Old 10-28-2003, 07:49 PM   #8641
B
The mtx-3 with the negative diff gives the car a greater punch comming out of corners, but the difference is not a lot.
Its enough for the driver to feel it though..
B is offline   Reply With Quote
Old 10-28-2003, 08:45 PM   #8642
esham's Avatar
Originally posted by Vinyard
did you check your bevel gears in the diff if they properly mesh?
that could be your problem of your diff not turning smooth.
besides the neg diff will not solve that prob.. the neg diff is just a tuning option.. it will eat up tyres on the striaght when you power on exiting the corners..
by the way i think u may have to adjust your driving style abit with the neg diff
personally i think the stock diff will work just as well..
it really up to the driver himself...
Emm...so much thing to concern..! Yup .. I do check the diff gear mesh..seem ok. But you make me to check it again for more sure/confirm. Need to do more testing and analyse on troubleshooting the problem.
Kawahara rear diff... infact will still used the same diff gear from the existing stock diff. I will check how is the performance. Good ..use it. Not good - keep it in my tool box. I believe it was discussed before on previous pages, need to check that. Otherwise I will just replace the whole set of diff gear and the housing.
More punching out of corner.. that explain..thank you B .
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 10-28-2003, 10:27 PM   #8643
Vinyard's Avatar
more punch means eats more tyres..
er if not good i will be glad to take it off your hands..
i pay for shipping..
Vinyard is offline   Reply With Quote
Old 10-28-2003, 10:48 PM   #8644
tIANcI's Avatar
MTXRACER - chunking is also caused by lousy set up and shocks. Check your set up (down droop, camber etc). The last reason would be lousy driving, hehehe ... driving like a rally driver on a nice smooth course! Hehehe ...
tIANcI is offline   Reply With Quote
Old 10-28-2003, 11:01 PM   #8645
B
Wow!, thats quite an expensive part to be left in the tool box! Generally, it should be better than the stock one, so, cuz u bought it, might as well use it
Old 10-29-2003, 02:56 AM   #8646
esham's Avatar
Aaaa... hhaa That sound worth to have it.!!.
Old 10-29-2003, 03:20 AM   #8647
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
i think its my setup, i don't setup my car, don't have a hudy.
mtx3racer is offline   Reply With Quote
Old 10-29-2003, 09:13 AM   #8648
Send a message via AIM to loosenut
The good thing about the negative diff is that you don't need to adjust anything or can't that is. Well...I guess you could by using different type of grease compound - different viscosity. But I've been told it's the best of both worlds. You get solid axle when the tire is spinning fast enuff (i.e., full throttle coming out of straights) and then it disengage at slower speed for more grip around turns and corners. I haven't driven mine yet - still building it. But the concept seems that it will allow a more aggressive style of driving. Ah10 has one in his car - and he loves it. Where is he when you need him!!! LOL...
Remember not to use silicone based diff oil like the ones you put in your normal rear diff. Use racer's choice or redline lube. And coat the gears liberally. Not packing the whole thing with lube. Something I learned from Ah10.
G
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 10-29-2003, 09:17 AM   #8649
Just DL the setup that the pro driver uses on mugen's website and set it up accordingly and that should be fine to start out with. From that point on - really all you need to do is select tire shores. Of course if you hit the boards alot - then that's youru problem. But sometimes, if you have too much grip - that'll take a chunk outta your tire too. So either lower yoru shores in teh rear or lay the rear shock down completely. YOu should also use the blue springs front and back. Change ONE thing at a time - or else you wont' know the source of your problem.
Also, check your body - sometimes the body cuts into the tires without you even knowing! Hehe...
Get an integy setup board - it's not that expensive.
G
Old 10-29-2003, 05:34 PM   #8650
Hi guys,
Question about springs? The track i am running have good traction. Do i need to change harder spring for front and rear? If i do, Which color is harder? What about if i run in a dusty track. Means i should use stock spring or even softer???
Thanks.
US_MATRIX is offline   Reply With Quote
Old 10-29-2003, 10:21 PM   #8651
tIANcI's Avatar
mtx3racer - my local hobby shop has al the stuff I need to do set up, I set up my car every week for free ... hehehe ... not bad huh?
us_matrix - standard is BLUE, softer is PURPLE, harder is GREY, hardest is WHITE. What spring will depend of how smooth the track is (bumpy or not), how big it is (long straights or just short ones) and how technical it is (long smooth straight or a lot of tight turns).
For dusty track where traction is an issue try to go for purple springs and perhaps 40 weight oils. Again this depends how smooth and big the track is. A lot of it is based on experience, like F1, you need a lot of track time to collect data.
Try this link, it might help you a lot to understand the reasons why we do what and the combinations that we need --> http://www.donegal.flyer.co.uk/car%20setup%20guide.htm
Old 10-30-2003, 05:41 AM   #8652
Fisher890's Avatar
Nice link tIANcI,
As New as they come to the MTX3 and that one went straight into my favorites.
Thanx
Fisher890 is offline   Reply With Quote
Old 10-30-2003, 06:52 PM   #8653
rcmike's Avatar
Trader Rating: 40 (100%+)
Default Hollow 2 speed shaft
Hi, Who on- line,or can i call in the states that sells these?? THANKS
rcmike is offline   Reply With Quote
Old 10-30-2003, 06:55 PM   #8654
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Hollow 2 speed shaft
justrc
Manticore is offline   Reply With Quote
Old 10-30-2003, 08:38 PM   #8655
tIANcI's Avatar
Fisher - no probs dude ... that is the good thing about the net, we can exchange and access to information easily. You into long range fishing? I used to fish a lot but nothing as big as what you have over in the US.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
