Old 07-08-2003, 07:22 PM   #6271
B
does anyone know where to get those alluminum front servo savers for the mtx-3?
seems that everyone has them, and i cant seem to find a good online store whic stocks them?
the only ive found is acehardwarehobbies, but the shipping there to canada costs 37 dollars for a little piece of aluminum!
so, any other stores which i havent found?, thanks
B is offline   Reply With Quote
Old 07-08-2003, 08:05 PM   #6272
puma1824's Avatar
Send a message via AIM to puma1824
Default Re: Diff Washers
Originally posted by TAW
Does anyone know where I can get the washers for the diff asembly, I have all the pieces tyo build the front diff but cannot locate suitable washers. There don't seem to be any part number in the manual.
Troy
It's part # C0227
It includes several washers...more than needed.
-Puma
puma1824 is offline   Reply With Quote
Old 07-08-2003, 08:09 PM   #6273
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Default Re: Re: Diff Washers
Originally posted by puma1824
It's part # C0227
-Puma
TAW is offline   Reply With Quote
Old 07-08-2003, 08:29 PM   #6274
B
man, it would be nice if mugen made an option which contains all the parts needed for the ft gear diff wouldnt it?
Old 07-08-2003, 08:43 PM   #6275
TAW
That would make it too easy
Its been like a treasure hunt to get this diff put together, not even sure that im going to use it but would like to have it ready in case.
Old 07-08-2003, 09:14 PM   #6276
B
good idea to have a gear diff in handy if you are racing on a tighter, less traction course (e.g, a parking lot)
i am planning to get one in the future, but hunting each part down is bound to be more expensive and time consuming
but, isnt that what this hobby is about?
cheers!
so does anyone have an anwser to my servo saver question??
Old 07-08-2003, 09:34 PM   #6277
RClover's Avatar
its all not too tough to figure out the parts needed for a front diff actually...
-diff gears set with o-rings
-diff washer
-drive cups
-2 pins for drive cups
-o-rings for diff case
-diff gasket
-diff screws
-and of course front diff case with pulley.
RClover is offline   Reply With Quote
Old 07-08-2003, 09:36 PM   #6278
RClover's Avatar
havent you tried www.justrc.com ?
Old 07-08-2003, 11:14 PM   #6279
B
i did, no luck
Old 07-09-2003, 12:58 AM   #6280
Motorman's Avatar
Is the minimum weight limit at the sedan nationals is 1700 grams without fuel? Without body?
1700 as it comes off the track no fuel, with body. Don't forget to consider tire wear. Last year they pre teched before and post teched after the qualifiers and mains. All cars every run.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 07-09-2003, 05:45 AM   #6281
Poste by eddiethefish
Where did it go?
Does anyone have the problem of lose brake pin on the right rear bulkhead like I did? In this case, I lost mine. Was cleaning my car till I notice there WAS something missing.
I'm glad it wasn't the 24K brake pin I was about to use, right? Manticore? RClover?
I lost two of the brake pins last sunday. I lost one that goes on the chassis (vertical) and one that goes on the hub carrier (horizontal). They do not have specific part numbers. Anybody know the part numbers and where to get them? I live in Puerto Rico and there are no replacement parts locally.
By the way I raced the car for the first time last sunday. Lost a steering screw during qualifying and could not finish. Ran in the F Main and won the F,E,D, and, with all the excitement, ran out of gas on the C. Finished second on the C. Enjoyed it a lot.
Jose
joseviejo is offline   Reply With Quote
Old 07-09-2003, 05:56 AM   #6282
alvinm's Avatar
Cartman have you weighed your car with the aluminum options?i guess another reason I'm stressing the gram issue is i have some buddies with 705's decked out in aluminum and titanium and are bragging about the weight.However they have yet to run the cars on the track with the mtx3
alvinm is offline   Reply With Quote
Old 07-09-2003, 06:22 AM   #6283
Send a message via ICQ to Cartman
yes 1760g in rubber spec, limit is 1750g in UK will be less in foam spec!
there is alot of light weight stuff you can not see!!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 07-09-2003, 06:32 AM   #6284
Marktur's Avatar
Send a message via AIM to Marktur
Default Rubber
Hi,
We're starting to run on a parking lot track...ran a couple of tanks with foam, and they were used up WAY TOO FAST! (I'm sure the Michael Salvin .12 had something to do with that, too!)
Anyway, there's 3 of us here with MTX-3's and we're looking for a good "starting" setup for rubber. The lot is smooth and flat, but not sealed. We blow it off and will spray sugar water on it.
Also, please recommend tires that work!
Thanks,
Mark
Marktur is offline   Reply With Quote
Old 07-09-2003, 06:48 AM   #6285
stefan's Avatar
Send a message via AIM to stefan
Thumbs up Corse-R,
last weekend I ran my car with your belts and the 16/19 setup and I loved it.
I was faster than ever before.
The car just turns in like a dream.
The tire wear was the greatest plus though.
I started out with a 4 mm split in the morning, ran practice, 3 qualifiers and 15 min. of the main and ended up with a 3mm split.
I don't know why, but the balance between rear and front tire wear is much better now.
Thank you very much again.
You will get an order for afew more belts soon, if that's still ok.
stefan is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
