Mugen MTX-3
#5191
Originally posted by VenomWorldOrder
people, there's no need to play around with the mugen clutch. it is perfect!
#5192
Originally posted by Corse-R
A slight grinding with sandpaper of the clutch bell where it touches the shoe isn't modification, is 'improvement' stopped glazing clutch shoes only doing this.
#5193
Originally posted by eddiethefish
darn it... Corse-R knows my intention... can't really hide anything from him, eh?
Now use non-stock clutch shoes and a slight grinding acts magic.
BTW: If you want a self cleaning clutch bell, make some holes drilled in angle where the clutch bell touches, Holes need to be facing clockwise to expel dirt, not on ccw where catches air and of cuz: dirt on your clutch.
Messing with a vertical drill, some pics later.
#5194
#5195
Originally posted by thebutcher
I saw a few people at the regionals that had a nice cover for thier personal transponder. It was molded so the transponder would tuck up inside to protect it, and it was mounted to the kit mount. I think it was Tim Long who had them. Who makes those Robbie????
#5196
Got scated in several races by a glazed clutch shoe that partially engages at sky-high rpms (and of course, engine temp >150ºC.... Poor Nova R1).
Slight grinding on the clutch bell = would this cause the clutch shoe to wear more easily?
#5197
Originally posted by RClover
Non-stock clutch shoe = Mugen Grey Clutch shoe?
The grinding on the clutch makes it grip better to the shoe, wear probably is a little higher that if weren't sanded, but about 12 litres of fuel under racing conditions is a quite good life expectancy of the clutch shoe.
#5198
Nope, Enneti Yellow clutch shoe, similar to Mugen grey but lasts longer.
So, it would only last about 12 l? That's it? Thought it would never needed to replace.
RCLover, wait till I change my clutch shoe to a 24k golden one? Then you can have my old ones.
#5199
while testing out the grey clutch shoe with super hard spring, phew, lots of punch and inconsistent clutch engagement causing the rear sliding too much under hard throttle.
when taking apart the clutch, discovered some oil stain around the grey shoe and clutch bell from nowhere! guess from the inner clutch bell bearings..
cleaned that away, reduced the clutch bell to 0.3mm gap with clutch spring at 0.5mm. its smoother now..
#5200
#5201
#5202
Originally posted by Manticore
just installed the enneti clutch pad on my sirio and will see how it performs this week end if no rain here !
#5203
where the hell did u get that yellow thing? man, i just installed my grey shoe yesterday!!
#5204
#5205
Where can I find the enneti clutch?
So now we have:
Black
Gray
Red
and enneti Yellow
I'm a hetero, but wonder if there'll be a rainbow one in the near future.
