Old 06-10-2003, 03:07 PM   #5086
dg8one's Avatar
robbie c
what is a good starting gears for mid track?
thanks
nelly
dg8one is offline   Reply With Quote
Old 06-10-2003, 04:05 PM   #5087
Send a message via ICQ to Cartman
Originally posted by FREAKAH
Great to see you posting on this thread again Robbie!
My rubber setup is similar 'cept I use a long rear camber link.
I also jump around from using and not using the rear swaybar depending on track temps. The track gets pretty hot(140+ deg.) here in Hawaii during the summer months.
Cutting the rear hubs works well as it gives alot less camber change and make the tyrs cooler as they run flatter
will post a pic if needed
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 06-10-2003, 04:46 PM   #5088
Varuth's Avatar
Where is MR. Ken?
Varuth is offline   Reply With Quote
Old 06-10-2003, 05:28 PM   #5089
stefan's Avatar
Send a message via AIM to stefan
Default Re: Re: Re: tires
Originally posted by US_MATRIX
What degree do you guys use for the Fast tire? 0 degree or -2 degree? Or add a shim ?
There are no tires with any degrees of offset.
Offset is measured in mm (millimeters), so they have rims with 0 mm offset and rims with 2mm offset.
For the MTX3 you should run the ones with 2mm offset.
stefan is offline   Reply With Quote
Old 06-10-2003, 05:45 PM   #5090
puma1824's Avatar
Send a message via AIM to puma1824
Could you post your rubber setup?
puma1824 is offline   Reply With Quote
Old 06-10-2003, 07:07 PM   #5091
Originally posted by ROBBIE C
I think these gears should take care of any ratio problems that you have.
Robbie,
Have you run with these gears yet?
thebutcher is offline   Reply With Quote
Old 06-10-2003, 07:19 PM   #5092
Default Re: Re: Re: Re: tires
I still have 6 sets of 0 mm offset rims from my last car. Is anyway i can use it on MTX-3?
US_MATRIX is offline   Reply With Quote
Old 06-10-2003, 07:23 PM   #5093
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Re: Re: Re: Re: tires
I use the wheel spacers left over from MTX-2 for my Kawahara tires, and they are fine, no rub against anything.
eddiethefish is offline   Reply With Quote
Old 06-10-2003, 07:51 PM   #5094
V-1-R's Avatar
Default Re: Re: Re: Re: Re: Re: tires
fish, where do you add the spacers? (inner of hex drive washer/ outer of hex drive washers?)
V-1-R is offline   Reply With Quote
Old 06-10-2003, 08:00 PM   #5095
Default Re: Re: Re: Re: Re: Re: Re: tires
Inner of Hex Wheel adapters.
Old 06-10-2003, 08:06 PM   #5096
V-1-R's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: tires
add the spacer just outside of outer bearing of the upright but before the hex, right?
but, you are using the stock outdrives or 1 mm offset outdrive?
thankz
Old 06-10-2003, 08:21 PM   #5097
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: tires
thankz
You've got it! I'm using the stock outdrives that came in a kit. Who makes the 1mm offset outdrives anyway? Do you know?
Old 06-10-2003, 08:31 PM   #5098
RClover's Avatar
i want the 1mm outdrive..
RClover is offline   Reply With Quote
Old 06-10-2003, 08:43 PM   #5099
kilokhan's Avatar
Kawahara Hex Wheel came with the Spacer.
kilokhan is offline   Reply With Quote
Old 06-11-2003, 02:27 AM   #5100
InitialD's Avatar
Kenji ran these gears at the Winter Natts this year, I noticed his car had a little more mid to top end then mine.
On the setup sheet listed in www.mugenseiki.com listed that Kenji was using 16T/21T pinions and 47T/42T spurs. No where mentioned that he was using the new 0.8 pitched spurs...
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
