Old 12-03-2002, 08:54 PM   #886
10,000wt diff oil is stock
Nytrochaos is offline   Reply With Quote
Old 12-03-2002, 09:13 PM   #887
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Novarossi
Tommy just came back from Europe Got so many goodies Has the MTX-3 tempted you enough yet? I heard it was awesome at Moorebank
Moon, those alloy hex adaptors you have posted, are they Kawahara?
What the standard diff oil the car comes with - 30,000wt?
It is proposed products from kawahara.
Manticore is offline   Reply With Quote
Old 12-03-2002, 09:55 PM   #888
hurhur's Avatar
you can fit the Mugen purple ones onto the MTX3 too if you are not going to wait for the kawa ones.
hurhur is offline   Reply With Quote
Old 12-04-2002, 12:21 AM   #889
ilaybrk's Avatar
they rub on race of bearing causing friction
ilaybrk is offline   Reply With Quote
Old 12-04-2002, 12:54 AM   #890
hurhur's Avatar
they have a spacer for the hubs in the pro spec version.
Old 12-04-2002, 02:00 AM   #891
Originally posted by rjl
O.K. The clutch bell should spin freely on the shaft. You will need more shims than are supplied to do it properly.
Use the tapered collet from the kit not the one from the engine, I use the smallest amount of threadlock on the motor shaft thread but that is up to u. Once the shoes are fitted, place the bell on the shaft with the 5x10 bearings in place. If the bell rubs on the clutch use enough shims to prevent the bell contacting the shoe, you should not be able to turn the motor over when you push the bell in and rotate it, this sets the clearance on the inside.
Now the end float has to be set, with the thrust bearing in place on the collared shaft trial fit and test the end play, use shims until the clearance is about .3mm.
rjl
Is the clutch the same as supplied mith mtx2 prospec? The mtx2 manual says nothing about shims on the inside of the clutch bell. The motor cannot provide drive until the bell is pushed out against the thrust bearing can it?
Is there any reasons you would want more or less slop in clutch bell?
All info appreciated!
SHARP is offline   Reply With Quote
Old 12-04-2002, 02:47 AM   #892
hooked_on's Avatar
I would still like to hear reports from people who have driven them what they think and some more pictures? I am a interested Associated driver that might be keen to jump camp if the reports are good?
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 12-04-2002, 03:05 AM   #893
acs
acs's Avatar
hooked_on
come out to Brendale on friday night and see them race first hand.
There should be at least three of them.
acs is offline   Reply With Quote
Old 12-04-2002, 03:08 AM   #894
hooked_on's Avatar
ACS:
Have you also changed camp from Yokomo? I know Jeff Knib, Karl Lee & Wade have them?
I might just have to come out? Is this the last meet for this year?
Old 12-04-2002, 03:14 AM   #895
acs
acs's Avatar
Originally posted by hooked_on
ACS:
Yes I have moved camps. And I am very impressed so far. Also changed motor brands.
We are going to run every friday night till the start of next year.
(I think)
Pro Tourers
Gas Tourers
Electric Tourers - Mod & Stock.
Old 12-04-2002, 03:18 AM   #896
hooked_on's Avatar
acs:
Keith would not be happy with your switch? Anyway what motor are you running and i will indeed make the trip and come out and watch. what time do you start?
Old 12-04-2002, 03:23 AM   #897
acs
acs's Avatar
acs:
I got tired of the old cars issues. Do you mean Kieth Mackrel? If so he's a Kyosho man anyway.
I put a new Novarossi S3 in the new MTX-3. A perfect match.
Racing starts around 6:00.
Remeber to bring your car and race.
Old 12-04-2002, 03:28 AM   #898
hooked_on's Avatar
Yes Keith Mackrel, He is Mr Yokomo since buying your old electric. I tried to convert him to associated, but to no avail.
Old 12-04-2002, 03:30 AM   #899
rjl
rjl's Avatar
Originally posted by tweakster
Does eveyone feel that the internal gear ratio has helped the overall speed performance or is it the motor. How are the tyres wearing compared to the mtx-2. I noticed from some earlier posts that the car works good with softer tyres, but are they wearing faster and are they coning.
The gearing options for this car are more than most mortals can cope with. It is suitable for a wide variety of tracks. Enough about gearing O.K.
rjl is offline   Reply With Quote
Old 12-04-2002, 03:33 AM   #900
rjl
rjl's Avatar
Has anyone been able to achieve 200mm width with the car using 0mm offset wheels?
Has anyone tried spacers or other modifications which would allow 0mm rims to be used (and achieve 200mm)
Can the hubs be adjusted far enough out to increase the width?
The geometry of this car is designed around 2mm offset rims, vary this to your detriment.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
