Old 06-23-2003, 05:56 PM   #5761
stefan's Avatar
Send a message via AIM to stefan
Thanks Data, much appreciated
stefan is offline   Reply With Quote
Old 06-23-2003, 05:58 PM   #5762
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
DATA knows everything. stefan, don't forget to pick the belt that is 6.000mm ok?
eddiethefish is offline   Reply With Quote
Old 06-23-2003, 06:44 PM   #5763
RayJ's Avatar
Default Gearing Solved
I called Mugen Racing today and they have the new gear sets available.
1st gear Spurs: 58,59,60
1st gear pinions: 20,21,22
2nd gear Spurs: 52,53,54
2nd gear pinions: 25,26,27,28,29
These gears will really help narrow the splits between 1st and 2nd gears, and also really give you a low drive ratio if needed for big tracks.
For example 2nd gear: 52/29 combo yields 4.53....whoa....I'll be able to tame any straight with that ratio.
I ordered the gears from nitro house. Hope this helps some.
RayJ is offline   Reply With Quote
Old 06-23-2003, 06:57 PM   #5764
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Gearing Solved
i pick up a set of those gear from Mr. Lam last night. each of the gear comes with a gear ratio chart and the ratio is down to 0.001 i think it is not enough for DATA who needs 0.0001 !
Manticore is offline   Reply With Quote
Old 06-23-2003, 07:04 PM   #5765
Default Re: Re: Gearing Solved
Good!
We expect a full report by the next two weeks.
Old 06-23-2003, 07:07 PM   #5766
puma1824's Avatar
Send a message via AIM to puma1824
Were can I purchase the Fast Tyres online for cheap? I was about to purchase some on Ebay then the auction went away
Thanks,
Puma
puma1824 is offline   Reply With Quote
Old 06-23-2003, 07:12 PM   #5767
Manticore's Avatar
Default Re: Re: Re: Gearing Solved
Originally posted by eddiethefish
Good!
except that the weather is fine here
Old 06-23-2003, 08:08 PM   #5768
RClover's Avatar
thanks for noticing that. When'll you'll be running the 24K gold shock shafts?
nope, i prefer to run the 'Platinum' shock shafts..
RClover is offline   Reply With Quote
Old 06-23-2003, 08:09 PM   #5769
puma1824's Avatar
Thanks,
Puma
Anyone ???
Old 06-23-2003, 08:32 PM   #5770
RClover's Avatar
where do we start with these gearing? any recommendation?
Old 06-23-2003, 08:34 PM   #5771
RClover's Avatar
another view of my beefed camber link
Old 06-23-2003, 08:42 PM   #5772
TBR
TBR's Avatar
I suggest looking at the mugen site it has the two gear charts for the standard gearing and also the new 0.8 gears. There you can compare what you are currently using and then see what gear ratio will marry up with the new 0.8 gears. Mugen
TBR is offline   Reply With Quote
Old 06-23-2003, 08:45 PM   #5773
TBR
TBR's Avatar
Is that the Kawahara adjustable rear sway bar set I see on your car? How do you find it? is the stiffest setting on the adjustable bar harder than the 2.5mm mugen optional rear sway bar? how does the lightest settiging compare to the standard mugen rear sway bar?
Old 06-23-2003, 09:08 PM   #5774
Originally posted by TBR
Eddie, is there anything different between the Mugen belts and the Kawahara belts? materials? width?
The Kawahara is softer belt and dull, while the Mugen is harder and shinier.
Old 06-23-2003, 09:16 PM   #5775
RClover's Avatar
yeap..that's the Kawa Adj Anti Roll Bar Set.
This is a must-get hop up, seriously! The adj stiffness allows me to adj according to the different track conditions. Yes, it is harder than the 2.5mm ones!
the lightest of this adj roll bar is just about the same as with the stock ones!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
