Old 09-14-2003, 10:31 AM   #7966
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by loosenut
Question for ya guys,
I finally was able to put together my car....but putting and storing away all the servo wires were pain in the ARSe!!!! How do you guys do it? I had a hard to figuring out where to squeeze all those servo/transponder/switch wires? Anyone got any pics?
G
this is my way of doing it.
Manticore is offline   Reply With Quote
Old 09-14-2003, 10:39 AM   #7967
Send a message via AIM to loosenut
Cows...where did you stick the plug that connects the rx pack to the switch? That one is pretty big? What about transponder switch!! I guess this is one of the weakness of mtx-3...
I'm just thinking what if the car get hit from the side ..I hope the electronics won't fall apart...hehe
G
loosenut is offline   Reply With Quote
Old 09-14-2003, 01:02 PM   #7968
rc_bam226's Avatar
I did my wiring in a similar way to Manticore, the switch I used had an extra lead to charge the Rx pack without removing the battery pack. As far as protection from hits, a switch acts like a bumper for the steering servo. Better to replace the switch than the servo.
rc_bam226 is offline   Reply With Quote
Old 09-14-2003, 01:25 PM   #7969
PhantomMaxx's Avatar
Default Battery life
I can't believe what I'm reading about the short run times some of you are getting on the reciever battery pack. I running my MTX3 at our local track for about 5-6 hours every Sunday, and the entire time my reciever is rarely off. I don't use digital servos, but if the short battery life is because of the digital servo, I'm staying away from them. I have a good charger from my electric days but don't us it for my reciever pack. Instead, I use an over night wall plug type charger from Prolux just to make life easy. I'll burn up a half gallon of fuel before battery is dead. My set-up: Novak XXL reciever, GSW failsafe, 2 Airtronics 94737 servos all plugged into an RD Logic battery pack.
PhantomMaxx is offline   Reply With Quote
Old 09-15-2003, 01:07 AM   #7970
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi guys, does anyone know what size is the stock black rear sway bar ? is it 2.3mm or 2.5mm ? also, what 's the stock front and rear piston size ? 1.1X1 and 1.1X2 ? thanks
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 09-15-2003, 01:09 AM   #7971
Tag
Tag's Avatar
regarding the rear lower-arm position, stock setup uses B-B 5mm, how does it change the handling if i use A-A 4mm or C-C 6mm ?
thanks
Old 09-15-2003, 01:19 AM   #7972
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default fish is back!
Hello All,
Feel so great being home after a nice two weeks off abroad. Well, here is a new chassis from Shooter, artistically and well functional.
best,
eddiethefish is offline   Reply With Quote
Old 09-15-2003, 02:01 AM   #7973
FREAKAH's Avatar
thanks
Well, according to my plastic caliper the stock swaybar is 2.3mm.
The 6mm high roll center blocks resists chassis roll more. The 4mm low roll center blocks allows more chassis roll. I have noticed that the chassis squares up faster with the higher roll center(C) and that I can use a softer spring rate. The low roll center blocks(A) seems to have more traction in loose conditions but seems a little slow reacting and lazy. Using a sway bar and/or stiffer springs is recommended. After all that, I'm going back to the "B" blocks to get the best of both.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 09-15-2003, 03:27 AM   #7974
Vinyard's Avatar
Default Re: fish is back!
Originally posted by eddiethefish
Hello All,
best,
And very expensive..
Vinyard is offline   Reply With Quote
Old 09-15-2003, 07:16 AM   #7975
VenomWorldOrder's Avatar
r u sure??? i thought it was like this;
A block ='s less roll equals better grip and handling on high traction tracks
b = middle
c = for loose track conditions, uprepared surfaces etc gives more roll to the rear end
i ran in the last state titles in NSW in oz the B, moved to the A and found the car to be flatter in the tight twisty bits. A = 'ed less roll, lower roll centre = more stable car.
i think i am right?!
VenomWorldOrder is offline   Reply With Quote
Old 09-15-2003, 08:18 AM   #7976
Tag
Tag's Avatar
somebody want to elaborate on this how about the shock piston size ?anyone know ? i appreciate all that replied, thanks for the inputs and keep them coming !
b = middle
Old 09-15-2003, 09:15 AM   #7977
Adjusting the clutch. Anyone have any tips on adjusting the clutch? Starting point? There an optional tool listed on the manual to adjust the clutch spring?? Is that necessary? I couldn't find it at my local hobby shop. Thx.
Gary
Old 09-15-2003, 10:53 AM   #7978
Corse-R's Avatar
Gary
Nope, you don't need an additional tool to adjust spring tension of the clutch. Simply is needed an 1mm or 1.5mm (if fits on your clutch bell hole). Lock the key on the notch who acts as nut in your clutch.
Just remember that for tightening the clutch, you need to rotate in CCW direction your flywheel (looking at the front side of the engine - you need to see the carb). Go in steps of 1/4 of turn, finetune in 1/8 of a turn when you like the spring tension (Take your time -3 or 4 laps at least- to heat the clutch before doing adjustments).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-15-2003, 11:01 AM   #7979
FREAKAH's Avatar
b = middle
Notice that most nitro cars(w/o adjustable roll centers) have a high roll center(high inner arm mount) in the rear compared to electric cars? This is to reduce the effects of the top heavy(and rear biased) nature of nitro cars.
Second-Hand Racing
RACE WORLD HAWAII
Old 09-15-2003, 02:16 PM   #7980
Default What would you pick?
Hello All,
What would you pick if you CAN just get one of these:
Stock NS3
JP Black NS3
Kondo NS3
Kawahara ZAC Project NS3
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
