Old 09-28-2003, 03:39 PM   #8131
raffaelli's Avatar
So what kind of track should the front gear diff be used instead of the front one way?
raffaelli is offline   Reply With Quote
Old 09-28-2003, 04:08 PM   #8132
Send a message via ICQ to Cartman
rubber tyres NO front one way diff only!!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 09-28-2003, 05:24 PM   #8133
Default diff parts
What parts do i need to buy in order to build a front diff?
I have only what came with the kit....
EnzoFerrari is offline   Reply With Quote
Old 09-28-2003, 08:39 PM   #8134
Default Re: diff parts
check page 126 of this thread. Also shows setup using rubber tires. hope these helps
penggoy is offline   Reply With Quote
Old 09-29-2003, 12:10 PM   #8135
Send a message via AIM to loosenut
Hey do you guys play around much with the shock oil weight? Coming for a ntc3 owner....changing the front shock oil weight..especially up front makes night and day differences in handling? But for some reason I look at people's setup on the mtx-3...no one really changes the weight of the oils....
Gary
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 09-29-2003, 12:24 PM   #8136
freefallmarine's Avatar
hey guys, my girlfriend just picked up an mtx 3 for my welcome home gift.. there was also an os 12 tr with the package but there wasnt a collar for the sg shaft, do i need an os only collar or will any one do? im in the dallas area, so anybody close buy who could point me in the right direction of hobbiest, or hobby shops would be appreciative..thanks....
freefallmarine is offline   Reply With Quote
Old 09-29-2003, 12:48 PM   #8137
Corse-R's Avatar
Gary
Hi Gary:
As you will go making more and more laps with your car you will know why people doesn't mess so much with the shock oils. Isn't much needed and their stock setup is about 90% fine for all the tracks (just only play with camber, toe-in/out and caster. This car really likes the blue springs, gray is rarely used and the same for purples.
I did some testing on oils, but for mine personal prefs I liked how handle with a 60 or 70wt oil for front and 60 to 80 to the rear. But looking at mine notes, 60 for front and 60 or 70 for the rear is mine preferred (stock oil - #600 is about 55wt).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-29-2003, 12:50 PM   #8138
Corse-R's Avatar
Uhm. You need to use the kit supplied flywheel collar, discard the OS one and you can assemble without problems the flywheel assy.
Cheers,
Corse-R
Old 09-29-2003, 01:25 PM   #8139
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Default Spacers for rear 0 offset tires
Does anybody know the part number for the wheel spacers that allow the use of 0 deg offset tires, I am trying to help a friend and I know my kawahara wheel hexes came with them but does mugen make some also
TAW is offline   Reply With Quote
Old 09-29-2003, 02:11 PM   #8140
Originally posted by Corse-R
Hi Gary:
what about this then Corse??
off top of my head
front
-1.5 camber
1 toe out
no front roll bar OR one soft and ground half thickness
special shock tower to stand shocks up
assosiated gold springs
4 1 mm holes in pistons
40 wt oil
1 small spacer for caster at front
100k diff
5mm ride height
rear
3 toe in
kawahara roll bar ground half thickness if roll bar used
-1.5 camber
asscociated copper springs
shocks same as front
rear hubs cut to same hieght as mtx2 rear (some fit myx2 rear hubs) 3 degree camber change
5k diff
6mm ride hieght
ING tyres, mugen 26mm wheels and Echo red thin or think inserts
stratus 1 body
got me 13th overall in the UK nationals
Old 09-29-2003, 03:01 PM   #8141
Corse-R's Avatar
off top of my head
stratus 1 body
Rubber tyres? For foam tyres, stock setup is almost perfect. Just read mine signature
Cheers,
Corse-R
Old 09-29-2003, 03:14 PM   #8142
jus teasing you m8
Old 09-29-2003, 03:58 PM   #8143
theRED5's Avatar
R/C Tech Charter Subscriber
Hey SmartRacer...are you ordering a shark?...I may ant to get one too.
Good to see Stefan got back from Fla...was a good time had?
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 09-29-2003, 06:37 PM   #8144
Default Engine break-in
Hi guys,
I just put my new Novarossi RS12T5 S1 in my MTX-3. Can someone tell me what is the proper break-in method? Do i need to richen up high end needle from default setting.
People mention that let it idle for 3 - 7 tanks and then run slowly.
Thanks.
US_MATRIX is offline   Reply With Quote
Old 09-29-2003, 07:07 PM   #8145
EVOLUTION's Avatar
Originally posted by eddiethefish
yike! yike! yike!
Fish,
How many times did i tell you that it's too dangerous tuning your car under water?
EVOLUTION is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
