Old 06-15-2003, 01:32 AM   #5356
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by Manticore
Ass o shock oil approx 55 to 60wt
awesome... guess its time for a rebuild... I want to play with shock oils a bit, but i had no idea which way to go...
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-15-2003, 03:26 AM   #5357
mitch179's Avatar
Default MTX 3 = :O awesome
ran the mtx for the first time today... got a 2nd and a 3rd not bad for its first run this thing has so much steering but stays planted to the track its awesome.. i could fly through the switch back section in my track it was good fun
mitch179 is offline   Reply With Quote
Old 06-15-2003, 07:35 AM   #5358
Default neg diff
god morning hey eddie im building the neg diff and got a couple ????,what weigth fluid u use?,what are the 2 hole on the clutch housing for?and what is the little metal shim that goes on the outdrive(looking at the instr)for?thank you
rcdubs is offline   Reply With Quote
Old 06-15-2003, 08:31 AM   #5359
RClover's Avatar
RClover is offline   Reply With Quote
Old 06-15-2003, 08:37 AM   #5360
RClover's Avatar
Originally posted by eddiethefish
RClover, I wasn't kidding when I asked you what "brake" was and how it worked. Because I hear no answer from you, the pictures are the result!
No linkage for brake
and everything involved w/ braking system was removed!
[COLOR=red]DEFINITELY NO BINDING!!!
phew! nice ride fish! you got my pant wet
you make me feel guilty now as i still use brake often
perhaps removing the brakes could train me a faster driver
Old 06-15-2003, 08:42 AM   #5361
RClover's Avatar
any feedbacks for the kawa neg diff? fish? manti? anyone?
Old 06-15-2003, 08:43 AM   #5362
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: neg diff
I didn't use any diff fluid. Instead, I use grease, lightly, just to cover up all those bevels. Remember, you wanna take full advantage of diff. If insist, you may choose to use 5,000 or 10,000. Also, remember to sand the housing, so when it engages, it grips hard.
Furthermore, I have no idea of what those 2 holes are for. Maybe someone will soon help us out.
The metal shim you would, at last, insert on the right outdrive, so that the bearing pushes against it and hold the bearing in place. That was it.
food for thought: I also notice that those 3Racing W-shape aluminum bodypost will not fit with the negative diff. One may have to use the stock--which still rubs w/ neg diff; or better yet, opt for the 2nd version Kawahara aluminum rear bulkhead stiffener w/ carbon graphite shock tower. It is recommended per the back of neg diff instruction.
eddiethefish is offline   Reply With Quote
Old 06-15-2003, 08:46 AM   #5363
Heard that Manticore does not use one.
fish loves it, and has been addicted to it since its first introduction to MTX-2.
For fish opinion, it's the best of both worlds! One gets the benefit of diff, and the speed that solid axle has to offer.
Old 06-15-2003, 08:49 AM   #5364
Either that or you'll end up wrecking your car. We need you hear. We don't want you to spend time to change parts nor anything else.
Old 06-15-2003, 08:50 AM   #5365
RClover's Avatar
what would i be expecting when running thicker shock oil mugen 80 with set of purple spring?
Old 06-15-2003, 08:51 AM   #5366
Caution: The car was fully c ustomized for professional driver. Please do not try this at home or at your local track. It may be considered as an assault!
Old 06-15-2003, 08:52 AM   #5367
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: neg diff
The holes on the diff clutch housing is for cleaning the clutch shoes. use contact cleaner to spray thru the little holes to clean the shoes and housing inside.
Manticore is offline   Reply With Quote
Old 06-15-2003, 08:54 AM   #5368
RClover's Avatar
Am i with Ripley's Believe It or Not show!
Old 06-15-2003, 08:58 AM   #5369
Default Re: Re: Re: neg diff
I know it's there for some reasons, since one can't adjust how one soon/late one want to have the solid axle engage.
Thank you Manticore.
Old 06-15-2003, 09:09 AM   #5370
RClover's Avatar
great! does it weight more than normal diff?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
