Mugen MTX-3
#5341
Originally posted by RClover
fish,
that's one new kit without motor on!
seems you dont use brake often, and you are one lucky fish that the inner plate didnt slip underneath any moving part, and the next time you probably found a BBQ motor..
fish,
#5342
Originally posted by sparksy
The Fireman is the only male playing cards. So he has to be the guy.
#5343
are you runing tomorow tommy
#5344
Jack,
You got a PM.
You got a PM.
#5345
Murderer Quiz
The fireman has his name John printed on his uniform.
#5346
Speedtech RC lists under MTX-3 parts, "Rear Lower Arm Pins for MTX-2"
Are these the same for the rear lower arm pins on the MTX3, part number K0213A ?
Just double checking.. I made the assumtion...
#5347
#5348
We're going to have to rename you Eddie the "Goldfish"!
#5349
it means trying to slow down a fish..
No linkage for brake
and everything involved w/ braking system was removed!
[COLOR=red]DEFINITELY NO BINDING!!!
#5350
Thanks!
#5351
no sense for a fail-safe now!great idea but what ever happens i need brakes!cool inovation tho!
#5352
Originally posted by eddiethefish
Same thing; same length. I use my MTX-2 Kawahara rear pins on my MTX-3.
I ended up breaking a rear arm, loosing a couple teeth on a spur, bending the hinge pin, and probably some other stuff, I'm just rebuilding now.
Caught a wall ( made from two 2x4's seperated by a block of wood, they dont give! ) in the turn between a small straight and the backstretch while in 2nd gear.
ripped the right rear right off...
#5353
Compared to Losi or AE shock oil, about what weight is the stock shock oil?
#5354
#5355
