Old 10-13-2003, 12:31 AM   #8401
RClover's Avatar
Originally posted by Vinyard
the Dragon D5 looks good.. and not forgetting cheap!!
so this new underwear code name D5 huh...??!!
show me a link to this...will'ya'..
RClover is offline   Reply With Quote
Old 10-13-2003, 12:32 AM   #8402
nolimit's Avatar
Default Gears
You can also use the MRX3 gears for those big tracks. But if you do, don't use their pinion and spear gear together, just one or the other. I just gear up my pin gear.
nolimit is offline   Reply With Quote
Old 10-13-2003, 07:07 AM   #8403
Anyone been using the 3 Racing brace/belt tensioner on the left side of the car. I have only run mine twice and the belt tensioner part has fractured and fallen off. No marks on the pipe or manifold so I dont think it was hit from the side.
Are these parts normally fragile or have I ended up with a bad one ?
Bob The Builder is offline   Reply With Quote
Old 10-13-2003, 07:52 AM   #8404
VenomWorldOrder's Avatar
unfortunatly 3 racing stuff is sometimes not of the best quality.
i have the lightened pulley adapters on my car and have found that they warp when, and if you tighten the grub screw to hard. no offense, but this is one spot i'm going to make sure i put on the screw tightly!
some other racers have found the rear swaybar blades to be too soft even on the hardest setting, and the connection to the brace to have play .
i currently have the front alloy blade holders they're of good quality though, and i also run the 4mm chassis witht he engine mounts. the chassis is heavy but of good strong, rigid quality.
my opinion? stick to static or minimal movement parts. stuff like chassis, front sway bar holders etc when buying 3 racing.
i really don't think you need that brace though. i race on a high speed ultra high traction track (we VHT it) and i found no advantage to have that brace on, OR off. the mtx3 is very strong in the rear area. especially with the 4mm chassis!
ps and don't get me started on the 3 racing cvds! OHHMAAAGAWDBROOO!! THEY SUCK!
VenomWorldOrder is offline   Reply With Quote
Old 10-13-2003, 07:54 AM   #8405
tIANcI's Avatar
Bob ... sorry to say that the 3Racing left brace is prone to breaking when you get hit or if you take a bad enough shunt, forget it as it is a waste of money (brace and anti roll bars).
Also, stay away from the front UJs ... they will span easily, get the stock Mugen ones!
tIANcI is offline   Reply With Quote
Old 10-13-2003, 12:21 PM   #8406
Glow plug selection...
I am running Novarossi T5S1 5 port turbo and i live in Bay area, California. I see there are many diffreent types of Novarossi turbo glow plug Long/Short/Hot/Med/Cold C5TC, C5TF etc. Which one i should use? What's the diff between Hot/MeD/Cold and Long/Short plug?
Thanks.
US_MATRIX is offline   Reply With Quote
Old 10-13-2003, 03:53 PM   #8407
chookgb's Avatar
Trader Rating: 26 (100%+)
Default 3 racing sway bar
i agree the front sway bar from 3 racing has broken on my car at our recent run nationals my right side bar in the alloy piece broke costing me dearly during qualifying back to mugen for me
chookgb is offline   Reply With Quote
Old 10-13-2003, 07:02 PM   #8408
Hey guys, I just switched over to the mtx-3 and have a question.
Whenever I put full lock on the steering right or left, there is one place on the cvd that will click or jump slightly. I tried many cvd's and they all do the same. Is there anyway to get rid of this without sacrificing full steering?
Thanks.
rcpilot is offline   Reply With Quote
Old 10-13-2003, 07:11 PM   #8409
JustRace's Avatar
Yea....use the rear universal in front. Or check to make sure you're using the shorter ones up front. Mugen has been packaging them incorrectly. The shorter ones should be up front and the longer ones to the rear.
Thanks.
JustRace is offline   Reply With Quote
Old 10-13-2003, 07:26 PM   #8410
B
All the dogbones on mine are exactly the same length
I dont think there are long v.s short ones
B is offline   Reply With Quote
Old 10-13-2003, 07:47 PM   #8411
RClover's Avatar
Thanks.
here's a good starting point
http://www.rbproducts.com/rbww/faqrb...htglowplug.htm
Old 10-13-2003, 07:48 PM   #8412
tIANcI's Avatar
Justrace - you must indeed have gotten some weird stuff, like B my Mugen shafts are all of equal lenght!
RCPilot - if you use the dogbones you will hear the click as the pin at the end rubs against the cup recesses that the pins lock on to. If it is that annoying then narrow your wheel width to about 197mm, best is to just use UJs from Mugen. Hope this helps!
Old 10-13-2003, 08:46 PM   #8413
Manticore's Avatar
R/C Tech Charter Subscriber
how can you be so sure? what other mistake has mugen made?
Manticore is offline   Reply With Quote
Old 10-14-2003, 12:42 AM   #8414
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
You still racing your Mugen Tommy?
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 10-14-2003, 02:38 AM   #8415
FREAKAH's Avatar
Ummmmmm..........
Uhhhhh...........
All of a sudden, i'm thirsty for milk.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
