Mugen MTX-3
#8791
servo saver?
when building the mtx3 servo saver there are 3 options for T0304A,T0304B, and T0304C, which is the stock/commonly used part. Looks like there is a slight difference in length of the parts what are these options for?(bump steer?) and what do you all use?
Thankyou
sb
Thankyou
sb
#8792
Re: servo saver?
Thankyou
sb
Thankyou
sb
#8793
Originally posted by CutePig
It seems that I really live in the R/C paradise.....
The limited edition mtx3 has....
1)4mm chassis
2)4mm engine mount
3)pair CVD in front
only about $30 more than the STD edition.
I don't think it's limited edition.It's PLUS+ edition.Get it?
1)4mm chassis
2)4mm engine mount
3)pair CVD in front
#8794
tianci
ah ackerman thankyou
#8795
Re: tianci
#8796
Re: Re: mtx-3 solid front setup
Originally posted by tIANcI
For rubbers usually its about all the same but your camber is only 1 degree front and 2 degrees back. I think try to keep the back droop less so there is less weight transferred to the front upon braking. You will slide less.
With rubbers you can set your down stop too ...
#8797
Originally posted by kreidel
I run the stock setup with my front solid axle but change to a harder front tire compund usually 2 ot 5 difference in the shore.
#8798
Re: Re: Re: mtx-3 solid front setup
Originally posted by Cartman
droop and down stop are the same thing????
#8799
Droop and down stop are the same thing. Downstop means that the suspension arms travel downward, which means the chassis raised.
#8800
Anybody knows tips for cutting sedan body for mtx3...so that the air can flow easily...
#8801
What dow it mean by roll center?
#8802
Anybody tried hpi spring on the car. If so which ones? rubber/foam??? Thanks
#8803
Thats the one!
Thats the one!
#8804
without having to read a million posts can someone tell me if the MTX-3 can be successful on small tracks that only allow rubber tires. we have two tracks and thats how they are. I'm going to be picking up a new sedan for christmas. i know how well it performs on foams but like I said thats not an option. can the car be bought with front and rear gear or ball diffs. thanks.
#8805
