Mugen MTX-3
Old 07-21-2003, 07:49 PM
  #6631
esham's Avatar
Originally posted by mistercrash
I use this book. I find it very helpful. Mpowered Racing chassis set up guide version 3.0
Seem like it refer to the same book so I placed order... Thanks guys.. puma and mistercrash.
esham is offline
Old 07-21-2003, 07:59 PM
  #6632
esham's Avatar
I do have problem installing my front and rear diff - mtx3
1. The O ring inside the rear diff is too tight hold the shaft and rubbing in the o ring housing. This cause my rear diff is to tight - more than my diff oil wt.
So I remove the o-ring and only use the washer as my oil stopper, any other solution guys..or is this happen to you all?
2. I damage the diff screw housing for my diff as well. To tight until the screw cap damage the rear diff screw housing. That spot is so thin. I plan to apply a gasket silicon inside the screw thread, not do that yet but maybe just replace with the new one.
Is there any aluminium diff housing for mtx3 like V1rr/Trinity have ?
esham is offline
Old 07-21-2003, 08:06 PM
  #6633
Racing4Evo's Avatar
You should put the o-rings back in and wait till the car is broken in before you can call it a problem. I had the same thing happen and after the car was worn in, it went away. If you have the cash, then go for the Kawahara negative diff. It has an aluminum case.
Racing4Evo is offline
Old 07-21-2003, 09:01 PM
  #6634
RCTech Member #2
TSR6's Avatar
Default Re: rear anti squat blocks
Originally posted by rcmike
sorry guys,,,tried searching. the difference in the blocks in the kit and the biggest adjustment you have found to do to help rear end stay planted during cornering....THANKS
The rear blocks are A , B and C.
A = low roll center
B = Mid Roll Center
C = High roll center
C will give you the most rear bite.
TSR6 is offline
Old 07-21-2003, 11:19 PM
  #6635
prawntoe's Avatar
Default similar to this ??
Originally posted by alvinm
After an afternoon of racing I was cleaning my car and noticed a crack on the knuckle from the bearing across the bottom of steering arm.My friend had a simular crack on his car.No problems with the pillow balls however(a problem I had alot woth the impulse).
prawntoe is offline
Old 07-21-2003, 11:32 PM
  #6636
Michael_T's Avatar
Trader Rating: 49 (100%+)
Default Re: similar to this ??
Strange break
Michael_T is offline
Old 07-21-2003, 11:52 PM
  #6637
theRED5's Avatar
I went to practice last Fri. and as I was packing up noticed the front wheel wobbling around, I quickly took off the wheel, and it looked like the bearing was broken. I called my local dealer, who's open late, Winnners Circle, and went by and got new bearings.
When I got home to repair, I realized that my upright was broken exactly like yours.
theRED5 is offline
Old 07-22-2003, 12:08 AM
  #6638
Vinyard's Avatar
Originally posted by prawntoe
bad knock eh?
Vinyard is offline
Old 07-22-2003, 12:19 AM
  #6639
RCTech Member #2
TSR6's Avatar
Ouch! That looks like it hurt.
TSR6 is offline
Old 07-22-2003, 12:25 AM
  #6640
Manticore's Avatar
Default Re: Re: similar to this ??
Originally posted by Novarossi
Strange break
it happened to me twice.
first time hit on a naked snake at the end of the straight. stupid snake.
second time, no idea !! just noticed it has broken last saturday.
Manticore is offline
Old 07-22-2003, 12:26 AM
  #6641
Manticore's Avatar
Default Re: Re: Re: similar to this ??
same side and same point of breakage by the way. LEFT hub
we just found out one more weak point of MTX3 !!
Old 07-22-2003, 12:31 AM
  #6642
RCTech Member #2
TSR6's Avatar
Default Re: Re: Re: Re: similar to this ??
Shh!!! Don't say that too loud. Harry, the Snake, TC3, and other drivers WANT to heat stuff like this! ...and it's not true!
Don't start false rumors.
TSR6 is offline
Old 07-22-2003, 12:37 AM
  #6643
Manticore's Avatar
Default Re: Re: Re: Re: Re: similar to this ??
actually, i want to hightlight, the stupid naked snake !
Old 07-22-2003, 05:43 AM
  #6644
stefan's Avatar
I could open an online shop for right side knuckles, because I also always break the left
stefan is offline
Old 07-22-2003, 06:04 AM
  #6645
puma1824's Avatar
Fast Tyres, Power Tires, or Elligi? Which do you guys like better? Have you had any long term problems using the 0 offset tires?
-Puma
puma1824 is offline
