Old 11-22-2002, 02:50 PM   #721
ant
ant's Avatar
Default Re: Re: Re: Tuned Pipe
Originally posted by click, dublin
Now lets see OZ = Australia.
Who was sent to Australia by boat in ye old times?
I don't think I need Interpol I have my first suspect . . . .
All the best
i swear i havent got it
ant is offline   Reply With Quote
Old 11-22-2002, 02:56 PM   #722
Default Break
Hi Guys,
I gave the break pads a sanding.
Pushed the two pins approx. half there length into the chassis.
The breaks still bind?
Has anybody removed some plastic from the top brace disc stop?
If I remove any more break lining I'll have no break?
Has anybody got a free rolling drivetrain with no break binding?
Many Thanks
click, dublin is offline   Reply With Quote
Old 11-22-2002, 03:03 PM   #723
patelladragger's Avatar
Send a message via AIM to patelladragger
Default Re: Break
Hi Guys,
Many Thanks
Did you seal the pads to the plates with thin coat of CA and squeeze tightly? If you did that and there is no gap between the pads and the plates then just sand the pads some more. Mine are free but I did have to go back and do more sanding. There is still lining left on the pads and I don't use brakes enough with a one-way to be concerned with how much is there.
patelladragger is offline   Reply With Quote
Old 11-22-2002, 03:06 PM   #724
rjl
rjl's Avatar
I've got your free roll.
Check for binding with the rear pod removed from the chassis before attacking the plastic.
Make sure your discs are not distorted.
Remove any burs from the stamped disc spacer.
Make sure there is just the smallest gap between the pad and roll pins. We had to gently lever one roll pin over on the car we started building last night.
rjl is offline   Reply With Quote
Old 11-22-2002, 03:27 PM   #725
Default Brakes
Hi Guys,
Slightly bending the pins has helped.
Not as tight but not free rolling.
I'll check & tweek a few more things, sure this is half the fun of building a car.
Thanks for the advice
Old 11-22-2002, 04:03 PM   #726
Send a message via ICQ to Cartman
do any of you guys drill the shock pistons?
in the uk (rubber tyres) we have been drilling 3 1mm holes in front a 4 in rear?
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 11-22-2002, 04:27 PM   #727
Horray For Nytro.......just got off the phone with our very own Robby, he told me how to solve the brake issue. first off, do not use any glue whatsoever on the brake pads, do not glue them to the metal. second, on the rear bulkhead over the brakes, there is a brake guide. grind it away. this should solve the problem.
Nytrochaos is offline   Reply With Quote
Old 11-22-2002, 05:39 PM   #728
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Brakes
Hi Guys,
I would enlarge the holes on the brake plate instead.
Manticore is offline   Reply With Quote
Old 11-22-2002, 05:49 PM   #729
Manticore's Avatar
I was told to fix the tight brake fitting is to use rubber adhesive to glue on the pad and use a brenh wise to press both the pad to make sure the brake pad sit flat on the plate.
Old 11-22-2002, 05:56 PM   #730
i was told by myself that removing one outter brake disc and the middle one will solve this problem! hahaha
who need brakes this thick anyways... ?
i should say who break hard with a one way in front?
i barely use brakes myself.....
ME-student is offline   Reply With Quote
Old 11-22-2002, 05:59 PM   #731
Manticore's Avatar
I was told by myself not to throw away that damn nice piece of braking unit even I dont brake much TOO !!
Old 11-22-2002, 06:05 PM   #732
Manti: yes.. its nice... but i am still going to use only one of the outter disc... hehe...
i think Mugen has a 1 piece brake disc just like that for MRX-3..
Old 11-22-2002, 06:08 PM   #733
rjl
rjl's Avatar
Yea brakes just slow you down, who needs 'em.
Old 11-22-2002, 06:10 PM   #734
Manticore's Avatar
I need them too feel good when I look at this cool thing on the car !
Old 11-22-2002, 06:23 PM   #735
yes yes.. eye candies are important too!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
