Mugen MTX-3
Old 07-29-2003, 01:33 PM
  #6766
eddiethefish's Avatar
Default Re: 2 spd
Originally posted by mtx3racer
has anybody had problems w/ the 2 spd sticking sometimes in 2nd? I have lubed it and tryed it dry both don't seem to work. Help!!!?
Nitro Rules
You meant the 2-speed shoe locks up in the 2nd Spur housing?
eddiethefish is offline
Old 07-29-2003, 02:26 PM
  #6767
Default Re: 2 spd
Nitro Rules
not if its adjusted corectly!!
Cartman is offline
Old 07-29-2003, 02:33 PM
  #6768
it is adjusted correctely!!!!!!!!!!!!!!!! Yes the 2spd. shoes in the housing.
Nitro Rules
mtx3racer is offline
Old 07-29-2003, 02:35 PM
  #6769
Default Re: Re: 2 spd
haven't had that problem, either. I only put it backward once when building the car. MY FRIEND found that out because he couldn't adjust the 2-speed. Had to take it out and put it the correct way, no problem since.
Old 07-29-2003, 02:37 PM
  #6770
Nitro Rules
I think I know what you meant now. Your 2-speed shoe did not retract back, thereby, they lock the whole housing.
Yes, I have seen that on other MTX-3 cars.
Check the bearing balls, make sure they're adjusted properly.
Old 07-29-2003, 02:40 PM
  #6771
Nitro Rules
then the center srews are too tight therefore its not adjusted corectly!!
Cartman is offline
Old 07-29-2003, 02:47 PM
  #6772
Default Re: Re: 4 mm chassis
Originally posted by nizee
Mugen made 4mm Chassis that have recessed for the front & rear bulk head, radio mount, etc.. That makes roll center the same as the stock 3mm chassis. Not sure of RD, Kawahara, 3-racing or others 4mm chassis.
Get well soon, nizee. Hope you feel better in a jiffy!
Old 07-29-2003, 03:04 PM
  #6773
yesterday was the first time i ever ran my mtx-3 and when i would let of the brake it would spin out like crazy i think it might be the brakes because when i let off the thotal the brakes would drag do u think that is what could be causing it to do that
pro3user is offline
Old 07-29-2003, 03:08 PM
  #6774
B
did you sand the brake pads like the instruction manual told you to?
if you didnt, then the brakes will drag on the pads
B is offline
Old 07-29-2003, 03:11 PM
  #6775
yep sand the pads or fit a one peice disk!
Cartman is offline
Old 07-29-2003, 04:15 PM
  #6776
EVOLUTION's Avatar
On the subject of pads,what does everyone use to bond the teflon pads,i got a pair and i'm going to put them in later this week?
EVOLUTION is offline
Old 07-29-2003, 04:19 PM
  #6777
EVOLUTION's Avatar
Default Re: GPM Aluminum Knuckles
Originally posted by stefan
yesterday I had the chance to run my alu knuclkles for the first time.
No problems all day long and I hit everything on the track because of radio problems.
I shattered my top deck in 6 pieces after a head on crash at ~40 mph, BUT the knuckles stayed on
Don't worry i have joined the club,i broke 2 body posts last week when the car went air born,LOL.
Old 07-29-2003, 04:22 PM
  #6778
B
CA glue should do the job
B is offline
Old 07-29-2003, 04:45 PM
  #6779
Corse-R's Avatar
Corse what are your rough basic stiings fot low and top end then, i end up around 2 3/4 low 3 to 3 1/2 top end
Uhm.... probably went far those high temp days, probably went up to 3 or 3 1/4 turns in the low end, haven't checked, but will do for you, high end screw was about your adjustment, will check too.
Corse-R is offline
Old 07-29-2003, 04:46 PM
  #6780
no i didnt if i run it will it wear down
pro3user is offline
