Old 09-26-2003, 12:43 PM   #8116
Corse-R's Avatar
Originally posted by loosenut
What is a faulty break in? I didn't know that you can mess up the breaking process? Reason I ask is because I'm in the process of breaking in a motor. Thx.
Gary
Probably you not finished the break-in, during this phase, engines get more friction and get a little hotter. When finished, engine lowers their operating temp. What's your temp?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-26-2003, 02:45 PM   #8117
Send a message via AIM to loosenut
When I'm breaking the engine in - at idle it's runs around 200 plus or minus..
After idling it for a couple tanks, I see on the O.S. website that it's actually not good to idle it more than like 1 tank! Psh...I guess I'm ready to drive it now! Yeah!!! I bought a TR(p) for my car. It hella tight - meaning its soooo hard to turn over!!! Kinda annoying that every couple times it locks up.
G
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 09-26-2003, 07:05 PM   #8118
Send a message via AIM to kreidel
Default Front diff or spool
Does anyone sell the complete front diff so I can replace my oneway or do I have to peice it together? Also, does anyone make a spool for it?
kreidel is offline   Reply With Quote
Old 09-26-2003, 07:10 PM   #8119
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
G
Wow! at 200F +/-? During running-in? yike! yike! yike!
eddiethefish is offline   Reply With Quote
Old 09-27-2003, 12:22 AM   #8120
theRED5's Avatar
R/C Tech Charter Subscriber
I knew picking up that front locked diff was a good idea when I got it!
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 09-27-2003, 08:16 PM   #8121
stefan's Avatar
Send a message via AIM to stefan
Originally posted by Corse-R
Hehehe... Tomorrow will send ome furious bee to the East Coast, expect to surprise some and kick/spank/... some asses some KY is included in the package for free
?? ?? or ?? ?????
stefan is offline   Reply With Quote
Old 09-28-2003, 02:11 AM   #8122
Thunder racer's Avatar
Default CAN I DO IT?
Hi guys and Girls
im looking to put my THUNDER TIGER EVO12 non-pull start into my MTX-3 is non pull start so thats not a problam the problam is that its SIDE EXHAUST and dont think that the header will go past the sway-bar it will hit it i think can any of you help me out on how to fit it in (thats if it is possible)
THANKS
Thunder racer is offline   Reply With Quote
Old 09-28-2003, 06:09 AM   #8123
smartdriver's Avatar
Default shark pipe
can anyone give me a link to where they sell those "shark" pipes? I need a better look at that billet stinger.
smartdriver is offline   Reply With Quote
Old 09-28-2003, 06:33 AM   #8124
Manticore's Avatar
Default Re: shark pipe
Shark
Manticore is offline   Reply With Quote
Old 09-28-2003, 10:02 AM   #8125
Default Tire/Rim Choices?
What offset rims do you guys run with the MTX-3?
I want try some different setups but don't know if i should get 2mm offset or 0mm rims. Im trying to find a decent setup with rubber tires if possible. I want to run 30mm rubber in the rear. Do i need to run 30mm rims as well or can i put them on 26mm rims? Foams wear out very quickly so im looking for an alternative.
Car handles amazing with foams but im spinning out with rubber tires. Currently using 26mm rubber tires all around.
Car is setup with 194mm track width both front and rear. I can't go any wider due to dogbone problems. I ordered a set of universals and can't wait to get them that way i can finally run 199mm Front and 200mm rear. Im sure this will dramically increase stabilty and traction in turns.
EnzoFerrari is offline   Reply With Quote
Old 09-28-2003, 01:04 PM   #8126
Send a message via ICQ to Cartman
Default Re: Tire/Rim Choices?
you can get this car dialed on rubber there is no need for any other than 26mm, you are running a front diff NOT a one way??
i will post my rubber set up on here soon!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 09-28-2003, 02:07 PM   #8127
I am running the one way...
Old 09-28-2003, 02:28 PM   #8128
thats one of your problems!
Old 09-28-2003, 02:30 PM   #8129
so you recommend running a diff in the front?
Old 09-28-2003, 02:59 PM   #8130
definatly
off top of my head
front
-1.5 camber
1 toe out
no front roll bar OR one soft and ground half thickness
special shock tower to stand shocks up
assosiated gold springs
4 1 mm holes in pistons
40 wt oil
1 small spacer for caster at front
100k diff
5mm ride height
rear
3 toe in
kawahara roll bar ground half thickness if roll bar used
-1.5 camber
asscociated copper springs
shocks same as front
rear hubs cut to same hieght as mtx2 rear (some fit myx2 rear hubs) 3 degree camber change
5k diff
6mm ride hieght
ING tyres, mugen 26mm wheels and Echo red thin or think inserts
stratus 1 body
got me 13th overall in the UK nationals
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
