Old 06-08-2003, 08:36 AM   #4936
Corse-R's Avatar
Originally posted by TBR
Hey race fans!!!!
Can someone tell me if having a fifth body post helps at all or is it just something that the cool dudes do?
Huh.... mine body after putting the fifth body post don't deforms going at the backstraight at more than 90Km/h... so probably will be fine. Downforce is constant and don't struggles your body.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-08-2003, 10:25 AM   #4937
PMT
Originally posted by RClover
so after the 363mm belt conversion the pulleys will be as follow?
32
19 16
16 19
48
So, this conversion allows us to run a smaller (3mm) front tyres than the rear tyres to maintain the original drive ratio?
If without this conversion, and we run smaller front than rear, what are the effects on the drive ratio?
Amazing! You and your friend spent most of the last 2 weeks bashing the crap out of me about my posts on this and it seems that you did not even bother to read them, not cool. The overdrive ratio sheet that I posted a couple pages back give you the complete OD Ratio for all tires diameters using a 16/19T pulley combination. Also there are some explinations about the benefits of running the 16/19 combo. As I indicated before if you run a 3.5mm split you maintain the origional drive ratio.
If without the conversion you run smaller front than rear tires the effect is that you will have more drive to the rear of the car. This will make it feel more like a 2 wheel drive car, basicaly less planted, more dificult to drive, can not get on the throttel as agressively while cornering etc. If you have more questions feel free to ask and I will try to answere them.
PMT is offline   Reply With Quote
Old 06-08-2003, 02:34 PM   #4938
Default Floating rear + Slipping one way bearing
Hi Guys,
Had a good day today, won my clubs 1/10 200mm race.
One of the cars was an MTX-2 with a Lola body with a rear floating setup. His car is PLANTED on the long sweepers.
Anybody know if you can get this setup for the 3?
During the heats my 2 speed was acting strange. It would kick in, then out then in again etc. Then I'd loose drive for a second, then it would kick in again!!
I traced it to the one-way bearing. Can you clean these out & re-oil them or is it shot?
I use VERY light oil with this bearing, I've heard others talk about proper one-way bearing oil, can this make a difference?
All the best
click, dublin is offline   Reply With Quote
Old 06-08-2003, 03:22 PM   #4939
Corse-R's Avatar
Default Re: Floating rear + Slipping one way bearing
The act on the long sweepers with floating body mount is characteristic, all the downforce created by the speed and body is directly transferred to the wheels, not to the suspension assembly as almost all touring cars do (Try to drive an 1/8 car without the floating body system.... if you have guts )
The abnormal shifting would be caused by several things, first to check is there's any kind of debris, grease, dirt or 'lord only know' on the shaft or the bearing. Best to do is a generous shot of brake cleaner, motor cleaner or similar and then apply a little dab of Serpent one-way bearing oil to the bearing, not on the shaft as many do.
If continue shifting badly check your 2nd speed shoes, should be even spaced into the bell and clean all the residues on the bell prior to reassemble (try to not put oil on the clutch shoes nor bell).
Cheers,
Corse-R
Old 06-08-2003, 03:47 PM   #4940
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Hi Guys,
Oh! Yes, AIP Floating Mount for MTX-2! good stuff...
The Floating Mount for MTX-3 will be released to limited Mugen MTX-3 owners w/in the next two weeks.
I only use the Serpent One-way Lube.
All the best
eddiethefish is offline   Reply With Quote
Old 06-08-2003, 04:21 PM   #4941
TBR
TBR's Avatar
Originally posted by Corse-R
Yep, using the same 16T pulleys that come on the center shaft to move the one-way/diff on the rear and moved the rear 19T pulley to the center shaft. Easy, clean and not needed to mess with other manufacturer pulleys (well, probably Kawahara ones, but on my next hop-up craze.
Sorry little confused are you saying that all is required is moving the 16T pulley from the front and replacing it with the 19T rear pulley?? So this requires a larger front belt only?
TBR is offline   Reply With Quote
Old 06-08-2003, 05:38 PM   #4942
FREAKAH's Avatar
I use AE silicone diff lube with excellent results. Racers Choice also has a oneway lube.
Don't use regular oil or grease because it's too slippery. They won't allow the rollers to lock properly.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 06-08-2003, 06:44 PM   #4943
stefan's Avatar
Send a message via AIM to stefan
Default Speedmind foam tires
Today I tested my first set of the new Speedmind Nitro TC tires.
Speedmind always had good foams for electric cars, but no front compound like the GRP tires.
Recently they released the "Beast" which is their new front tire.
I ordered a set of 42/40 in 26/30mm.
I am totaly sold on these tires.
They wear better than the GRP's, they seem not to chunk as easy and they have the same if not better traction.
Considering that I bought them for $12.95 in the US is the best part.
If you want to know where to get them, shoot me a PM and I'll let you know.
I won't post it here on the board with respect to the sponsors.
For more info on the tires, check
http://www.magmarc.com/pages/catalog/magma.htm
stefan is offline   Reply With Quote
Old 06-08-2003, 06:46 PM   #4944
stefan's Avatar
Oh, and I forgot, the rims are super strong.
Old 06-08-2003, 07:12 PM   #4945
Taylor-Racing's Avatar
Default Re: Re: Re: Re: Re: 363mm custom Belts order.
Still on testing phase (sorry, I take mine club races very seriously and haven't tested yet, but previous practice sessions gave very good results).
Probably will swap to the new pulley system on the forthcoming National race (very very abrassive surface, almost sandpaper).
OK, I would be pleased to hear your results.
We also take our club races seriously - probably too seriously.
We ran a 20 minute final yesterday using 35 shore front and rear, and with enough ride height to do it, I thought.
The car (VoneR) performed really well, but as you might imagine, rear tyre wear was considerable. There were quite some sparks coming from the rear end near the finish.
We have entered a three hour Enduro for next weekend. Our part will be three x twenty minute sessions.
Taylor-Racing is offline   Reply With Quote
Old 06-08-2003, 07:36 PM   #4946
RClover's Avatar
All the best
Few of our club members had similar problem to yours. When i checked on their 2 speed clutch shoes, found that they werent properly adjusted (refer to attachment sheet from manual) at the two steel balls which wasnt compressed enough to hold the center shaft nut.
RClover is offline   Reply With Quote
Old 06-08-2003, 08:01 PM   #4947
Manticore's Avatar
R/C Tech Charter Subscriber
Hi Guys,
All the best
congradulations !!
i suggest you to check on the shoes adaptor to see if there is any worn spot. the worn spot will make 2nd speed shifting funny.
I would suggest to replace 2speed shoes, screw set and the adaptor nut as they are not expensive.
Manticore is offline   Reply With Quote
Old 06-08-2003, 08:10 PM   #4948
kevink2's Avatar
Default Re: Speedmind foam tires
Sounds great Stefan, are the offsets similar to the FAST tires also?(Is it a direct fit?)
kevink2 is offline   Reply With Quote
Old 06-08-2003, 08:15 PM   #4949
Does any know that if ROAR is going to follow IFMAR rule for allowing turbo plugs? Thanks
ME-student is offline   Reply With Quote
Old 06-08-2003, 08:34 PM   #4950
stefan's Avatar
Kevin,
they fit on my MTX3 w/o any problems.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
