Mugen MTX-3
#8386
Originally posted by rccplayer
Sorry, upload here~~
#8387
Mine does too.
They came with the 3racing 4 mm chassis.
#8388
No, Mugen 4mm Chassis with Kawahara engine mount but for MTX2, so was 4mm screw.
#8389
I am confused !
#8390
Originally posted by Manticore
I am confused !
I am confused !
#8391
The latest Kawahara MTX2 engine mount already has low CG, (same height as MTX3 one), use with 4mm titanium screw & Serpent washer.
#8392
Multiple MTX3 questions
What gearing will I need for a large track, the only gears I have are what comes in the kit and one track I race at is so big you dont need brakes. What shore are the tires that come stock? Will the Jaco Nitro Shoes with 0 degree work on the rear or will I need an adapter? I am going to run a solid axle/spool up front for a small track...any suggestions on what to do for the rear as far as heavier oils and any setup changes. If these questions are lame I apologize...I run an Associated and am clueless to this car.
#8393
Re: Multiple MTX3 questions
I would go for Mugen Fast tire period! because they work really good on mtx3
#8395
Foams
The kit foams are fast tires, and they 37's. You can also benfit with 40, and 42 compound. depnding on the track cond.
#8396
the .8 modules just came out awaile back ago. Using the .8 gears will give you a broader line of gear ratios to work with. For example: In electric, its like using 64 pitch gears compared to 48 pitch gears. For me, when I first started using the .8 gears, the first thing I notice was the transition from 1st to second 2 gears was very smooth. Basically, the car felt smooth throughout the whole power band. Give them a try. You might like them.
#8397
Originally posted by loosenut
guys,
What is the best rear roll bar for the mtx-3. I'm confused...I have the 3-racing belt tensioner that goes around teh engine and mounts on the screw that holds the stock bars down. But...if I use it I can't use the stock bars...I'll have to get different bars...just wondering if you guys have tested different ones?! LMK...Thx.!
Gary
guys,
Gary
Stick to the stock rear bars. The one that comes with the kit is 2.3mm while the silver rear bar is 2.5mm. I've had people try the 3 piece rear sway bar, but they went back in using the stock mugen sway bar.
#8398
Originally posted by Vinyard
Hehe.. thinking of getting another engine.. any recommandations?
no comments..i'm still running my Rody RR..
#8399
Originally posted by RClover
seems that you change engine like underwear..huh!??
#8400
No leh.. have been using my S5 for bashing and Max for racing.. my S5 is complaing, so its time for a new cheap engine for bashing.. the Dragon D5 looks good.. and not forgetting cheap!!
