Old 10-07-2003, 10:39 PM   #8326
RClover's Avatar
Originally posted by mtx3racer
Does anybody that drives the mtx3 use oil to lube the 2nd gear housing that fits over the 2 speed shoes? I'm still having problems w/ my 2 speed sticking in second. I talked to some local race champs and they looked at it and said that there was nothing wrong w/ the way i put it together. I just finished driving it w/ lube the inside of the housing and its seemed to drive longer w/ out sticking but still got stuck after about 3 min. of driving. Help!
perhaps, you might want to check if the 2 speed shaft is straight?
does the 2nd shoe rub against the rear bulkhead?
RClover is offline   Reply With Quote
Old 10-08-2003, 03:34 AM   #8327
Just in!!
Mugen MTX3 Spare/Options/FastTires
HPI R40 kit Spare/Options
T-MAXX Options
Savage Options/Spares are coming
NTC3-coming soon
Full line of RD Logics Parts
Updating site.......
Check it out! Thanks!
JustRC
justrc is offline   Reply With Quote
Old 10-08-2003, 03:41 AM   #8328
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
RCClover- I have checked that and replaced it w/ the aftermarket hollow shaft does the same
mtx3racer is offline   Reply With Quote
Old 10-08-2003, 04:05 AM   #8329
Vegetto's Avatar
Hey,
Can you guys help me, is this a good deal?
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3148588730
Thanks guys
Vegetto is offline   Reply With Quote
Old 10-08-2003, 04:19 AM   #8330
Corse-R's Avatar
Originally posted by Vegetto
Hey,
Thanks guys
Seems a good deal at first looks, if the engine is on good condition and the car the same. Just ask for some extra photos to the owner and see the condition of something (front bumper, end of the outdrives, pulleys, etc... to see if the car has been abused and received crashes).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 10-08-2003, 04:33 AM   #8331
Vegetto's Avatar
Thanks Corse-R !
Old 10-08-2003, 10:03 AM   #8332
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Hey,
Thanks guys
Very good point! just another input, see if you can ask for more images on the front oneway outdrive, usually if the car is abused or been running much longer then advertized the front oneway outdrive will wear and you can actually see an indention on the outdrive itself!
Ah10 is offline   Reply With Quote
Old 10-08-2003, 10:42 AM   #8333
Manticore's Avatar
how long have you been using the 2 speed clutch with out rebuild it?
it is possible that the flat spot on the 2speed clutch adaptor has worn out unevenly that makes the clutch shoes not able to return to its unengaged position.
Manticore is offline   Reply With Quote
Old 10-08-2003, 11:14 AM   #8334
Hi Guys,
Need your input on this.
Is there a big advantage of using a floating rear body mount on a lola body as oppose to the stock rear body mount on the MTX-3?
I would like to run a lola body on my MTX-3.
Thank you.
cvccsi is offline   Reply With Quote
Old 10-08-2003, 11:22 AM   #8335
Corse-R's Avatar
Default Floating body mount and Lola bodies
Originally posted by cvccsi
Hi Guys,
Thank you.
With a high downforce body like the lola is DESIRABLE to use the floating body mount, because all the downforce created by the body is transferred to the rear wheels rather than applying the downforce to the rear suspension and compressing it making it bottom out on some situations.
A floating body mount isn't officially available for the MTX3, instead you can use the parts from a V-one RR and put into your car, some modifications and dremeling is in order to do, probably any other here can give you more info regarding this.
Used sometimes the Lola body with the stock body mounts, isn't the best, but at least you can notice a little how handles the car. Another benefit of the floating body mount is to keep the body at a given height allowing the car to move under it without disturbing the height of the body (hence here their name of floating body mount).
Cheers,
Corse-R
Old 10-08-2003, 11:29 AM   #8336
Hi Corse-R,
Thank you for the explaination!! Will try the lola first on the stock mount than modify the car for the floating mount.
Old 10-08-2003, 12:33 PM   #8337
Corse-R's Avatar
Default Red clutch shoe (H0769)
Anyone has tested it and compared with the Delta red shoe? Are the same or different?
Cheers,
Corse-R
Old 10-08-2003, 12:46 PM   #8338
Manti- I just rebuilt it last week
Old 10-08-2003, 02:22 PM   #8339
Send a message via AIM to loosenut
mtx3racer,
Why don't you just get a new two speed assembly? I"ve never had that problem before. Plus, I guess you don't have to worry about it since you are sellling your car?
G
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 10-08-2003, 02:23 PM   #8340
i have bought 2 new sets of everything (2spd. shoes, shaft, screw...)
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
