Old 07-31-2003, 09:08 PM   #6841
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Re: 0.8 module recommendations
Originally posted by Corse-R
For the gearing you're using, you will be fine with almost the same combo I'm using 21/59 & 26/54 (I use 21/58 & 26/53).
This one I said is slightly longer on 1st gear (7,132 vs 7,097) and the same on 2nd gear (5,293 vs 5,246). Differences shouldn't be noticeable.
A slightly shorter and slightly more closed gearing (good for mid to high and strong 2nd gear shift) could be 21/59 with 25/52 and let your engine whine at the top end.
By the way, for those who use the 0.8 gearing system, when I was in Japan, I remember seeing the harden steel pinion on this type of system, make sure you seek them for your car. I don't remember who makes it.
I surely will look for ones for my Evolution.
eddiethefish is offline   Reply With Quote
Old 07-31-2003, 09:50 PM   #6842
vones's Avatar
hmmm...hardened steel pinions.......wuldn't these weighs abit heavier than alum ones......I hve some feed back regardings these hardened steel pinions.......these extra weights wuld stress the crankshaft......what do u think...?
IMO....these steel pinions weighs almost twice as the alum ones.....
vones is offline   Reply With Quote
Old 07-31-2003, 10:29 PM   #6843
Weight difference is not much. However, if you can afford buying new ones all the time, stick with Al. A lot easier to find and a bit cheaper.
Old 08-01-2003, 12:28 AM   #6844
vones's Avatar
well said..........
Old 08-01-2003, 06:17 AM   #6845
Originally posted by alvinm
Cool,they have the specific belt available?.Aside from the tire wear is there any differences in handling(more or less steering etc...)Thanks.
alvinm: the belt for the 16 tooth rear pulley/19 tooth front
pulley is made by Kawahara and is part #K-785...www.ace
hardwarehobbies.com carries them...the last time I checked
(5 days ago), they had 8 in stock. Pick up an extra set of
the Mugen plastic pulleys (TO221) and you are all set...if you
want to run 0% overdrive, the front needs to be 3.72 mm
smaller...most of the guys on this forum topic seem to like
a 3.00 mm spread which is about a 1.3% overdrive which
still gives the steering but helps to tuck the rear end in
when you get on the power coming out of corners.
jd300zxtt is offline   Reply With Quote
Old 08-01-2003, 06:32 AM   #6846
Manticore's Avatar
R/C Tech Charter Subscriber
i tried both kawahara 363mm belt and the one corse-r sent me
the kawahara one is softer (less friction???) and the one corse-r supplied is beefed.
the kawahara one just wont last and the belt strip after a gallow or so.
I have been running corse-r 363mm belt for a few gallow and it is still in good shape.
I still have one kawahara belt left. who wants it?
Manticore is offline   Reply With Quote
Old 08-01-2003, 06:45 AM   #6847
Originally posted by Manticore
who wants it?
me! me! me!
Old 08-01-2003, 06:54 AM   #6848
alvinm's Avatar
Verifying with this setup you lose some steeringWhat is gained or lossed with setup?
alvinm is offline   Reply With Quote
Old 08-01-2003, 07:33 AM   #6849
Default Kawahara Rear Sway Bar
I already got the Sato rear brake brace. Will the Kawahara
rear sway bar fit or do I need to get the Kawahara rear brake brace as well?
Thanks.
Supra66 is offline   Reply With Quote
Old 08-01-2003, 07:42 AM   #6850
stefan's Avatar
Send a message via AIM to stefan
To everyone who's considering the belt conversion, I recommend that you stick with Corse's belts.
They are affordable and they are made by Pirelli!!
How do they say: Power is nothing w/o control...
stefan is offline   Reply With Quote
Old 08-01-2003, 07:54 AM   #6851
super dave 45's Avatar
is the gearing on the mtx2 the same on the mtx3
if so i have a mtx2 i run on a big track 180x80
it is and open track good drivers are getting 24 to 26 laps
in 5 min what gearing should i use
thanks
dave
super dave 45 is offline   Reply With Quote
Old 08-01-2003, 07:58 AM   #6852
Corse-R's Avatar
Nope, with the 16/19 conversion you will not lose steering, at least you will gain a little of, because of the small launch of the chassis. I tried it myself before all and liked the way was.
Stefan and Manti, thanks for the compliments.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-01-2003, 08:48 AM   #6853
Default Re: Kawahara Rear Sway Bar
Thanks.
it'll fit just fine.
Old 08-01-2003, 08:49 AM   #6854
thanks
dave
hey dave,
can you peek or ask those drivers what they use? I'm sure they'll be more than happy to tell you.
Old 08-01-2003, 08:51 AM   #6855
Manticore's Avatar
yep !! strip belt is out of control !! use a "proper belt" !
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
