutch is the same only the flywheel has changed.
there is no mention of the shims in the inside, this is a racers trick in certain conditions the clutch bell can be pushed into the shoe at idle causing an engine cut, adding spacers makes it so when you push the bell to the engine it does not drag.
Why do you want end float and how much??
basically its a tunning aid, more clearane will cause the clutch to engage harsh, less clearence will give a smoother engagment.
for best info go here
http://www.rctek.com/info_centax_clutch.html
As for changing the width, so you never ran your mtx 2 narrow or wider for differant tracks? or the Kawahara rear end, 2mm at the most wont make that much change especially with mtx spacers
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 12-04-2002, 08:22 PM   #914
hurhur's Avatar
a simple solution to your problem: ream the fresh rims's axle opening a little such that you can extract and mount the rims into the axle with ease.
hurhur is offline   Reply With Quote
Old 12-05-2002, 01:45 AM   #915
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
I noticed Mugen USA has moved to a new building, does anyone have the new phone number for customer service or address of the new building?
Thanks!
Dan is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
