Old 09-07-2003, 07:53 AM   #7801
Default Math Question
Question for you math wizards. Is 90 mA 0.9 amps? If not, how many amps would 90 mA be?
BTW: AWESOME track Antonio!!!!!!!! I'm jealous!!!!!!!!!!!!!!!!!
tekrsq is offline   Reply With Quote
Old 09-07-2003, 09:25 AM   #7802
mistercrash's Avatar
R/C Tech Charter Subscriber
90 mah = 0.09 amp. If not then I really should go back to school.
mistercrash is offline   Reply With Quote
Old 09-07-2003, 10:49 AM   #7803
FAST1's Avatar
What school is that.............electronics engineering!
FAST1 is offline   Reply With Quote
Old 09-07-2003, 10:55 AM   #7804
Send a message via ICQ to nizee
Default Re: MTX-3 part deux..
Originally posted by Vinyard
Another view.. top side..
Salam Vinyard,
Nice picture. Is the receiver box came with the new kit or what company make that receiver box, Ofna?
nizee is offline   Reply With Quote
Old 09-07-2003, 11:33 AM   #7805
Default Clutch adjustment
Hey Guys. Which screws do i adjust to make my 2 speed engage earlier? Right now it's swifting to late and the cars starts spinning out of control in 2nd gear.
EnzoFerrari is offline   Reply With Quote
Old 09-07-2003, 11:38 AM   #7806
Fire's Avatar
adjust the button head screws on the clutch inside the 2nd speed housing
don't mix up the button head screws and the set screws tho, the set screw is for how the 2nd speed engage
Fire is offline   Reply With Quote
Old 09-07-2003, 11:39 AM   #7807
Fire's Avatar
Originally posted by Data
see that big parking lot behind the sweeper ? people run go-karts there too
maybe i should move
the go kart tracks here is not even as big as the rc track there
in fact that rc track is just slightly smaller than the autox track here
Old 09-07-2003, 11:47 AM   #7808
Vinyard's Avatar
Default Re: Re: MTX-3 part deux..
Originally posted by hurhur
where is your NovaMax?
Its there.. cant u see it??
Vinyard is offline   Reply With Quote
Old 09-07-2003, 11:48 AM   #7809
Vinyard's Avatar
Originally posted by nizee
Salam Vinyard,
Not sure if Ofna makes them.. but the one in the pic is by Team Magic..
Old 09-07-2003, 02:14 PM   #7810
Default Setups?
What do you guys recommend for front diff setups?
Right now im using the one way it seems to handle well.
My problem is with braking. If i don't use abs the car will skid while braking and always seems to spin out. with the abs on i found a setting where it doesn't skid but it takes a while to completely stop. I was thinking of using a diff in the front. What do you guys think?
Old 09-07-2003, 02:34 PM   #7811
EVOLUTION's Avatar
Default Re: Math Question
Where is that damn maths wizard Data when you need him?
1000mah in 1 amp
1.0=1 amp
0.9=900mah
0.09=90mah
EVOLUTION is offline   Reply With Quote
Old 09-07-2003, 02:35 PM   #7812
nitrodude's Avatar
You have to use very little brake with a one way, set the brakes so they barely slow the car down, in fact they shouldnt slow the car down just a touch to help tuck the car in in tighter turns.
The trick is to learn how to drive without brakes, or very very little brakes, it will make you faster, and will teach you how to run always the same line.
Thanks,
Steven Muller
MPP
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-07-2003, 02:47 PM   #7813
ok great. I don't use the brakes very often just enough to scrub some speed before a tight turn. I was curious what others did. I guess i should keep the one way in?
Old 09-07-2003, 02:50 PM   #7814
B
If your car's rear is going crazy under braking, it means that you are using too much
use the endpoint adjustment on your radio to adjust the brake to the point that the car will slow down and the rear will not slide out
then that is all the braking you can use
If you want much harder braking, then opt for a diff
B is offline   Reply With Quote
Old 09-07-2003, 03:07 PM   #7815
EVOLUTION's Avatar
The key to using the oneway and no brakes is throttle control and setup.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
