Mugen MTX-3
Old 06-18-2003, 01:58 PM
  #5536
Corse-R's Avatar
Originally posted by RClover
i believe these are castor oil stain after the combustion process.
just to make sure i dont have pre-detonation syntoms..
Uhm, you don't have pre-detonation symptoms.... but the fuel leaves some to desire, those residues doesn't look so good for me, a good fuel not leaves residues or leaves a very fine layer of color over the piston, too much castor or low quality oil.
What fuel is?
Corse-R is offline
Old 06-18-2003, 05:20 PM
  #5537
Hi,
Where i can download MTX-3 manual?
I have a set of Standard Hex drivers, Does MTX-3 has any Standard Hex screws or Metric only???
Thanks.
US_MATRIX is offline
Old 06-18-2003, 05:48 PM
  #5538
eddiethefish's Avatar
Originally posted by US_MATRIX
Hi,
Thanks.
Guess people don't search the info in the forum anymore. Oh! well, here is where to download the manual: Mugen MTX-3 Manual
And, get yourself a Metric Hex drivers, you'll use the 2mm Allen very often.
eddiethefish is offline
Old 06-18-2003, 06:09 PM
  #5539
RClover's Avatar
What fuel is?
i use Gammalube 25% nitro. This is one brand offers more castor %.
http://www.gammalube.com
RClover is offline
Old 06-18-2003, 06:10 PM
  #5540
TBR
TBR's Avatar
You got to have a 2mm hex wrench you will use it all the time.
TBR is offline
Old 06-18-2003, 06:15 PM
  #5541
TBR
TBR's Avatar
And a 1.5mm one too comes in handy too.
TBR is offline
Old 06-18-2003, 06:18 PM
  #5542
TBR
TBR's Avatar
What % oil do you run with 25% nitro?
TBR is offline
Old 06-18-2003, 06:22 PM
  #5543
RClover's Avatar
i didnt add additional oil in the fuel.
RClover is offline
Old 06-18-2003, 06:42 PM
  #5544
RClover's Avatar
Originally posted by Vinyard
Hmmz, now you made me wan to strip my engine and check...
its recommended to check your motor from time to time to avoid pre-mature wear and tear if dirt gets into the motor.
RClover is offline
Old 06-18-2003, 06:58 PM
  #5545
RCTech Member #2
TSR6's Avatar
2.0 mm for most of the car
2.5mm for the pillow balls
1.5mm for droop screws and other grub screws.
TSR6 is offline
Old 06-18-2003, 07:01 PM
  #5546
Vinyard's Avatar
so far no problem with this fuel. unlike 1 other which i had experience with, actually causes my enigne to bogged down.
and i have fren's engine's life shorten, BY very much.
gammelube gave me no problems.
Vinyard is offline
Old 06-18-2003, 10:45 PM
  #5547
theRED5's Avatar
My engines used to look like that when I used BK fuels...Having the engine look like that IS (what I call) a problem. Switched to Byron's Fuel and now the engines are almost like new whenever I open them up. Head buttons just have a slight grey shading ...
theRED5 is offline
Old 06-18-2003, 10:48 PM
  #5548
RCTech Member #2
TSR6's Avatar
Never had that problem with Trinity. I saw it on a couple engines running Odonnel when I was working for the hobbyshop.
-T
TSR6 is offline
Old 06-19-2003, 07:20 AM
  #5549
Red face Where are you?
yawning...
I miss MY FRIENDS...
Life is boring without them bs around...
do not disturb, fish is taking nap.
Old 06-19-2003, 07:31 AM
  #5550
-T
problem might not be from brands of fuel. could be from temperature. how hot it was running, for how long, any after-run oil, etc.
he he, I'll go back to nap now...
