Old 06-25-2003, 07:10 PM   #5866
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Tweak station
Originally posted by Cartman
do you use them? which ones?
i like the simplicity of the MIP one.
Manticore can you let me know if i have enough credit?
no, you dont !
I will tell you if the sway bar back in stock again.
Manticore is offline   Reply With Quote
Old 06-25-2003, 07:12 PM   #5867
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi all, can someone explain how to adjust the stiffness of the front sway bar ?
thanks
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 06-25-2003, 07:17 PM   #5868
Manticore's Avatar
thanks
try to understand the direction of the front a-arm movement.
when you have the flat side of the sway bar perpendicular to the direction of the a-arm movement, it is the softest setting.
Old 06-25-2003, 07:17 PM   #5869
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Originally posted by stefan
Why should a nitro car be different than an electric car.
Especially when you want to use your brakes with a one-way, you learn to value a tweak station.
Let's create a scenario: If one were to go to a track where EP and GP run together. Would one set up the EP exactly the same as the GP? Would the person drive EP exactly the same way he/she drives GP if based on the same setup?
There are many things we can neglect on GP that DO matter on EP. Please correct me if I overlook any important factors here. I mean, GP pretty much don't have the Anti-Squat or the Kick-up to play with already, but we do have the roll center to play with, at least. Tweaking can be compensated if one know how to apply the throttle and maneuver the steer accordingly.
Well, I'd better stop now, as I don't have much knowledge on this technical issue. I'm just "the fish". And, lately, I spend most of my time driving my MTX-3, not just sitting on the bench daydreaming of what/how to set it up right.
A good tip I learned from my friend is that once the tires start wearing down; everything i.e. the car setup, will change. Compromise is the key here.
back to siesta...
don't bother me. I'm sleeping...
eddiethefish is offline   Reply With Quote
Old 06-25-2003, 09:11 PM   #5870
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I've used GOOP hand cleaner on the foams a couple times. I've been running without it lately, but it did help when the track cooled down. Just rub it into the foam about 5 minutes before your up, and wipe off the foams before you get to the track.
Yes, setups do change through the run as the tires wear down, but generally my tire wear left to right is the same. My front to rear wear is not.
If the front of my car is tweaked because I was too lazy to toss it on the tweak station, then It will change how the car handles, and it will probably also change tire wear left to right.
I just don't like to leave things behind that I can use as an excuse later on. When wrenching on the car, I always thought it was a goal to make the car the best it can be. If I'm wrong, I'll step off my soapbox.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-25-2003, 09:19 PM   #5871
Originally posted by eddiethefish
Tweak Station for Nitro? You must have been pulling my leg...
Regardless of the car being nitro or electric, you want it to go straight. You don't want the car to pull to one side when you pull or let go the throttle, correct?
The tweak station help you do this.
Sydewynder is offline   Reply With Quote
Old 06-26-2003, 12:12 AM   #5872
Jonathan's Avatar
Originally posted by Sydewynder
[B] You don't want the car to pull to one side when you pull or let go the throttle, correct?
Nope.... you don't want to be sydewynding....
Jonathan is offline   Reply With Quote
Old 06-26-2003, 12:20 AM   #5873
Corse-R's Avatar
On racing, I use one made by one friend of mine that consists 4 kitchen digital scales to adjust tweak, but under practice I have one MIP tweak station that use without a problem, kitchen scales are quicker and precise.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-26-2003, 12:23 AM   #5874
RCTech Member #2
TSR6's Avatar
Default Re: Re: Tweak station
Scales are nice, I just can't justify the cost, personally.
I've borrowed scales a couple times for my electric car, and I found that with the mip tweakstation, I get it so close, that it's not even worth pulling scales out of the bag.
Troy
RCTech Member #2
Old 06-26-2003, 12:29 AM   #5875
Jonathan's Avatar
Originally posted by Roger
Jonathan: Good run at the McCoy's.
Thanks Roger.
I sent you a PM..
Old 06-26-2003, 12:33 AM   #5876
Corse-R's Avatar
Many times is a matter of preferences and the possibility of adjustment. A friend that went from 1/8 gas cars to EP touring, bought an Xray Evo2, the first times at the track, he was overhelmed with all the adjustments of the car and he wasn't able to decide what needed to modify and needed constant help for the setup of the car (in fact, their setup sessions were done on the rostrum, he drived the car and I watched it, made some adjustments and got feedback about the adjustment), this for not saying about how it drived the EP around the track (try to drive a rubber EP touring like a 1/8 scale car ) laptimes were simply nasty.
Some months after he was much better tweaking their GP cars and he got a more delicate driving. He was much constant driving and got better lines at the track. Definitely, EP helped to improve their driving and setup skills.
About your last sentence, isn't all true. Setup of the car is very important, no matter how much dexterity you have controlling throttle and steering if you need to go battling with the car around the track, you will be slower.
Cheers,
Corse-R
Old 06-26-2003, 01:00 AM   #5877
kilokhan's Avatar
I CANT DO THIS
kilokhan is offline   Reply With Quote
Old 06-26-2003, 01:30 AM   #5878
Data's Avatar
i guess what he is trying to say is that he will not spend too much time tweaking his car until it is perfect (i think he rather spend more time sleeping in the fish tank). true, setup is important, but where would one draw the line between excessive and just the right amount? or what is necessary and what is not? One could spend endless hours measuring / truing tires down to 0.1mm accuracy and think that would give one advantage over the other guys that donít. well, maybe, but does it worth the effort or time ? a good, perfect starting point doesnít mean it will stay that way for 40 minutes or when you were hacked.
once oil from the exhaust (or from the track) gets on your carís left rear tire; or when there are more dust on one side of the track than the other side, a tweaking station is not going to help your car go straight when you pull on the throttle. If only we live in a perfect and constant world, but what fun would that be ?
i guess just setup the car such that it is in the ball park area and let your reflex/experience do the rest. MHTC.
Data is offline   Reply With Quote
Old 06-26-2003, 01:56 AM   #5879
RCTech Member #2
TSR6's Avatar
True, but what if the car is tweaked, giving the oily left rear tire less traction as it is. If you take the disadvantage of being tweaked, then the disadvantage of boing oily / dusty, That kinda sucks!
I do agree, that you can't only bench race. You need track time, but you also need a good balance of both. Get the car right on the bench, before you take it to the track. Then, once your on the track, you can work on a setup, instead of fighting a tweaked car, not knowing what is really wrong with it.
Just my point of view..
-Troy
Troy
RCTech Member #2
Old 06-26-2003, 06:20 AM   #5880
sparksy's Avatar
Trader Rating: 14 (94%+)
You can also set tweak into the chassis to compensate for a large number of say right hand sweepers...
sparksy is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
