Old 07-23-2003, 01:50 AM   #6676
Jonathan's Avatar
Originally posted by Roger
Then what happens, you have a new nitro powered car made by ????
Then you'll have issues...issues bro.
B... you win that ld could barely get the S10 going...so mute point
Fire...I think the answer he wanted was...."Wal Mart".
Jonathan is offline   Reply With Quote
Old 07-23-2003, 03:42 AM   #6677
Corse-R's Avatar
Default Re: Rollout and Gear ratio chart
Originally posted by theRED5
I was helped greatly by a friend last weekend and his gear ratio and rollout chart, dloaded off the Mugen website.
I can't remember how to use the chart, can anyone help a brutha out?
Easy, first check what pinion & spur combo are you using and select it on the chart, for example 16/47 & 20/42:
Go firstly at the main column where 16T pinion is and select then the 47T gear.
After this, you need to know what diameter of tires are you using and select on the horizontal line the diameter in milimeters. Cross the vertical with the horizontal and you will get a value. This value is on milimeters how much your car advances.
As you go wearing the tyres, this value changes, check with the table if for getting the same (or almost the same rollout) you need to change gearing.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-23-2003, 06:51 AM   #6678
Manticore's Avatar
R/C Tech Charter Subscriber
Default They arrived !!
lovely !
Manticore is offline   Reply With Quote
Old 07-23-2003, 06:52 AM   #6679
Manticore's Avatar
Default They arrived too !!
Lovely 2 !
Old 07-23-2003, 07:20 AM   #6680
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: They arrived too !!
Originally posted by Manticore
Lovely 2 !
As always, I expect a full written report on this one.
eddiethefish is offline   Reply With Quote
Old 07-23-2003, 07:21 AM   #6681
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: They arrived !!
lovely !
Red shields!!.... you are getting "Hau" in your old age!!
dtm is offline   Reply With Quote
Old 07-23-2003, 07:36 AM   #6682
Manticore's Avatar
Default Re: Re: They arrived !!
i have no choice !! and this is the best they offer !
why you want to make me to relate to your family name?
Old 07-23-2003, 07:37 AM   #6683
Manticore's Avatar
Default Re: Re: They arrived too !!
i think i still owe you many reports !
Old 07-23-2003, 09:09 AM   #6684
RClover's Avatar
lovely !
Acer Super Polyamide Sealed Bearings?
RClover is offline   Reply With Quote
Old 07-23-2003, 09:12 AM   #6685
RClover's Avatar
Default Re: Re: Re: They arrived too !!
heard the news today, HK weather is getting worse.. expect no reports huh?!
Old 07-23-2003, 09:40 AM   #6686
Default Re: rear suspension blocks
The rear blocks are A , B and C.
A = low roll center
B = Mid Roll Center
C = High roll center
C will give you the most rear bite.
I am having a little bit of trouble understanding this roll center concept. From what I am reading, higher roll center move the RC closer to the CG, thus the car will roll less. If the car roll less, doesn't it lose traction? Or it is the other way?
Thanks.
Supra66 is offline   Reply With Quote
Old 07-23-2003, 11:05 AM   #6687
FREAKAH's Avatar
Default Re: Re: rear suspension blocks
Thanks.
Because of the top heavy nature of nitro cars, they use higher roll centers than electric cars to prevent too much roll. Higher roll centers also allows the use of softer spring rates.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 07-23-2003, 12:11 PM   #6688
Assuming all other settings remain constant. If you just change the rear rc, ie raise it by using the C block, doesn't it reduce rear bite because the car will now resist roll better? As the car roll less, less traction will be gained from the tires.
Please correct me if I am on a wrong track.
Old 07-23-2003, 02:44 PM   #6689
Francis M.'s Avatar
the car will have more chasis roll with
the c block (higher roll center) and should
hold more corner speed on lower track
conditions.
(on a different note RD logics just released
a heavy duty cvd for the mtx3)
check out the web site rdlogics.com
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-23-2003, 05:50 PM   #6690
Francis,
Long time no see, good luck @ the nationals.
Vince
BongR is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
