Mugen MTX-3
Old 07-28-2003, 04:49 PM
  #6751
stefan's Avatar
Default GPM Aluminum Knuckles
yesterday I had the chance to run my alu knuclkles for the first time.
No problems all day long and I hit everything on the track because of radio problems.
I shattered my top deck in 6 pieces after a head on crash at ~40 mph, BUT the knuckles stayed on
stefan is offline
Old 07-28-2003, 04:54 PM
  #6752
Corse-R's Avatar
Default Re: GPM Aluminum Knuckles
Shattered my top deck in 6 pieces after a head on crash at ~40 mph, BUT the knuckles stayed on
Beware.... track owners can charge you an extra for 'stressing the boards'.
Regarding top deck. Ouch!!!!
Corse-R is offline
Old 07-28-2003, 05:39 PM
  #6753
Vinyard's Avatar
Ouch!! .... there goes your wallet..
Vinyard is offline
Old 07-29-2003, 07:56 AM
  #6754
mistercrash's Avatar
Originally posted by Corse-R
Uhm.... for your symptoms and what you told about the inner side of the Sleeve your P/S is shot and needs replacement.
If you made only two races with your car and suddenly the engine lost the.........
Thank you very much Corse-R. Great post.
mistercrash is offline
Old 07-29-2003, 08:31 AM
  #6755
Default 0.8 module gear
hi, has anyone tried the new 0.8 module gear ? can it improve the top end with a better gear ratio 4.53 ? thanks
speedy100 is offline
Old 07-29-2003, 08:45 AM
  #6756
Corse-R's Avatar
Default Re: 0.8 module gear
I'm using 0.8 spurs as many others on the thread. Personally I liked them, lesser drag (but more delicate, and you need to pay attention to gear mesh), finer stepping on the gearing and others.
4.53:1 is to me a quite steep gearing, if you're looking better high end, probably a shorter gearing will make your engine and car shine at high-end.
Corse-R is offline
Old 07-29-2003, 10:50 AM
  #6757
clmbia45's Avatar
Cool 4 mm chassis
Actually, since the bulkheads, and all attached suspension parts are sitting ON TOP of the 4mm thick, unrecessed chassis, the chassis mass is LOWERED I.E. THE BOTTOM OF THE CHASSIS IS NOW 1 MM FURTHER BELOW THE BOTTOM OF THE BULKHEADS. Since the only mass which lies below the level of the chassis bottom is the portion of the 4 tires and wheels, and since this remains unchanged at the same ride height the the CG must be lower with the thicker chassis.
jack
clmbia45 is offline
Old 07-29-2003, 11:40 AM
  #6758
Default Re: 4 mm chassis
jack
Mugen made 4mm Chassis that have recessed for the front & rear bulk head, radio mount, etc.. That makes roll center the same as the stock 3mm chassis. Not sure of RD, Kawahara, 3-racing or others 4mm chassis.
nizee is offline
Old 07-29-2003, 11:42 AM
  #6759
B
the kawahara chassis does it too i believe
B is offline
Old 07-29-2003, 12:13 PM
  #6760
jack
WRONG!!!
because if you run 5mm ride hieght with both chassis, the four mm you have raised every thing 1mm higher than the 3mm chassis at 5 mm ride hieght!
Cartman is offline
Old 07-29-2003, 12:17 PM
  #6761
Corse what are your rough basic stiings fot low and top end then, i end up around 2 3/4 low 3 to 3 1/2 top end
Cartman is offline
Old 07-29-2003, 12:47 PM
  #6762
Removing gears
Any tips how I can remove the gears on the bell, without damage the bell?
Eben is offline
Old 07-29-2003, 12:53 PM
  #6763
Default Re: Removing gears
buy the correct Mugen tool its not cheap but its cheaper than wreaking clutch bells
Cartman is offline
Old 07-29-2003, 12:55 PM
  #6764
Default 2 spd
has anybody had problems w/ the 2 spd sticking sometimes in 2nd? I have lubed it and tryed it dry both don't seem to work. Help!!!?
Nitro Rules
mtx3racer is offline
Old 07-29-2003, 01:32 PM
  #6765
eddiethefish's Avatar
Default Re: 2 spd
Nitro Rules
eddiethefish is offline
