Old 06-17-2003, 12:27 AM   #5491
Corse-R's Avatar
Originally posted by AMainJay
Alright guys, i got my MTX-3 today and started building it. Im glad to be a part of this forum now. Anyways, did anyone have trouble putting that clip next to the one way, that was so hard for me. I was just wondering if anyone else had trouble. Construction is going smooth and cant wait to be done!
You need to get access to a special tool, don't know how is called on English, but resembles like pliers and their nose is 90 bent with the end shaped in two small round nipples. Check in your local hardware store or ask in the shop you bought if they can install for you.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-17-2003, 12:30 AM   #5492
FREAKAH's Avatar
I think theyr'e called snap-ring pliers.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 06-17-2003, 12:47 AM   #5493
kilokhan's Avatar
Wellcome To Mugen Worlds AMainJay.
You'll Love it when it is done ask anything in this foruum and you will get a very fast reply.
kilokhan is offline   Reply With Quote
Old 06-17-2003, 12:58 AM   #5494
RClover's Avatar
Default Re: ouch!
Originally posted by eddiethefish
For a brief moment, the car thought of the song, "I belive I can fly..." Until...
http://www.mytsn.com/publ/psimage.aspi?pid=8084&psid=2
headless snake!
RClover is offline   Reply With Quote
Old 06-17-2003, 01:20 AM   #5495
Does anyone know or try Kahawara (correct me if i spell wrong)
wheel Hex adapter? Someone mentioned that you can use 0 degree offset if you use Kahawara hex adapter.
US_MATRIX is offline   Reply With Quote
Old 06-17-2003, 01:33 AM   #5496
Manticore's Avatar
R/C Tech Charter Subscriber
the kawahara hex comes with 1mm spacers that allow you to run offset rims and non-offser rims
Manticore is offline   Reply With Quote
Old 06-17-2003, 04:41 AM   #5497
acs
acs's Avatar
Originally posted by Corse-R
363mm of lenght. 121 Tooth in total if not remember bad, belt pitch is 3mm.
unfortunatly i can only get 6mm wide belts and that is about 2mm too wide.
I'm guessing the standard belt will be too slack and fall of with the different pulley's.
I will have to try some other places that sell belts.
Al
acs is offline   Reply With Quote
Old 06-17-2003, 05:00 AM   #5498
Corse-R's Avatar
Al:
As I did many times, don't wanna talk about business here, but ordered some and got custom cut to 4mm wide, I don't make profit with this, what I request is what they costed me. If interested on some belts, please PM and I will send you the details.
Cheers,
Corse-R
Old 06-17-2003, 05:10 AM   #5499
RClover's Avatar
i dont have the kawahara hex adapter, but i use 1mm washer.
Old 06-17-2003, 05:15 AM   #5500
RClover's Avatar
Al
i see you very keen on the conversion, just get the belts from Corse-R, these belts are cheaper than normal mugen belts. From what i can see in the picx, these belts are of good quality and should be as durable as stock belts, rite Corse-R?
Old 06-17-2003, 05:34 AM   #5501
Corse-R's Avatar
At least the belt that was installed on the car when I photographied it got 4 hours of continuous thundering (more than 600 laps to my local track).
Belts should be durable (are made by Pirelli, one of the leaders on the rubber business - got the oportunity of choosing some cheaper but passed in favor to those), but as ever, may be the possibility of a lemon (that's not mine intention) and I double check every belt previously to send it, at least on visual shape are without defects.
BTW: All who asked for belts, when receive yours, please give a PM to know that all received and are in good shape (not many did with the brake rotors, but haven't heard cry nor shouts from anything) about this.
Cheers,
Corse-R
Old 06-17-2003, 05:46 AM   #5502
RClover's Avatar
running >600 laps continously is going to make my fingers and wrists frozen and numb!
but a can of bear might keep me awake..
Old 06-17-2003, 05:55 AM   #5503
Corse-R's Avatar
4Hours is an extreme ride, costs of running that day were high (to know: 4.5 litres of fuel, 7 complete sets of tyres (F/R) and 3 CVD's from 3Racing - simply they didn't hold the punishment) quite expensive, but needed some training for the forthcoming nats (was a little rusted ).
Engine got severed (lost all their compression) but was a kinda used engine, new P/S is on the way.
The worst of this running was try to remove the 4 hours of rubber, grease and grime from the car (sheeeesh! exhaust got the dirt cooked over it and is impossible to clean will try to sandblast it). The photos you saw were after a serious session of air compressor and methanol sprayed over it to clean at least the first layer of grime.
Cheers,
Corse-R
Old 06-17-2003, 06:09 AM   #5504
RClover's Avatar
oouch..! that's a pain in the pocket in just one day!
hardwork pays! good luck in your nats
Old 06-17-2003, 07:17 AM   #5505
stefan's Avatar
Send a message via AIM to stefan
Default Cleaning!!
I know that I will get a lot of arguments about this, but here is how I have been cleaning my car after raceday for the last 2 1/2 years w/o any problems:
Take the top deck and the engine off and spray the whole car with Simple Green, let it soak for ten minutes, brush the bad spot with a paint brush and then HOSE the sucker down!!!
Simple Green is very easy on bearings and plastic parts.
I then blow the water off with a compressor.
Car looks like new....
Top deck and engine I do with denatured alcohol and compressed air.
The whole cleaning ordeal takes me 15 minutes.
stefan is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
