Old 06-11-2003, 07:04 PM   #5131
Manticore's Avatar
R/C Tech Charter Subscriber
Talking
Originally posted by thebutcher
Robbie, it gets pretty HOT in here from time to time. But its usually caused by people who assume too much. You need to be in this thread whenever you get the opportunity.
Butcher
Manticore is offline   Reply With Quote
Old 06-11-2003, 07:04 PM   #5132
TBR
TBR's Avatar
Default Re: PERSONAL TRANSPONDERS
Originally posted by hicheef
Whats up all!!!
Can someone please post a pic or just info one where and how you all are mounting personal transponders?? I have an idea where but I'd like to get an idea where evryone else is so that I don't make a grave mistake. Any input is much appreciated!!!!
Kevin
Why not use the personal transponder mount that comes with the kit?
TBR is offline   Reply With Quote
Old 06-11-2003, 07:05 PM   #5133
Manticore's Avatar
Default Re: Re: PERSONAL TRANSPONDERS
Originally posted by TSR6
I mounted mine on the center steering screw. I posted the pic a while ago... pic sucks... but gives the general idea.
http://www.rctech.net/forum/attachme...?postid=366664
Post #3,000 - TSR6
the screw is going to loosen easily as you cannot tighten it much with the transponder in between.
Old 06-11-2003, 07:11 PM   #5134
TBR
TBR's Avatar
If you are still wanting to use the switch aswell all you need to do is turn the switch mount upside down and get some longer screws to go through both the transponder mount and switch mount. Dont have a pic at moment but can get one if required.
Old 06-11-2003, 07:14 PM   #5135
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default Re: Re: Re: PERSONAL TRANSPONDERS
I haven't had a problem, and I don't even have loc-tite on that screw. It only shims the screw up by about .03".
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-11-2003, 07:44 PM   #5136
RClover's Avatar
Default Personal transponder
i like the idea to be mounted in the foam bumper!
RClover is offline   Reply With Quote
Old 06-11-2003, 10:28 PM   #5137
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Here is a pic of the my MTX3 with the Sqaure graphite switch/transponder holder, works and fits well.
TSR6 - I mentioned this previously, the AMB transponders don't like graphite too much, not sure what your hit/miss signal is, but you may want to relocate your transponder away from the graphite. Just an FYI
The transponders should be mounted horizontally, no higher than 15 cm/ 6 inches with no metal or carbon fiber between the transponder and detection loop.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 06-11-2003, 10:35 PM   #5138
RCTech Member #2
TSR6's Avatar
Nova - Yeah, I know exatly what you mean about the instructions
I've never had a problem. If you look at it, the transponder actually sits above a hole in the upper deck, and lower chassis, not much for graphite or aluminum between it and the track.
Troy
RCTech Member #2
Old 06-11-2003, 10:40 PM   #5139
Michael_T's Avatar
Nova - Yeah, I know exatly what you mean. I've never had a problem. If you look at it, the transponder actually sits above a hole in the upper deck, and lower chassis.
I was having all sorts of problems with my transponder and signal (it was a new transponder). Ever since I mounted it this way, it was tested on the computer, and it gave a high signal each time. You'll notice that there is nothing between the transponder and the ground.
The instructions do say not to have any metal either, most of the guys here just mount it in there bumper.
I guess if you are having no issues, theres nothing to worry about
Old 06-11-2003, 10:46 PM   #5140
RCTech Member #2
TSR6's Avatar
I thought about rigging something up for the bumper, but I don't want to take a heavy hit to the front, and blow up my $55 transponder. ( part of the reason I'm also not to keen on hanging it off the side of the chassis, and I also didn't want to buy a mount).
I usually end up following that good 'ole rule of "between the shock towers, and within the chassis structure" rule.
-Troy
Troy
RCTech Member #2
Old 06-11-2003, 10:55 PM   #5141
-Troy
I saw a few people at the regionals that had a nice cover for thier personal transponder. It was molded so the transponder would tuck up inside to protect it, and it was mounted to the kit mount. I think it was Tim Long who had them. Who makes those Robbie????
thebutcher is offline   Reply With Quote
Old 06-11-2003, 10:57 PM   #5142
Michael_T's Avatar
Tim Long sells this
Old 06-11-2003, 11:00 PM   #5143
Yea, I thought it was Tim. I like IT.
Old 06-11-2003, 11:11 PM   #5144
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi guys, i am planning to get a new sirio .12 outlaw for my mtx-3 , but i have also heard some mounting problem ? is it true ? or i need to do some modification for it to fit ? the mounting problem i am referring to is carburator..any inputs will be appreciated. thanks
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 06-11-2003, 11:23 PM   #5145
TBR
TBR's Avatar
I had to make a small slot in the top deck so that the carby can open up fully on full trottle
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
