Old 07-10-2003, 07:40 AM   #6301
alvinm's Avatar
Originally posted by Corse-R
Alvinm:
If you go some pages before, you will find between the late night and the boring mornings chit-chat, some posts regarding 16/19 conversion.
This is a swap of the center pulleys to get a better rear tyre wear (all cars have the nasty habit of wear more the rear tyres than the fronts). Is only advised on Foams, on rubber, since the problem of different diameters isn't present, you don't need it (read that you run on rubbers on a previous post).
For more info (in the case you're too lazy to search those posts ) is swapping the rear center (19T pulley) for a 16T and changing the front center pulley from 24T to 19T, hence the name 16/19T conversion.
Corse-R
Will this give you the exact ratio as stock no matter what tire size or do you have to run a certain diameter?By the way I"m using foams.Thanks for all the info.
alvinm is offline   Reply With Quote
Old 07-10-2003, 07:59 AM   #6302
Corse-R's Avatar
Originally posted by alvinm
Corse-R
The ratio remains unchanged, but to use correctly you need to use a tyre split of 3mm (i.e: 64mm rear with 61mm front, 63mm rear and 60mm fronts and so on...).
If not use with split sized tyres, the front end will pull so much and your car will be FWD and be twitchy to drive.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-10-2003, 08:27 AM   #6303
alvinm's Avatar
Sounds good,I guess you have to change belts as well?Are there any pulleys for the side belt that would accomplish simular results?
Old 07-10-2003, 08:55 AM   #6304
Send a message via Yahoo to speedy100
hi corse-R, is it mandatory to use the kawahara pully for using 16/19T ? thanks..
speedy100 is offline   Reply With Quote
Old 07-10-2003, 09:22 AM   #6305
Vinyard's Avatar
Default Kawahara Neg Diff
Just tried the neg diff..... works great.
great punch out of the corners working down on the straight..
problem is my diff's sealed bearings were blown out!
Any solutions to that?
would changing from sealed bearings to conventional metal kinds do the trick.. ??
Vinyard is offline   Reply With Quote
Old 07-10-2003, 09:50 AM   #6306
RClover's Avatar
If not use with split sized tyres, the front end will pull so much and your car will be FWD and be twitchy to drive. [/B]
my front belt is showing the wear of the FWD already... but this isnt a new one though.. but i can tell the effect upon changing the 16/19T conversion..
i found the car has even more steering with quicker directional change.
also, the 0.8 modules are....sweet! despite i have a 6 tooth spread, the gear change was not sluggish at all when 2nd gear kicked in down in a 100 ft stra8way...
RClover is offline   Reply With Quote
Old 07-10-2003, 09:56 AM   #6307
Vinyard's Avatar
sweet eh? good smooth control all over.....
Old 07-10-2003, 10:10 AM   #6308
RClover's Avatar
what gearing are you running?
Old 07-10-2003, 10:45 AM   #6309
alvinm's Avatar
More steering,I like that You lost me however on the 0.8 modules?
Old 07-10-2003, 11:14 AM   #6310
kevink2's Avatar
Default Re: Kawahara Neg Diff
I damaged my first set by installing them last, after the diff was built. I found it's supposed to be captured between the drive cup and the diff case, installed before you seal everything up. I just forced them on, and they blew up like yours.
kevink2 is offline   Reply With Quote
Old 07-10-2003, 12:04 PM   #6311
Manticore's Avatar
R/C Tech Charter Subscriber
Default NS12 S5
just stripped it down. too lazy to post it up ! here is one !
Manticore is offline   Reply With Quote
Old 07-10-2003, 12:31 PM   #6312
B
has anyone tried the ft gear diff for the mtx-3?
i am thinking of getting one, however, there is a guy at my LHS who kept having problems with it and got so frusterated that he switched back to the one way
anyone encountered any problems with the gear diff?
to me, it should work fine?!?
B is offline   Reply With Quote
Old 07-10-2003, 01:16 PM   #6313
Marktur's Avatar
Send a message via AIM to Marktur
Default Re: Kawahara Negative Diff
How did it drive? Was it like having drag-brakes when coming off of a high-speed run?
I just switched to the MTX-3 from the NTC3, which I really loved but broke too easily....but I really liked the lack of rolling resistance when coming off the throttle...for my style of driving (no drag brakes, minimum rolling resistance), do you guys think the negative diff will improve MY lap times?
It's a big investment for a "test"....
Thanks,
Mark
Marktur is offline   Reply With Quote
Old 07-10-2003, 01:51 PM   #6314
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
I have no problem on any of my neg. diff.
eddiethefish is offline   Reply With Quote
Old 07-10-2003, 01:52 PM   #6315
Default Re: Re: Kawahara Neg Diff
Hope you didn't damage the bearing inside the diff, as well.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
